Everything posted by 86ruguy
Let there be light
hey i just went to autozone around the corner and picked up 2 of the 24.99 off-road lights and a set of the rallyX (?) lights......i deliver papers and am in darkness all the time. the off -road lights come on with my high beams the way i have them wired. i run across a lot of deer also, the way the lights are aimed i can see for about 3/4 of a mile ahead of me at night. (my wife says if i'm really careful i could see seattle from our house with them on. ) pic of the front of my car...http://www.ultimatesubaru.org/photos/showphoto.php?photo=12755&cat=500&ppuser=18606 the top center light is no longer there
Newest member of my Subaru collection... PICS!
nice rig cab. dareon....life is one GIANT mountain range with pitfalls everywhere. it will work out and you will find the sooby of your dreams, just be patient.
cup holders
yeah the stereo might get a little sticky if you're not careful, but the liquid seems to splash out towards me instead of forward. i guess we'll see in the near future. also, i just flipped the stereo install kit upside down cause before i replaced my worn out shifter linkage, the shifter would go to far forward to let me put it under the stereo.
cup holders
here is what i did http://www.ultimatesubaru.org/photos/showphoto.php?photo=13239&cat=500&ppuser=18606 http://www.ultimatesubaru.org/photos/showphoto.php?photo=13238&cat=500&ppuser=18606
Check this problem out!
i'm glad you found your problem...however, the question i have is....you smoked all four tires with an EA82 motor? or is this an EJ-swapped ride? What clutch? Does the e-management help that much? just curious. cause i have trouble smokin all four in my EJ-swapped rig. might be cause of the 195/70 15's that i'm running tho. Dave
Could this be done to a loyale? (brat conversion)
you know....doing something like this is cool...but it doesn't help the rest of the world understand why we like soobs so much:grin:....good luck
Strut Swap in Progress...Need Help
fo those of us po' foke that can't afford air....make sure when you wedge open the pinch bolt slot you are doing so from the TOP not the side so as to not wedge your screwdriver into the strut and actually complicate things more. it took me about twenty minutes to get mine apart with the control arm and sway bar still connected.....after of course a good pen. oil soaking.
4wd or just 2wd ?
did you check the fuses....i could be wrong, but i thought there was a fuse for the PB 4WD.
yet another probem....
just a couple Q's....what year? What engine?...these will help us help you.
HELP!...car chugging at high speeds
check the plug wires....use some window cleaner and spray it on the wires, then run your fingers along them and you will probably get your self a little wake up jolt. next thing i would check is the cap and rotor. hope this helps. dave
has anybody seen this brat...
WOW!!!!!!! 470hp @ the wheels:slobber:
The true weight of a Loyale?
take a peek here http://www.ultimatesubaru.org/forum/showthread.php?t=65620
FT4WD / Locking Diff Question.
just went out and looked at mine....engaged is toward the front of the car
EJ22 power testimonials
i wish to add my 2 cents... i have an ej swapped 86 gl wagon that i also converted to full-time 4wd and just connected my front diff. lock... my car may not win any drag races but IT SURE IS F******IN FUN TO DRIVE. and it goes just about anywhere i want it to with out me begging it to...it just goes. as far as the 4 banger versus the V8 thing.....power con come in small packages to. Dave
Fog Lights
i agree on the location of switch...that is where mine is. also concur on relay use as your aux. lights are going to need more amps than the switch will handle. i have mine wired so that they get switched power from the parking light side of the HL switch, then run that to the switch for your aux. lights, then to No.85 on your relay. lights get battery hot all the time AT THE RELAY and then the relay turns them on when you turn on your park lights. wiring the relay: # 30...batt positive #87...lights (could also be 87 A) #85...switched power #86...ground good luck and happy no shorts. dave
87 Subaru GL-10: Injectors not firing
i'm not sure if you are aware of the fact that the ecu gets it's signal to fire the injectors from the same place the coil gets it's signal to fire the sparky bolts, but it does. it all runs off the distributor signal so i would check to see if the ignition is working properly before you go replacing the ecu. just my 2cents dave
T-wagon Stranded Me!!!!!!! Argggggghhhh!!!!
well the t-wagon stranded me this morning when she over heated. she's losing water but not leaking it so i figure she is drinking it. any suggestions would be helpful.
Internal/Recycled Air Button on EA-82/L-Series
SY....if your rig is an ea82 your a/c should have two(2) options on the a/c button. 1 light push turns on the a/c...push it again and it should go into max a/c which is RECIRCULATED AIR ( not recycled)
a few upgrades and pics...
nice rig man:headbang:
What gas Mileage do you get?
i have an EJ22 swapped 86 GL wagon, ft 4wd, 5 speed, no O2 sensor, and i can't keep my foot out of it and last check i was getting 26-27 around town.
3.7 LSD question
sounds to me as though the stub shaft has fallen out of the rear diff....right? in the exploded view, do they show the clip? you're probably going to need a new one
Hmm, one rear tire touches the wheel arch, the other one not...
my right rear coil spring is more worn out than the left because a third passenger always sits behind the passenger seat.
most powerfull Sube Engine?
they'd hold up that long?
Huge Kudo's
I would like to give a very BIG THAK YOU to Suberdave for all of the help he has given to me since i became a member of this board. Dave has been extremely helpful with all of the stuff that i have done to my ej swapped ea82 wagon and today he was there for me again. i will not bore you with the details but i have no doubt in my mind that Dave is one heck of an awesome person. i am not sure how else to put it other than..... THANKS DAVE!!!!!!!
I need Horn Help, 87 GL SW
i replaced my horns with HELLA hiway horns:slobber: and will never go back
