Everything posted by DaveT
Head bolt stripped?
The repair kit I have is Coil Sert Part Number IK405-11 M11x1.25 metric- fine
Head bolt stripped?
oh, do you mean will the Helicoil tap work with the Timsert insert? I would be surprised if it would.
Supercharger for EA81
From the EAVS super charger link - the model for a 1.4 liter engine uses a 4KW motor to drive the supercharger. That's a little over 5 Horsepower, so a 1.8L will need a bigger one.
Yes, for any of these later ideas, start investigating how much power it takes to compress the CFM you need to supply at the boost pressure you want.
Head bolt stripped?
I can try to look up where I got the helicoil style ones I used. Yes the others are stronger. But the ones I used worked, and were not in the $100s for cost.
Coolant leak spfi manifold
Get OEM gaskets only. Run the engine to normal operating temperature. Carefully loosen the 6 bolt ASAP while hot. Also the EGR pipe. Best to have a flare nut wrench for those. Rock them back and forth, gradually progressing. Do not force them. IF you are very careful, you can feel the difference between the bolt twisting springiness before it starts to yield. Sometimes tapping downward on the heads can help loosen them, but don't hit so hard they begin to deform. That's the hard part. Especially with that much crud / corrosion build up. You'll need to use wet / dry sandpaper to recondition the mating surfaces. Once those items are loose, you can let it cool off before removing the coolant lines, etc. Unbolt the AC compressor and swing it out of the way, the hoses are long enough.
Crank, No start..Battery drains after a few cranks
DaveT replied to AlexAhiao's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow old is the battery? What size? Did it used to start the car?
Is it a thermostat problem?
DaveT replied to Subruman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNeed to read the codes that are setting the check engine light. I've never read about or seen anything that ties the check engine light and temperature together, so probably coincidences? Not getting *all* of the air out of the cooling system can cause troubles with overheating. Over normal temp while low on coolant can damage the headgaskets, so watch that like a hawk. Need to know what size engine it has, so that one of the experts on those years / models can verify if the engine is interference or non interference. Turned what shaft? Maybe the exhaust seal that goes between those flanges isn't thick enough? Aftermarket exhausts can be iffy alignment wise, and all. Is it a known good reputation system, or el cheapo ebay special?
94 loyale dies when I let off clutch
Certainly worth checking the belts.
That rules out the exhaust. Does the fuel pressure stay up while trying to get it going?
Easy test. Support the y pipe, loosen the studs to get a 1/2" gap between the heads and the flanges. Short test run. If it runs normal, something is blocking exhaust. Gutting the cats will increase emissions. Not a huge difference in power or anything else.
ea82 bad motor?
I'm not sure pulling a vacuum on the coolant system is a good idea. Certainly not more than a few psi. The small amount of air left after the usual "burp" procedure will work it's way out in a few drive cycles IF everything else is working correctly, sealed / no leaks. I saw a funnel system for sale on amazon that makes it a lot easier to fully fill the system without making a mess.
ea82 bad motor?
Oem or best quality Stant for the thermostat. I'm running a 180 degree in one, and a 190 (normal temp) in the other. The heater is much better in the car 190 degree car. I'm in CT, so get a range of temps year round. I run 10w-40 synthetic oil. +1 oil pump seals, including the shaft seal. The bubbling bothers me. That's not normal especially if it is coming from the cooling system. There should be nearly none to zero air in the radiator / upper hose. Check the upper hose by sharply squeening it while listening for the giggle pin, and air gurgles. Check the level in the recovery tank. Before every cold start for a while, to see what is going on. It takes several times / days to gather this data l, unless things are going downhill fast. Waiting to see the temp gauge go over normal while low on coolant is bad for headgaskets.
ea82 bad motor?
I'd drive it. Look up "tick of death" for the noise. When the leaking gets bad enough, reseal the cam tower /s. Did you use the oem metal reinforced o rings?
What is the limit of 4wd? 91 LOYALE
I have a dual range 5 speed trans laying around that needs a home. Someone on here will likely know the ratios, but iirc it was noticeably slower in low range.
Experience with burst/leaking hoses?
DaveT replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook at the fsm cooling system diagram to find all of the little bypass hoses. Once you decide any one of them isn't looking good, Replace all of the cooling system hoses before they fail. Not worth the risk to wait until failure.
Found a gold standard '91 Loyale, literal 'little old lady' car
Buy it. Fix or find and rebuild an engine. I choose fixing driveline over rust any day.
Distributor cap gasket?
Maybe an o ring? Or gasket sheet blank. Or sheet rubber of your choice. I have bought sheets from mcmaster Carr and MSc direct. Then cut to match.
power cutting out/stalling. not the fuel pump
There are numerous connections between the battery, power distribution, fuse block, ignition switch, etc. Any one of them could get intermittent. I've seen wires break inside the insulation also. But that's rare. I might wire in a test light to key systems, such that when it quits, you could tell if that system was getting power, or loosing it.
90 loyale suddenly quit
Always good when it's a simple thing. I have yet to have one of them fall out. Been driving these since 1988.
Does it crank with an even rhythm, or uneven? Pedal down and crank is flood clearing mode. 1 or 2 seconds of carb cleaner into the air intake will make it run for a few seconds if the spark, timing and distributor are all good. Pull one of the smaller hoses to squirt it in toward the throttle body.
fuel pressure sounds good. check the timing belts check the rotor in the distributor check for power at the coil
New 2010 Forester Owner - Fog lamps not working
DaveT replied to Hikerboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe have an 09 Forester. The foglights are wired stick right now, and can only be on with the low beams. Which is wrong, since in really foggy conditions, the fog lights are more effective with the headlights off. I've had opportunities to verify this with my older cars with aftermarket fog lights over the years. I also often run with the fogs on in good weather, as they fill in places the headlights alone don't hit well. I check that they are aimed properly. I usually leave them off in city driving.
1989 Justy kaput
What I run is mid quality conventional battery, but I get the biggest one that will fit in the battery space. This gets you some extra reserve, some extra cca. And, at it's end of life, (about 5 years) it still has enough to start the car, so you can still let it go a bit longer. I looked at those fancy batteries a while back. They cost about double a conventional one, last about twice as long. Doesn't make financial sense. I haven't priced them lately, so check.
Head bolt stripped?
I have done 1. I'm in CT.
