2008 Tribeca Transmission failure
1 Lucky Texan replied to hertfordnc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^^^ good post
best brake line material
I recall reading about some lines made from a cupro-nickel alloy?
Anyone found alternative to OEM drain plug crush washer
1 Lucky Texan replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDorman sells a box of 20mm washers but, yeah, you could just buy a several next time you're at the dealer too. https://www.amazon.com/gp/product/B001SNRGAA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
1991 XT6 won’t idle, runs rough
if a few sprays of starter fluid calm it down - that would point to fueling.
09 Fozzy XT Tires.
1 Lucky Texan replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my WRX I run Kumho ECSTA ASX or ECSTA 4x .
Persistent P0136 O2 code after harmonic balancer failed
if the bearings for the toothed idler are failing, that could be a source for magnetic debris too.
from a stock 1996 subaru outback legacy 2.2l manual 5 speed to an offroad adventure wagon
fix the headgasket, sell the car, buy a turbo Forester to play with.
engine ticking when cold
I have read of some negelected engines having gummed-up oil control rings. Might cause low compression?
Do you heat seized bolt or crossmember or bushing sleeve?
- Ej22 Idle oddity/issue
1 Lucky Texan replied to Auz23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI dunno, wondering if examining the plugs might give a clue? maybe a cylinder is misfiring and a plug would appear different than the other 3 ?- New XT Foz In My Life!
1 Lucky Texan replied to Sonicfrog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsweet ride! Make sure to get OEM or Japanese parts for the timing belt system service.- Any reason NOT to use Idemitsu power steering fluid in 2001 OBW?
1 Lucky Texan replied to brycarp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmany of us would use Valvoline MaxLife trans fluid in that car. I did. It's Dex II/III/VI w'ever compatible.- 1997 Impreza OBW ABS Light on
1 Lucky Texan replied to palfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrear bushing on the lower control arm can knock/thump.- 2001 Legacy GT stalling at startup
1 Lucky Texan replied to ViktoryDog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdownstream (post cat conv) does nothing related to a:f or other parameters related to the engine's performancein that car (pretty sure only the H6es may use that sensor for a:f corrections). It is a 'nanny' for cat conv heating-up properly. hopefully, someone with more experience will replay but one thing you might do is, in a new thread, ask for recommendation of a soob-friendly shop near your city. Someone may know a good independent mechanic.- loss of power - sudden burst of power - repeat
1 Lucky Texan replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmany folks have good luck with the Subaru Coolant Conditioner (repackagaed Holt's RadWeld) ONLY one bottle, ONLY install per directions.- Hints on hard-to-start '01 H6 OBW?
hmmmm....OK, next time it's cold/prone to exhibit failure....try cycling the key several times, from OFF to ON-wait for a 3-4-5count, OFF-ON,wait,OFF-ON,wait, then OFF- Start. If there's leak-down of pressure in the fuel rails, that should correct it and maybe starting will be better? wonder what the plugs are like? proper NGK or some oddball type? just trying to eliminate some 'problem areas'. any stored codes?- H6 Timing cover area oil leak
1 Lucky Texan replied to cwells's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's coming from higher up, oil pressure sending switch/sensor might be leaking. They can leak a lot. kinda under the alternator?- Do you heat seized bolt or crossmember or bushing sleeve?
yeah, I get it, my situation was more, 'open'?, and I had splines. Though, in line with your comment, maybe that meant MORE rust/corrosion was involved? I never even got anything red so, just watch out for fire. You may need to either spray a LOT, or wait until parts cool a little. Can't se much opportunity for liquid to penetrate if it all vaporizes! anyway, fingers crossed...- H6 Driveshaft Broke
1 Lucky Texan replied to Zoltan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmake sure the car is idling on level ground when you check the trans fluid level.- Hints on hard-to-start '01 H6 OBW?
hmmmm, with cool weather, a bad engine temp sensor might explain the symptom of initial lean/poor running with better bahavior after warm-up. Can't signal the ECU for 'choke' injector settings if it thinks it's already a 'warm' engine.- 01 Fozzy check engine flashing
1 Lucky Texan replied to upnorthguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdead coil? I think the cyl pair 1&2 share a coil due to waste spark.- Do you heat seized bolt or crossmember or bushing sleeve?
I think I would try 'moderate' heat on the bolt, then spray/flood with some penetrating fluid. I had read before that suggestion , the fluid cools the parts and as they cool, the fluid can be 'draw in' . Then let is sit and go back to trying to drive the bolt out. I might try it twice before going back to a more drastic plan. I did a similar thing to a severely stuck axle-in-hub problem on a chevy impala. Propane heat for 30 seconds at 12 and 6 oclock positions, sprayed with PB blaster, waited a coupla hours I think, went back and it started moving finally. ymmv- loss of power - sudden burst of power - repeat
1 Lucky Texan replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXmaybe a pinhole is spraying coolant on a cracked spark plug wire?- Subaru Forester 2006 - 154k - change transmission oil???
1 Lucky Texan replied to Stirletz1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhasn't ATF has been 'synthetic' for a long time ?- Prospecting a 2010 Forester. Can I trust the dealer??
1 Lucky Texan replied to augustsky3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWait, is this a SUBARU dealership? If so, should be easy to get documents showing what parts have been put on the car - if they serviced the timing belt system, you want to see more than just the belt listed as mentioned above. The toothed idler is often the point-of-failure, not the belt. maybe push them for some little powertrain warranty? - Ej22 Idle oddity/issue
