Everything posted by subiemech85
have a spare spfi pump in the trunk along with spare fuel fuel filter ATF coolant oil oil filter t-belts belts axles starter alternator waterpump lugnuts tools service manuals trucker's road atlas
1 small
FLANGE sealant? ANAEROBIC sealant?
How The Heck....
subiemech85 replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
ATTN: McBrat!! red brat -
it's not a gimick, it's rev-matching Rev said trashmobile "Rev 4:17PM (2/24/2009) Rice? I can't find a single thing in the included images that say "rice". The hoodscoop? Foglights? Venting??? Let me guess: you drive a white trashmobile or a secretary car... You'd be better off calling a mini or one of the ten thousand Mustang variations "rice"."
SEARCHED and only found dead links and invisible pictures :-\ if you are a source or have pictures, please provide found this one from Psyko, but would be better if more of the words can be read!
and welcome! I see you are also down by the river go easy on him, he is my brother, and I am slowly converting him from Ford and Nissan
Needin some advice...
subiemech85 replied to SubaruWagon87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
buy and drive the $100 special! after the turbo engine gives up, swap in the carb engine and fuel pump! -
where is the NORTH coast?? :-p
santa clause brought something to mick
subiemech85 replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://public.fotki.com/subiemech85/subaru/psbrat.html just got done photoshopping the brat used Qman brat for body, copied color from McBrat, changed wheels, painted topper, bar, body just dreaming for now somebody please buy my ski wagon!! http://www.ultimatesubaru.org/forum/showthread.php?t=93672 -
87 GL10 turbo, auto, lower turbo hose:help!
subiemech85 replied to KRMusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://subaru.sonik.us/ezboard/topics/19952.html -
? gear oil for COLD weather
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the difference is 4wd, as fwd clutch "must" be pushed in to crank I use clutch switch to cancel cruise!! -
have them rebuilt it's been posted before, search!
Help With Turbos 101...
subiemech85 replied to lostinthe202's topic in Non Soob Cars and Bikes Discussion
A/R here's the link for 102, 101 and 103 also available http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html -
ea81 camshaft removal
subiemech85 replied to backinbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
remove oil pump, bellhousing, back cover there are alignment marks -
$100 should snag it, and $100 for a turbo LSD!!
hicrappy carb. primary venturi STILL dripping
subiemech85 replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IT WILL IDLE after the ADS works!!! BTDT!!! ADS will default so that the idle passages are blocked off to prevent idling and dieseling you CAN defeat the ADS by removing the plunger when everything is working, it should be able to idle @ 400 rpm, SMOOTH, mine does if you want, I can post pics of the carb vac. line system I am using with good results -
remember TROGDOR! ..... "I pokes badgers with spoons" http://www.ultimatesubaru.org/forum/showthread.php?p=130787&highlight=badgers#post130787
Repacking pulley bearings
subiemech85 replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
luckily 20T press at home what is the part # for ea82 bearing? skf only lists the tensioner ITEM : VKM78001 ID : 0.35 OD : 2.36 WIDTH : 1.08 LENGTH : 1.57 WEIGHT : 0.45 -
ea82 decisions decisions
subiemech85 replied to Txakura's topic in Old Gen.: 80's GL/DL/XT/Loyales...
time to do an upgrade EA81!!!!!!! :bnana: swap in the ea81 in a weekend if you take it slow skip the jeep while the ea81 is in, rebuild, repair, replace...... the ea82
