Ej25d Weird Timing Belt Tensioner
johnceggleston replied to jread's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ebay.com/itm/Fits-96-97-Subaru-Legacy-Outback-DOHC-2-5L-EJ25-Timing-Belt-Kit-Water-Pump-/360421290862?fits=Year%3A1997|Make%3ASubaru|Submodel%3AOutback&hash=item53eac8736e:g:lhkAAOxy9eVRJRRm&vxp=mtr
johnceggleston replied to jread's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXjread, you already have the old style tensioner, \which is considered better, why are you pricing the bracket for a conversion??? i guess i missed something. you also did not specify your year????? but if it is an ej25 and factory stock, it must be a 96 - 97, maybe 98. the swap to the new tensioner took place with the 98 model year. i guess there is a possibility that canada got ''changes'' on a slightly different schedule. but i doubt it unless the US law dictated the change. does any one know where canadian legacys are built???
cluster problem.99 outback
remind be of your problem, and what you have tried up to now. 99 is a one one year speedo. and it has a known failure issue. usually corrected with an improved ground wire on the circuit board. i do not know about the rest of the instrument panel.
4:44 LSD GL 10
the swap you are considering is a huge amount of work, even if the parts are free. why not just swap in a dual range manual trans and call it a day. you will have a ''hiway'' range for fuel economy, and a ''low'' range for when you want ''power'' off road. just my opinion.
2001 outback engine
johnceggleston replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou don't ''gain'' anything, reliability or power, by doing it. but since you have the heads you will save the cost of rebuilding the old heads. the y-pipe will cost you some thing though. but it will work.
- Air box
95 impreza leaking oil and powersteering.....plz help
johnceggleston replied to Doby82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe power steering fluid leak is usually the o-ring between the reservoir and the pump. use a turkey baster to remove the fluid from the tank. then you will see the bolt in side the tank.
'98 Legacy Outback immobilizer issue
you do not seem to have the factory installed ''remote entry'' unit, so none of those instructions will work. i would call the remote start company and ask about testing or removing the unit altogether.
Steering coupler removal
if it is like the 90s legos, and i assume it is, one pinch bolt ''rides'' in a cutout in the shaft. in other words, one end of the u-joint coupler MUST be correctly aligned with the shaft. the bolt not only pinches, but it rides on a notch on the shaft. REMOVE this bolt. i think it is the lower, steering rack, end. the other bolt, upper end, needs to be loosened. once done, you can slide the u-joint up onto the steering column shaft so the lower end comes free of the rack shaft. i could have the shaft the ends mixed up, but i do not think so. caution: it is easy to reassemble so that the steering wheel is not centered. careful.
1996 Legacy AT fluid shows over filled after fluid change?
how long is the dip stick? do not drive it until you answer. you probably drained the trans and filled the front diff. how long is the dip stick? it happens.
97 Legacy outback blowing trans fluid out of the vent.
johnceggleston replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFYI: i have a rebuilt one in Va, 24014. i know it is a long way away, so probably not practical. i do not know the miles on it after it was rebuilt. but it has plate / tag indicating the date it was rebuilt. it has been sitting in a wrecked, T-boned, 98 outback for several years.
99 OBW front disk brakes slide pin lube
johnceggleston replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit is a high heat lube. purple, iirc.
Outback H6 4eat compatability
johnceggleston replied to imprezkid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXengine Hp + final drive ratio + wheel size / tire size = power output / fuel economy. i know it is not that simple, but all 3 play a part. in the 00 - 04 years, legos, brighton, L and imprezas (low end) have smaller tires. they also have the 4.11 FD ratio. outbacks, foresters, GTs all have larger tires and the 4.44 ratio. (gt only slightly larger, but still larger.) the H6 does nor suffer from the same power output limitations as the outback & GT cars. it has tons of power. therefore, the final drive does not need to comply with the same power formula. ALL H6 auto trans in the 00 - 04 years have the 4.11 final drive ratio. it is also my understanding the the H6 auto trans has different gear ratios, 1- 4, than the lego 4eat. but i would have to research this to know for sure. hth.
FWD Fuse in 96' Impreza
johnceggleston replied to golucky66's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe FWD fuse is interesting. but if you want real fun, search for AWD ''locked switch'' . it is the reverse of FWD. it locks the AWD in a 50 / 50 split, front to rear. not practical in most situations, but very desirable in some situations. but it is NOT what you want when driving on dry pavement . good luck.
