Everything posted by subiemech85
methanol in the fuel tank
subiemech85 replied to moshem74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
NO it doesn't do much good, and you need co-solvents use 10% ethanol blend, corn burner!! -
Low Fuel LED being a tad bit too sensitive?
subiemech85 replied to Phaedras's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and as a bonus, they usually work even if the guage doesn't do anything -
it's a "feature" we don't want our customers to run out of fuel needlesly, so we provide them with a light that comes on when there's about 1 1/2 -2 galons in the tank -
a better clutch cable!?
subiemech85 replied to shanonsf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and my left leg gets a workout with a horrid rrrrrrrrrrreeeaaaaaaaaaaaaaaaaaak it's the stupid 83 1/2+ system of holding the cable in place and to make matters worse, I have no idea if I am running a worn out ea82 pp and a 2wd ea82 clutch disk for the ea81 engine and ea82 d/r which slips at full throttle secondaries or hard starting no broken cables, yet, kow -
Rear E-Brake donor found. (U.S. model)
subiemech85 replied to CIS Subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
jsut be warned the pads are severly undersized for their origional application, expect to change pads yearly 87 200 sx se v6 , dad's dd -
one last snow fun run for the turbo brat.....
subiemech85 replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
BUMP!! just have to see how the brat does donuts hoping for 4" -
ea81 to ea82 axle swap question
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
2 git r houm the parts car has a good reman ea82 axle and I want to put it ntha ea81 to drive it home 300+miles it's one of those "MilesFox" type of adventure -
what does it take to swap a front ea82 axle in to a ea81? given spline count is the same is there a writeup somewhere? no search luck
ea82 dam thing acted as if it had a rev limiter after 6,000 when I wanted it to rev faster I have held it at redline rwd lo going up a muddy hill for minutes, no problem from engine
Who here has painted Peugeot rims??
subiemech85 replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
where did the wheels page go? -
attn chemistry geeks - need correct solvent
subiemech85 replied to thealleyboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
xylol , xylene -
what's the hose on the blower motor?
subiemech85 replied to teasdam's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yeah, that thing is to cool the motor did you get a lifetime warranty? you may need it -
or pull the ecm fuse install a "real" oil pressure, coolant temp, and boost/vac guage
mine enjoys the heated garage, cruising at 3,000 + rpm, using the secondarys shifting at 4,000 + rpm, and not using too low of a gear helps when it has the ea82 d/r 5spd, exhaust, intake and carb
install a real guage, and replace the sending unit
Attn: Colorado I submit for your approval
subiemech85 replied to Wasteland's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ugh! it doesn't say BRAT, and it's a dl, or an early gen 2 -
my wagon is back! MAJOR moldy pics inside
subiemech85 replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's the rust holes -
1.8L L4 2BBL ??<-- What is this?
subiemech85 replied to LuckyPistol's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's what you get when you are on a BAD parts website mpfi was available in 86 xt -
Help - Electrical Power Loss
subiemech85 replied to MSSLGECKO's topic in Old Gen.: 80's GL/DL/XT/Loyales...
was it just a spark, or was there welding involved, divots and burn marks? a spark takes about 5-15 amps communication is crucial -
I have tocuhed one in a jy I have driven one, tried to buy both still looking for a 91 5spd 4x4 turbo I could also take a 5spd 4x4 fi snow king
