87
Everything posted by DaveT
91 loyale front end locking up
DaveT replied to Boogerweed308's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The original description does not sound like brakes. I've forgotten to release the parking brake once or twice in my life. The brakes don't get grabby when they get hot, they smell bad, and become less effective. I'll add, I set the parking brake every time I am parking the car.- 12 replies
- 91 loyale
- Transmission
(and 1 more)
Tagged with:
Help with new injector spfi
DaveT replied to grandam88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had one where the engine would idle down to zero sometimes. The wire to the IAC valve had fractured, inside the insulation. Narrowed it down to the harness on the engine with an ohm meter. Didn't find the break until I unwrapped the harness. Can't say that this is definitely your problem, but it shows how sneaky these things can be. -
I have / had a 90, 92, 93 Loyales. All 4wd wagons, 3AT transmissions. In the US. There may have been other options?- 12 replies
- 91 loyale
- Transmission
(and 1 more)
Tagged with:
Before replacing stuff that was already replaced... check the idle air valve and it's wiring. -
Tie Rod Boot replacement
DaveT replied to rae houghton's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like you got things back together. Something is very wrong if you have to drive a roll pin with much more than moderate firm tapping... There are very few things to use the "get a bigger hammer" technique on with these cars, and those are usually last ditch destructive disassembly. 6 point sockets - good ones - help a lot with these old stuck bolts. The o ring can be used like an elastic to help hold the end closed / in place. But all of the ones I remember seeing have steel spring clips holding the boot. -
If you run a 3AT in 4wd on dry ground, you will feel drag. Do it long enough, wear something out. Probably the clutch Pack that enables drive power to the rear. I once had one that was run with no gear lube in the front diff too long. The pinion bearings failed, allowing the pinion to move forward and hit the diff carrier when engine braking was allowed to happen. That made for some horrible jerkyness and horrible sounds. Got it home by never allowing the engine to slow the car. The seals failed by then, and the last of the atf go t i to the diff. just as I pulled it into my garage.- 12 replies
- 91 loyale
- Transmission
(and 1 more)
Tagged with:
I've looked a few times, can't find that thread... -
1992 LOYALE LEAKING 5L OF OIL A WEEK.
DaveT replied to Kootenays kid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A few key things - resurface the heads is a must. There is a thread about DIY on the forum, or machine shop. Fel pro or OEM headgaskets only. Has the engine ever been overheated while low on coolant? -
NAPA had the axle seals separately the last time I bought them. Here is a pic of one side of an EA82 power steering rack with tie rod and tie rod end. -
For the rack boot, I'd take a close look at the spare one, if it looks ok, try to remove it. I can look at a spare on tomorrow. -
I have worked a little new grease into the bearings without removing them. GL 2 grease. I happen to use Amsoil, don't know for sure what other types are compatible. If they are not making noise, it wouldn't hurt much to add a little, see what happens, and gather parts to redo them later. It will take time for them to fail. Normally, the bearings are removed from the knuckle, cleaned, re greased, and re installed. With new seals. I have been running EA82 wagons since 1988. Have not had one wheel bearing fail. I have cleaned and repacked the bearings sometimes when replacing an axle, but not always. -
I have never heard of a car alternator failure cause any such problems. Typically, once the battery is depleted, the car stops running. Nothing permanent. Lots of smoke. White sweet smelling, or blueish oil smelling? A 92 is passed due for a reseal. There are oil passages that supply oil to the lifters and cams, and they pass through the heads, so there are a few places they develop leaks, in addition to the cam and crank seals just being dried out. Usually, the cam seals are the leakers, but they are just one of the leak points. I've had many years running these models where I would go for long runs with nothing but minor repairs. Once you get everything put right, it should be good for a long while. If you reseal the engine, the most important thing to do before driving it is thoroughly evaluating the entire cooling system. -
I am confused. A lot of questions about tie rods. Then pictures of axles, CVJ, and DOJs. -
I do no t know for this newer engine, but my experience with EA82s is that 3/4 overheat with low coolant is all it takes to damage headgaskets. The real test is to monitor coolant level like a hawk [every drive cycle] for at least a week. If coolant is going away, and there are no other leaks, or coolant is always pushed into the recovery, not a good sign.
To the backyard body men
DaveT replied to crazyhorse001's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I saw the OP. I tried to think of an idea... But nothing came to mind right away. Pictures might have helped. Also, I just never had to do that sort of repair before - it's one of those things I'd figure out best on site. I have a gantry crane and a backhoe, which have changed how I approach many projects. -
Nuts. I did something sort of like that years ago. Put a 3/4" id 10 foot piece of pvc Condit diagonally across inside my wagon. Closed the back, No problem. Another trip, I buy a 2" id 10 foot piece. It doesn't bend as Much as the 3/4... looked like it fit and all, but when I closed the back, I cracked the windshield.
Source for front axle cone washers?
DaveT replied to McDave's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since 1988 I have used grease and antisieze on those parts. Not once have I had a problem with anything loosening. And they come apart again the next time service is needed. -
Will 3rd gen wheels fit 2nd gens without issue?
DaveT replied to catbus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That sounds correct. I remember making 1/8" thick spacers to use a couple of old rims on a newer (86) gl. It was due to the brakes hitting the inside of the rim. I don't remember why I wanted to do it however. -
Steering wheel wobble solved apparently
DaveT replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had wobble like that. Gets bigger while slower, fades to near zero on the highway. Found that part of the tread on a front tire was separated from the steel belts. Turned out both front tires had the sam problem. Swapped them for another pair, and a week or so later, same thing. The alignment was too far out. Adjusted it, swapped on another pair, and no problem. The car steered better also. -
I recently bought a pair of the sachs ones. The only other source of adjustable ones I ever saw was Subaru.
Yes, find the leak. Failing headgaskets usually push coolant out, air into the reservoir. Check ALL of the several coolant hoses, not just the radiator hoses. You may have a small leak to the exterior that lands on the hot engine, and evaporates before you see it. Does this model of engine have intake gaskets that share coolant and intake passages like EA82s? And / or a coolant passage between the throttle body and manifold?
Big washers from a hardware store . Maybe a pipe fitting or 2. ? I'd have to go make a few measurements to be specific.
