Numbchux
    105
Everything posted by Numbchux
  1. I spin the front tires a lot when exiting corners under power on pavement (can't lock the center...). I'd definitely recommend the EJ one.
  2. correction there is no difference at the hub-end of NA v turbo EA82 axles. EA82 axles will not work without hefty modification on an EA81 car. also, EA81t axles are still 23 spline. there's probably a way to put 25-spline DOJ cups on EA81 axles.
  3. yes, because NASCAR is on the cutting edge of technology. look at real racing, F1, WRC, Le Mans, etc. etc. yea also, carb size/manifold design will be crucial. not to mention the fact that 2.2 heads on a 2.5 block will yield quite high compression (10.5:1, IIRC). so you'll need to be extremely accurate in your tuning, or you'll blow it to pieces. and, new headgaskets on a DOHC 2.5 fixes the problem all by itself.
  4. mine did that, then I went to the login link on the forum page. then I could login. although, I'm still not listed on the members list, and cannot edit my profile.
  5. excellent let me know if you need any yota drivetrain parts. I'm parting out an '86 IFS 4Runner right now. I'm keeping the engine, tie rods and front axles for sure. pretty much anything else is up for grabs.
  6. all EJ-series heads are interchangeable. your 2.5l heads are DOHC, the 2.2 would be SOHC. so they'll use a different intake mani, but if you're making a custom one..... the 2.2 heads will have a bit less quench volume, so higher compression on a 2.5 block...
  7. I haven't had any luck getting mine apart. the press plates I have are too thick to get between the gearsets/bearing. and I made a pair using some 3/16s steel, and just bent those.....
  8. you don't like all the sensors, but you're talking about wiring up the stock harness/ECU just to run the spark? you do realize that would require all the sensors anyway, right? I understand the concept that some people just prefer carbs. but you're talking about all the work, all the sensors, all the electrical stuff.....with none of the gains. or, you could try to rig some sort of standalone to run the ignition. but again, all the work, just run 4 more wires for the injectors and be done with it. or.....put 2.2 heads on it, and put a disty on it.
  9. they do become more prone to failure. BUT, when they fail, it makes it a pretty easy side-of-the-road job. could save you big $$$ in the cost of a tow truck. just keep extra pulleys/belts in the car, and you're set.
  10. I am...yep. I forgot the XT6 strut works with the legacy knuckle pretty easily....I suppose I'll just do that.
  11. just bustin your chops. I think it's an awesome idea, and would be happy to help!
  12. so, I'm in the process of buying an XT6. it's got working air suspension, and I'd like to keep it that way while it works. I would like to convert to EJ front knuckles/brakes. If I got my hands on a pair of working Legacy front air struts, would they work with the XT6 system?
  13. alright, so I had planned to be a bit secretive about this.....but it's going to be a rather long-term project (hope to have it up and running by next summer though), so screw it.... Few weeks ago, I bought this: a v4 Link LEM ECU. mmmmmmmmm........still need a few things before it'll be fully usable, but the bulk of it is here. And after studying the manual for it, I realized it's only designed to control a 2-wire Idle-air solenoid. and subarus are 3.....so I picked up this on ebay for $10. from a '90 Audi 200. 2 wire, and doesn't mount right to the intake. shouldn't be too hard to fab a flange to bolt to the subaru intake where the old IAC was, and plumb this in there. then, this showed up...... an Eaton M62 Supercharger from a '00 Mercedes C230. only has 25k miles on it. I took the intake and exhaust manifolds off it and polished them on the wire wheel on my bench grinder. now they're all shiny . I also re-mounted the high-pressure one 90* from where it was stock so it points more towards where the subaru tb is. you can see the line that I drew on it, where I plan to cut it off, and weld a plate over the hole to only use the one output. from the back: again, line drawn where I'll cut off the low-pressure manifold. a few measurements, and it looks like a 3.5" coupler will fit perfectly over that spot. then I noticed the little chunk of heater hose left over from the new water pump on the '96 imp motor I put in the '86 wagon. I used it to put the IAC valve right off the blower: ideally, you'd want it on the low-pressure side, but any time the valve is open, the blower will be off, so it shouldn't be a problem. Also, I've got a Jaycar voltage switch, that will be calibrated to engage the blower at ~75% throttle. plan is, to get my hands on a dual-port phase I EJ22e. partial rebuild (rings if necessary. but certainly headgaskets, all seals, timing belt, pumps, etc.). Leave it at stock N/A compression Delta Cams, possibly head work phenolic intake mani spacers t-leg intake manifold and injectors possibly parallel fuel rails keep my existing exhaust (mmmmmmmmmm) use this AWIC, plumbed between the blower and TB. should keep piping down (click image for more specs): another voltage switch controlled by an intake air temp sensor to control the water pump for said AWIC stock pulleys should yield 4-5 psi I'm also planning on mounting 3 LEDs on the dash. one for the supercharger clutch, one for the AWIC pump, and the third for the radiator fan. mounting system originally planned to be something like this: but then a different setup just appeared on rs25. so things might get switched around before then. also, there will be paint involved on the new engine. still trying to think of a color scheme.....
