Everything posted by subiemech85
Please educate me on EA82 wagons.
subiemech85 replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I only have experience with the '85 ea82 d/r it was the best combo for showing off in the parking lot, both forward and reverse and driving on the hiway :cool: when the traffic sped up or slowed down, I just shifted ranges -
Accident at Colorado Meet 1/22/04
subiemech85 replied to ShawnW's topic in Meet n' Greet. Your USMB Welcome Center
seems to me that you need a convertible conversion kit sure is good YOUR body did so well eyesore, empty your PM BOX -
Upsizing the oil filter possible?
subiemech85 replied to freedster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2870A is bigger, the one I used came from autozone, rubber texture, red -
83 dl weber carb what is ticking?
subiemech85 replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's your computer crap, you don't need it to run do yourself a favor and disconnect it below the steering column -
YOU SHOULD HAVE SEARCHED!!!! http://www.ultimatesubaru.org/forum/showthread.php?t=27068&highlight=COOLANT+HEATER BAR'S LEAK is one of the WORST things to add, shame on YOU!! If you would have removed the RADIATIOR WTIH THE FAN, the fan with the radiator would have fit back in after the coolant heater is installed, and this would have made the removal / installation easier an OVER-RATED IMPACT and a 8"extension and a cornwall 14mm worked nicely
no, no, no, no, that's all wrong, it is designed to go between 4wd and 2wd while moving without using the clutch, "shift on the fly" when you want to shift between 4wd hi and 4wd LOW, you MUST clutch, unless you are stopped and the engine is off TIP: if you can not shoft between 2wd and 4wd, becaue there is a horrible grinding syncromesh sound, and when in 2wd you hear a grinding and when in 4wd, the noise goes away, you may have blown a rear axle, btdt
in grass down hill in reverse, park brake set works
Brat's having another hissy fit! *Info added*
subiemech85 replied to Seahag1978's topic in Old Gen.: 80's GL/DL/XT/Loyales...
remove a side step, both rear shocks, and 1/2 of each rear wheelwel, and it should run like a champ! , and it will be willing to run and start easily even when it's in the teens for temp -
all can be done by SCREWING, NO PRESS
change the fuel filters, then check the oil, then allow to warm up thoroughly, then FLOOR IT for a MINUTE MINIMUM, sure does blow the crap out if it can't do 7,000 rpm, you've got problems -
EA82 Caliper questions
subiemech85 replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
consider it a chance to change the brake fluid, or use a hose pincher, or 2 coins and vice grips go for it !!!!! -
drill you need torque go to a place with "free air" and change the fitting to suit yours go to a place with "free air" and fill up your air tank try an electric impact get -
I once had a caliper that "would not move" I MADE IT MOVE!! take caliper off car, place in wood pallet use the "cube" 6" extension, and 1/2" dr air impact wrench in forward cw rotation this allowed me to press down firmly and turn at the same time worked great! -
ea81 guys, i gots a leak
subiemech85 replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
oil filter, crankshaft pulley seal, oil pump -
new to me 86 Brat... pics added
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
LAST I knew they are solid bumpers, no covers -
block heater install Q
subiemech85 replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What I did remove rad cap remove rad cock drain plug remove lower rad hose remove upper rad hose remove temp sender wire remove rad use 3/4" drive impact, air tool, the 1/2" did nothing use 14mm hex bit from cornwall tools, $8, it fits, snapon, $24, is too long make sure gasket is on heater install, 34mm? socket install and route cord enjoy if you have extra cord, loop it around the passing lamp BTDT -
Did I hear someone wants a brat?? see one pic here .. http://usmb.net/gallery/albuo65/a0019_15a?full=1 McBrat, keep quiet on this one -
grind to fit torque sounds good
is my tach working correctly?
1. go by what real idle speed is, and what "indicated" idle speed is 2. use a non contact optical tach 3. use a contact mechanical tach :cool: -
? for those with pyrometers
subiemech85 replied to stngllhm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds good to me I have noticed that when I am flogging it, crop circles, cruise at 5,000 rpm, the exhaust temp warms up and burns off all the accumulated oil -
stupid axle nuts...
subiemech85 replied to hooziewhatsit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
use a torque wrench, 150 ftlbs the cone washer and spring washer may be bad or in the wrong way -
I would call that a mild frist stage of bending I've got worse
check the fuses and look for the evil greenies while you're at it, check the grounds