98 Legacy GT duty c solenoid/ transfer clutch problems
johnceggleston replied to xMalonex's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat dash said. change the fluid. tip: reading trhe dip stick can be difficult. if you measure the fluid you remopve and add that much back with each frain and fill, you will not have to depend on the dip stick . also, be sure you KNOW the location of the AT dip stick and the front diff dip stick. good luck.
SVX bad solenoid C (transfer clutch solenoid) - drivable?
all 96 CARS ARE OBD2, SO YOURS SHOULD HAVE THE CONNECTOR. if like the legos, it should be under the dash above the gas pedal. a black, 6 pin connector with 3 or 4 pins in it.
1990 subaru legacy Wagon Overheating
johnceggleston replied to Trevo_B23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfans blowing cold air, not hot means..... the cooling system is low on coolant. it may be bad head gaskets, but i would bet on a simple cooling leak. either one could cause a loss of coolant and overheating. 1st, refill the system correctly, remove the vent plug, fill slowly, at rad cap, install vent plug, idle until the temp is normal, top off rad and then cap radiator. and drive it. 2nd, when / if it over heats, open the overflow bottle for the rad, and look for ''bubbles'' in the coolant. this would be a ''bad head gasket'' indicator. 3rd, when you come home after work, park and let the engine idle for a while. and place a large clean piece of cardboard under the engine. look for stains and drips . given the age of the car / coolant hoses, my first guess would be a slow leak.
1997 Outback AT OIL TEMP help appreciated
johnceggleston replied to mattsoft1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHOW MANY MILES ON THE CAR? the most common result of a duty c failure is torque bind, not no power to the rear. but no power could also happen, usually due to a ''stuck'' duty c valve. it is no longer metering the fluid pressure, it is stuck and there is no fluid pressure. in fact you could have 2 problems, no rear power and another electrical malfunction in the trans. but until you read the trouble codes you do not know what the problem is. there is a test to see if the transfer clutch is mechanically sound. there is a fuse you can insert to see if that will cure the AT Temp light. and as mentioned, if you trans fluid is not fresh, and pink and ''stink free'', it may all be caused by dirty fluid. so do some investigating and perhaps some service, 3 ATF drain and fills with driving in between, and let us know what you learn.
- 8 replies
- 1
- 1997
- Legacy
- Outback
- AT OIL TEMP
Tagged with:
Replace front tone ring 99 OBW
johnceggleston replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, separating the hub from the housing kills the bearing. so unless you ''piece together'' a tone ring on your existing hub assembly, you are going to be spending money. if the ''piece together fix does not work, i would buy a used assembly and install it. run it until it fails, could be a long time. but save the old one and prep it for reinstall, when the new ''used'' unit starts to fail. for $35 you can have one mailed to your door. www.car-part.com probably cheaper than a ''new'' tone ring.
johnceggleston replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXor, just replace the whole hub assembly. order it from www.car-part.com and have it shipped in from a NON-rust state. cheap and easy.
2000 Outback transmission issues
what year? hopefully not 04? it sounds like you are working in the right direction. good luck.
- 95 legacy needs more clearance
1996 Subaru Legacy L Sedan CEL (MIL on ) no codes
johnceggleston replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXswapping the bulb is pretty easy. you might could use another bulb in the instrument panel. which bulb are you willing to give up, ABS, SRS? SRS pops up WAY WAY less often. the knock sensor should be a non-issue., once replaced. what is the definition of the p0136 code? o2 sensor?
Swapping in a Ej22 phase2 or Ej25 SOHC into a 1999 Legacy Obw
johnceggleston replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe ej25 dohc intake will NOT bolt on to a phase 2 engine. it will not swap. try again.
98 OBW, power brake problem
johnceggleston replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe brakes in my 97 Gt wagoin are very different from the brakes in my (now sold) 95 L sedan. dramatically different. the 95 stopped quick and easy with less pressure. the 97 takes much more pressure and takes longer to stop. not very scientific , i know. i assume the wagon is heavier, but not 20% heavier, 10 to 15% at most would be my guess. how much of a difference can pads make?
