Everything posted by 86ruguy
TOD thread #245234521355
i agree, do the oil pump and belts and check the W/P while you're there, makes me sad that i didn't do it to the 89 we had a couple of months ago. we ended up scraping it:banghead:
Gen1 BRAT with WRX shifter!
that's sick dude:headbang: i want to put a wrx shifter in my ej swapped ea82 wagon:banana:
2.2L knocking sound (sound clip attached)
86ruguy replied to JPX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat's a pretty good sound byte, and from what i am hearing it sounds like piston slap(piston rocking back and forth in cylinder)
Found pic of EA82 stuck in big river.
those guys in iceland are pretty stupid if they coul;dn't figure out how not to get the second one stuck. i REALLY like the video clip though:headbang:
bad hesitation
well i've got the EJ 22 SWAP complete and now i am suffering from a really bad hesitation at light to 1/4 throttle......no lack of power beyond that. any hints would be kool. thanks, dave
subie plow?
i like the flame job on the hood:headbang:
Boss kit for leone
uh? what's a "lexicon".....LOL
my new engine
that's kool dude....i just got my ej swap running
It Runs!!!!!!!!!!!!!!!!!!!!!!!
GOT IT FIGURED OUT AND MY EJ22 RUNS LIKE ACHAMP:banana: :banana: :headbang:
EJ22 wiring woes(!!!!!!FIXED!!!!!!!)
well i finally got the EJ22 into my EA82 car and got no ground for the fuel pump relay:mad: . light green wire at relay to ecu is supposed to be ground. all ground wires were left in the harness and connected but not getting a fuel pump run and no spark either:mad: . worked on it til 1am and am very frustrated..:-\ ..any clues would be greatly appreciated. any info from factory manual would help i think thanks in advance:slobber: , dave figured out that i had the fuel pump wired wrong in the project car:banana: :banana: had the factory relay cutting fuel and the cam timing was off RUNS REALLY GOOD NOW:headbang: .....HAVEN'T HAD IT ON THE STREET YET BUT IT RUNS AND MOVES UNDER IT'S OWN POWER:banana:
Later motor for '87 GL Wagon?
it depends on what you want to get your self into. i am in the middle of putting an EJ22 into my 86 EA82 and it is not easy. you could just fix the one you have and all but i personnally was not happy with the power.
WCSS8 Registration Page
paid mine....i'll be there
BBS wheels! for OLD SCHOOL!
I WANT! I WANT ! I WANT!
1988 1.8L EFI $1000 college car backfires...need help!
im a little slow but the cam timing "THING" happened to me:banghead:took me 2 days to figure it out:-\ thankfully i have friends in low places
1996 Subaru Leone?
don't it just make you sick!!!
BRAT Paint for the ER27TT Advise
if you're going to do multi-color.....i would not use black and white....they are toooooo opposite. i like the blue but i agree on the rally stripe deal. and i also noted that it is an ej27tt? dont forget hood scoop for intecooler if it has one.
ea82 5spd d/r 4wd trannys and EJ22s?
if you are going to wheel with it you will probably want the d/r tranny....however, if it is in a street rig the EJ trannies are definately stronger. make sure if you do swap the trans that you swap the rear diff with it.
88 GL-10 WRX 1/4 mile time
jees dave, i wish i knew youy were actually racin last night i would have went.....good show for the first time with the car.
222,222 miles……
kool song:burnout: here's to many, many more miles:drunk:
The saga of brownie
yeah for old skool!!!!!!!!!!!!!!!!!!!
EA82T problems... i dont like these engines....
i would more likely suspect that it has a crack at the exhaust valve more than a blown turbo because the turbo SHOULD BE oil cooled not water cooled......thus it would blow blue smoke rather than white smoke ( or is it actually dumping liquid on the ground?) could also be a bad intake gasket. good luck. d
Took the wagon out for a quick run.
BE SPLASHY:headbang:
Any Older Soobie Converts Here?
i have not yet had the opportunity to drive any of the newer soobs, but am in the midst of an ej swap on my 86 wagon
Ignition Lock problem on my RX
you might also want to try putting some GRAPHITE POWDER in the lock assembly.
Next ORG rallycross event, May 7th
hope i get mine dun in time:confused: hope to see ya all there
