Numbchux
Everything posted by Numbchux
  1. welcome. you have a lot of research to do. all the information you seek is abundantly covered here. write-up and others here: http://www.numbchuxconversions.com/downloads.htm only thing I will comment on now, is that a body lift is definitely not necessary for an engine swap.
  2. well....he should drop it all in an EJ D/R case for that. but yea.....pretty sweet.
  3. a: did you make sure you have vacuum to them? double check the lines from the engine to the accumulator on the passenger side strut tower. b: don't mess with strings or anything. if you've got vacuum to the switch, and they don't switch, it is the switch. pull it out, and go to an auto parts store, and buy a vacuum "T" fitting. with some experimenting, you can have it always on Heat and Defrost. done!
  4. that is news. SWEET! that will simplify my project this week yea, looks like only 04-05. but my chart only goes to 05.... as long as the cut on the auto pinion gear is at the same angle....it should work. actually, that pinion shaft looks a lot closer to the MT version than I thought it did! cool! I'll be watching this closely.
  5. no I don't. I offer the service of stripping your harness. I will do this on any 2001 or older subaru harness for the same price, but you still have to provide a donor. do it right, grab your donor harness and stuff from a 2.5, and be done with it. or, if you plan on modding, and really want to get the most out of it. grab a standalone.
  6. not really news the only thing I don't think has been confirmed/denied, is if an EJ pinion shaft will work with an EA output shaft (hollow one). what year outback trans do you have? in all the decent gearing charts I could find, the only US cars to get 4.444s are the larger tire turbo cars (FXT, OBXT, Baja turbo). also, all EJ 5MTs have a viscous center. actually, all subaru center diffs have some sort of traction device, be it a locker or viscous LSD. anyway, a 1.6 with 4.444 would be pretty sweet. my toyota only has a 30.5:1 crawl ratio (auto), so you're getting close.
  7. ^hehe, I was just going to say, "Infinitely". a 2.5 would get you the 160ish hp you seek without any trouble. the biggest difference between the 2 is the torque curve. I used to wind my EA82s out to redline EVERY shift. and I'm sure an EA82t is the same way. I shift my Ejs at 4k or less all the time except on the track. as there just isn't any need for it. but yea, slap 5-6psi of boost at a 2.2, and you'll have much more power than your Ea82t. the ONLY challenge, is management. specifically ignition timing. the logic modules in the EJ ECUs are very good at adjusting fuel trims, but they won't pull timing. either way, if you're going to nit-pick the last 20hp or so between a 2.2 and your Ea82t. grab an OBD II engine. they put out better power. the ECUs are smarter still, much more responsive to mods.
  8. also. other way around. RX pinion gear is shorter than the legacy one. legacy output shaft and pinion gear: and assembled: extending the pinion to reach the locker is not going to be easy.
  9. yea, '95 is hard to predict. most are dual-port. but I have seen a few with single. but yea, all '96+ 2.2s had single port. I have never, ever, seen an exception.
  10. not easy for all of us. seriously. not guaranteed. and I wasn't exactly easy on my car. it wasn't wheeling....but many many many ice races, and autocrosses. not to mention delivering pizzas here in Duluth (hills.....frequently called the little san fran). it got some abuse. yea, good idea. if I had the parts/equipment for it. I certainly would do it. but I had neither. and it never became enough of a priority to fix it. actually...I got a couple videos of it with the hood off. I'll post them on youtube. you wouldn't believe how little the engine moves. done:
  11. this. I don't leave tbelt covers off or carry spare belts on my EJs, or my ER27. but I did on every EA82 I owned. because they fail, and you'll be changing them on the side of the road. and I 100% blame the tensioners.
  12. sometimes they can stick if there's some sort of force on it. sounds like yours is tougher than that, but try un-bolting the sway bar. sometimes that helps. which side is it? XT6? if it's a driver's side one, I've got one (the passenger side got bent in the accident). let me know...
  13. I'll be down for the holiday. I could bring mine with me Wednesday. or mail it to you monday (you'd get it tuesday) and pick it up on wednesday.
  14. Numbchux replied to Redcap's topic in Off Road
    the toe won't change. so if that's off now, it was off before and it won't settle out. if it's off....fix it. it's easily adjustable. larger tires definitely amplify the camber. since the tire is taller, but at the same angle, the top and bottom will be more noticeably not directly above one another.
  15. ^^dude. your 195/70s would be about an inch taller than 205/55s. he'd have quite a bit more room. I ran 225/55r16 VictoRacers (measured a healthy 26.5" tall, and as close as you can get to slicks and still be DOT legal) while autocrossing on my wagon. lowered about an inch, but with ~50% stiffer springs, and XT6 sway bars. with the right offset wheel....they'd work (which you won't find unless you go 5-lug). then again, my old '85 wagon hacked up a set of 205/60r15s (24.7") on pugs with the stock suspension from rubbing on the rear fenders. and I've seen 29" super swampers put on an older EA82 with the adjustable suspension cranked and a TON of cutting. long story short. it's different for just about every car. pug wheels have pretty crappy offset for a subaru, so the tires will NOT tuck up into the wheel wells at all. your best bet is to measure your tires, and your current clearance between tires and fender. decide how much cutting you're willing to do, and how much clearance you want to leave (I would leave at least 5-6" with the suspension un-weighted).
  16. Numbchux replied to Redcap's topic in Off Road
    we should sticky one of these threads (it might be in the FAQ...but apparently that's not good enough). yea. normal. they have a bunch of camber stock. there just isn't room in the strut tower to compensate for the extra control arm angle (pulls the bottom of the knuckle in). even if your lift blocks are installed correctly, your camber will get a bit worse than before. and it's going to look even worse when you get bigger tires on it.
