Turbone
Administrator
Everything posted by Turbone
  1. Just curious, how much did you pay for that trim from the dealer?
  2. Dang it, I looked for that thread and couldnt find it Thanks NW.
  3. Good gov gear = [] Applecored gov gear = )( There were some pics sometime in the past, but it appears they are gone. I would disassemble the valve and clean it good. Ah, I found a old article. It has pics, but not of a cored out gov. http://web.archive.org/web/20050227203610/www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f57fdb83de231.34713659.art
  4. Glad the car did its job and your ok. Can I have the engine?
  5. I would hold off until you find out what insurance is going to do.
  6. A lot of times the temp gauge wont register a correct temp because of a lack of water. Make sure the water is topped off to get a accurate reading.
  7. What color are you looking for? Have you posted in the Wanted forum yet?
  8. Yup, I'm about 7mi away. Might have time in the late afternoon to look at it, maybe. I have to work on my nieces 04 Malibu tomorrow :-\
  9. Its possible the t-stat is stuck, but I doubt it. Its most likely a headgasket is bad.
  10. Get the belts and timing correct first.. http://www.ultimatesubaru.org/forum/showthread.php?t=50768&highlight=timing+belt Then if it still has problems do more trouble shooting.
  11. The 85 and 86 RX trans is part time 4wd with D/R. The gearing is the same as the S/R trans. And its still 3.7 ratio.
  12. This is the winch on my Hatch. Its a Warn 6000 mounted to a standard winch bumper thats mounted to a steel channel front bumper. It has pretty beefy mounting brackets mounting it to the frame rails. I have actually bent the mounts winching myself (and others) over the years.
  13. I guess have a try at the modulator then. I'm far from a guru when it comes to a transmission, but I would say if this doesnt do the trick I would be looking for a replacement or swap in a 5spd. Not sure how your missus would like that, but it would solve having to deal with it again. This make of trans from Subaru is notorious for going bad and fixing one is more costly than replacing.
  14. Its a solenoid valve, part of the EGR system. You can use one off of your other intake. Just be careful, they are usually pretty brittle.
  15. You could try draining-replacing the fluid. Not sure I would do a flush on it, may be more hurtful than helpful. I dont think theres a filter for it either, my parts book doesnt show one.
  16. Try doing a search for EA82T, should come up with a few results. Dont expect a lot of them to be good tho. I see you're some what local, if you want help or parts just let me know.
  17. I would have posted this link earlier, but it was borked. Now fixed. http://www.indysworld.com/80s/general/USRM/Transmission/Governor/ATgovenorclean.htm
  18. You can check to see if the governor is apple cored. Its on the passenger side of the trans and has a round cover that sticks out on it. Try calling 1 866 528-5282 or ordering a new one at http://1stsubaruparts.com/ Heres someone else that had the problem, but it sounds like in the end he probably had to replace the trans. http://www.ultimatesubaru.org/forum/showthread.php?t=47309&highlight=governor+service
  19. http://www.smart-service.com/index.html
  20. Thats why they say JEEP = Just Empty Every Pocket
  21. Just need to read.... And it looks like I havent updated here either. Its really not all that low either, the tires just fill the space well.
  22. Spillmaster ftw. My RX... My old GL-10 T-Wagon... And the GL-10 again, but with a type that fits in tight spaces.
  23. Some unique stuff there. Like how the cooling fan is run by the generator. The transverse leaf suspension is the same as the old Opel Kadetts.
