15
Everything posted by bratman18
Forester struts are the same length as Outback struts. The springs may be a little stiffer which would add the slightest amount of lift, and you would want 03-08 rear Forester struts because the spring perch is higher allowing for bigger tires. But 98-08 Forester struts will bolt right into 95+ Legacy, just like the Outback struts will.
Yes, Strut assemblies off an Outback and the will bolt right on. It will give you around 3" more clearance, maybe a little more depending on tire size.
So now I have a Toyota (my first one too!)
bratman18 replied to obk25xt's topic in Non-Soob Off Roading
I have always loved that body style. Only ever seen 2 or 3 in person. any pre, mid 90 Toyota is rusted into the ground out here. -
Pics dude!
Sweet! That's a damn easy fix!
Yeah I have a cordless impact gun here as well. 475 lb/ft of torque! Makes things so much easier. And you know me, I already have all the parts! Lol
- 25 replies
The blowing smoke part is what worries me. I don't want to fry anything.
- 25 replies
- 1
Chris, if you do this, I may ask for a hand later on doing it to my Loyale. I'm not confident enough with wiring. My new EA car will already have an EJ alt.
- 25 replies
Loyale/EA82 strut components
bratman18 replied to bratman18's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I do know that. I have had many sets, in and out of a car. But I'm unsure if the strut boots, and the bump stops fit between the front and rear, or if there are different. -
Are the front and rear use the same size bump stops, and strut boots? Also, are 2wd and 4wd REAR strut bushings the same? I'm looking into buying new stuff to go with my new struts an springs, and I want to make sure I get the right stuff. Thanks for the help!
http://www.get-primitive.com/ And he is running 03-08 Forester struts. Fronts are the same 98-08, but the rears need to be 03-08 to clear bigger tires.
Subie L. Jackson build thread
bratman18 replied to subieman666's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm in Maine -
Wish I was closer, I'd trade you a legacy with everye for an ej swap. I want the 5lug swap stuff. -
BOSS 2" EA82 Lift Kits- $100!!!
bratman18 replied to The Beast I Drive's topic in Products for your Subaru
http://www.ultimatesubaru.org/forum/topic/136310-boss-1-crossmember-spacer-kit-for-boss-2-suspension-lifts/ -
I hear you about the weather! It's been holding me back here for a while now!
Oh, I'm not saying it won't last! I have just heard others stories. Looking forward to seeing this all put together!
It's been done a few times. Usually doesn't last long, but it'd be cool if it did!
Hmmm. It wouldn't let me. I will have to try again.
Lol, well it could be instantaneous, or could be a few weeks. Depends on the brand of axle, and how worn it is before you install the lift. My axles on my 2" lifted Forester, have survived pretty well. But the boots rip very quickly, which allows water and dirt to get into the joint, so that will cause early failure, especially when they are at more of angle due to the lift. But as a rule, it will be more often than you want to change them. If I were to go over 2", I would do a full lift. But I know many have gotten by with 2.5-3" and been ok. But I also drive mine every single day.
Or video on a site that doesn't require a expensive membership. I have no problem donating for sites, but not one I'm not going to frequent. But I'd love to see video/pics. I've always loved your rig.
It would actually be 98-02 Foresters that are the same. 03-08 are different. Although it does seem that the front struts are the same for all 98-08 Foresters and 97-99 Outbacks. 98-02 Foresters won't fit anything bigger than the 205 70 15 tire in the back, as was pointed out, but 03-08 Foresters will fit a 215 70 16. That's what I run on my 98. I installed 03-08 rear struts and was able to clear the bigger tires, with a 2" strut top lift. Been running it for over a year now with no issues.