  17. '85-'86 RXs were sedans with PT4WD. otherwise very similar to the FT4WD version. the taller final drive, smaller low range reduction, really short 5th gear and 25 spline axles. they're pretty different. and wasn't asking about 2WD cars. the FWD Ea82 5MT internals are the same as EA82 FWD internals. there are many differences in mounting and shift linkage.
  18. need more information. OBD II subaru covers 13 years, and many many different models/engines.
  19. heh heh.......DOH. I knew I'd forget something. I left the steering column in the car, but in an EA, you definitely have to un-bolt it from the dash and drop it to the floor. that does remind me, though. make sure that the ignition lock isn't engaged when you un-plug everything (make sure it's in park, and key stays off). or you'll have a heck of a time getting your key out! good call. I assumed it was non-turbo, as the only turbos to come with a D/R were the RXs.
  20. doing a clutch alone is FAAARRRR easier by pulling the motor. but only to avoid dropping the trans. since you have to drop the trans anyway....might as well leave the motor in it. the axles will definitely work. remove the torque converter by un-bolting the bolts that hold it to the flex plate through the access hole on the top of the motor (engine side). then drop the trans, and un-bolt the flex plate from the engine. remember to keep the flywheel bolts, as they're longer than the ones that go through the flex plate. aligning the clutch disc is an ENORMOUS pain from under the car (one of the reasons it's so much easier to pull the engine). a tip: forget the alignment tool, and aligning it at all. put the clutch together, and then just leave the pressure plate bolts finger tight (at most, I just thread them in a few rotations). now as you're installing the trans, the clutch disc can move around in there, and it makes it much simpler to get everything aligned. Then you can tighten them one at a time through the starter hole just like the flex plate bolts. just make sure to get to each one at least twice, to make sure they're all good and tight before you install the starter. Also, put a jack and chunk of wood under the oil pan to tilt the engine back (don't forget to un-bolt the pitch stopper...or you'll probably lift the car by the pan..... ). This will also help drastically in getting the 2 aligned properly. remember, the driveshaft is a different length from Auto to manual, so you'll need the front half (at least) of the driveshaft from the donor car. and, your rear diff is likely a 3.7, and the one in the D/R is a 3.9. so you'll have to swap that out too. I think that's it...
  21. nevermind. sorry. just was working on my EJ-swapped loyale a few days ago. I forgot the carbed ones are the other way around. the supply line is down on the frame rail.....you were on the right track. I put a '92 2.2 in an '86 EA82 carbed GL wagon last summer. zero mods. plugged in the fuel lines. I hooked the GL supply line to the impreza filter, and the return and vent lines are different sizes than each other.....but the same as the EA82. only change was fuel-injection clamps on all the supply lines, and the under-hood return lines.
  22. sounds like you've got your return and supply lines backwards. the supply line is up by the strut tower, and the return line is down on the frame rail. supply line has the fuel filter in-line. sizes are all the same, if connected correctly.
  23. the struts have to come pretty far out of the tower in order to leave enough room to get the block up there. the control arm will prevent that much travel, so something else has to be removed. I've been trying to remember how I did my '88....it was so many years ago. but I know on the EA81s we've done, we did the crossmember at the same time as well, so the entire front suspension was detached from the body. which made it a bit simpler
  24. yep, the leading rod will help drop the whole suspension down a bunch. but I'd definitely just pop the ball joint out of the knuckle (easier, and less chance of destroying the ball joint boot than pulling it out of the control arm). then you'll have tons of space to work with.
  25. even the 2.2 SOHC heads are good up to about 300hp (turbo, of course). I don't think there's much to be gained N/A for the switch. Also, keep in mind that the quench volume of a 2.5 head is larger than a 2.2 head. so using a 2.5 head on a 2.2 block will lower your compression ratio. definitely means a drop in power N/A. I love to see subie motors in VWs! I've done the wiring for more than a few of them, and if things go well will be very involved in another one this winter. But you really need to narrow your desires in order for anyone to help. Almost every combination you can dream of has been done and documented. read up, research parts, decide on a budget, a hp goal. you know the saying, "fast, cheap, reliable. pick 2", so find where your priorities lie in that triangle. THEN we might be able to point you in the right direction. generally, though. all EJ heads are pretty much interchangeable. you will run into a few issues if you try to put 1.8 heads on a 2.5 and vice versa, as the bore diameter is so drastically different....but even then, the bolts will line up. as a rule of thumb, intake manifold has to match the heads (not 100% true...but frequently). So when you talk about swapping heads onto your motor, you're really talking more about swapping your shortblock into another motor. at which point.....why not just start with a different motor? fuel injectors are dependent on the rails, which are dependent on the intake manifold. so if these need upgrading, consider those options as you're considering the rest of the build. head gaskets, again, are all pretty similar. there are a couple different thicknesses (effect compression/interference). some have different cooling holes in them, and different materials. but....very similar. probably only about 4 or 5 different OEM designs. management. depending on your power desires....you may want an engine management system. the stock ECU is surprisingly intelligent, but it has it's limits. specifically when it comes time to adjust your ignition timing. IMHO. if you already have an entire 2.2 donor car. and want more power than the 2.2 offers, turbo it. don't mess with the heads and stuff. just throw ~6psi of boost at it, and be done with it. the 2.2 is the most reliable subaru motor ever, why mess with it? or, if you're going to piece together a swap. start over. your N/A 2.2 parts car will have little use.