  14. just ran downstairs and checked....I definitely have that bearing, there seems to be a bit of play in it, but it spins real smooth, and it didn't make noise when pulled.... AND, the 5th synchro and driven gear are already pulled off the main shaft. I'll press the bearing off tomorrow and take a closer look. to make sure we're on the right page....this one, yes?
  15. been discussed. as mentioned, the crank angle sensor is the key. you'd have to find a way to mount the sensor from an EA82 disty to the EJ..... seriously. harness modification isn't that difficult. and one of the reasons the EJ motors are so powerful (not just in a hp way either...) is the electronics. surprisingly intelligent/adaptive ECU, electronic ignition, MPFI, etc.
  16. another vote for pulling the motor. it's definitely possible to do in the car, but the extra time to pull/replace the motor is decidedly less than the extra time to do the headgaskets while stooped over the fenders.
  17. ^The EA lines will plug right into the EJ pump. and yes, AFAIK the non turbo pump is the same (either way, I know the non-turbo pump will work...). also, what tranny bearing do you need? I've got a '93 n/a legacy tranny in pieces in the basement. worked fine when pulled, it's got some miles (like 180k, IIRC. which is why it didn't cost me anything, but seriously had nothing wrong with it). let me know what you need, and pm me your address, and I'll send it off to ya.
  18. according to the information I was able to find from various sources and compiles....they would work, but you'd need the newer upper spring perch: spring rates for the newer legacies were a bit harder to find....so the H6 ones might be stiffer...
  19. technicality yep, already working on the front, but since that design is very similar to EJ stuff, it's really not new territory. and yea, I was thinking about some subframe connectors to stiffen the length of the unibody.
  20. yea, it's been said that a strut tower brace on the front will drastically help with chassis flex, and therefore handling. I also have a pair of aluminum fender braces for an impreza that I intend to use on my wagon (when I get motivated enough to pull my fenders......don't hold your breath ) but I've been thinking about the rear. many wagon owners talk about how much a rear strut tower brace helps, and I've been looking at my car, trying to decide how best to do this....empty-handed of course. my only success was finding cool pictures of some custom braces....like this for a GC impreza, that still allows the use of the rear seat: then it occured to me.....the rear suspension is already very well tied together due to the trailing arm design. I don't think that turning forces really exert much force on the rear of the body (between the 2 sides anyway, I'm sure a full roll cage to tie the front to rear would help....but that's a whole different can of worms). am I making sense? thoughts?
  21. been done on many cars (I've never seen it for an old subaru....but the idea remains the same). cut a piece of plastic/carbon/wood/whatever the shape of the stock cluster, then use a hole saw to cut holes for aftermarket gauges. a few lights for indicators, and some paint and you're set. it's something I'm looking at doing in my next round of mods EDIT: a quick google image search for "custom gauge cluster" brought up these..... the hard thing, of course, will be the speedometer.....especially if you have a swapped car that needs the VSS signal
  22. and understandably so! I know how you feel. boy was it hard to watch my Chuxwagon leave, especially knowing that the guy that bought it crashed his last sooby into a fence post :-\
