136
Should be seeing more like 180-200 psi compression. I'm inclined to think that's due to a cam timing problem. Can you remove the timing covers and take pictures of all the timing marks lined up? There should be 6 notches on the back edge of the crankshaft timing sprocket. Did any of those notches get broken off? If its missing one the engine will not start, or may start but will run very rough.
The catalyst monitor is running at the same time as the others. Basically as the monitor runs it ticks off a checklist of criteria that have to happen to ensure the cat system is operating properly. If any of those checks fails, it will set a code. It cannot set the monitor to Ready if there is a code present. I think the cars that new have a 100k mile spark plug change interval, but it never hurts to change them early. Spark plugs can make the difference between a 420 code and no code. Other things include a clogged air filter. Dirty MAF sensor (if equipped) A vacuum leak. Or split or loose hoses for the breather/PCV system.
It'll run too rich without a return. Don't block it off. If it's too rusty just cut it off and run injection hose from the top of the tank over to there. The two larger lines are supply and return. They run along side each other the whole way from the tank to the engine. A smaller hose next to those is the evap system vapor line.
Biggest problem is its just too new. There isn't much in the way of aftermarket sources for those. CAIs don't do any good. No chips. Though you could check with Cobb and see if they support that ECU for accessport reflash. Exhaust can be custom made at any exhaust shop. Header pipe and cats might be available somewhere but I'm not sure. You'll get about 10-15 extra hp for $2000. Buy an older Impreza WRX or Legacy GT or Forester XT and you'll have more options for upgrades.
Probably one of the inner axle joints getting ready to break. The one on the passenger side tends to fail more often since it sits above the catalytic converter and gets exposed to more heat. The boot splits and flings all the grease out then the inner parts get run dry and eventually wear out. Should be able to see it from above by looking down behind the air intake tube.
Rough idle and stalling issues are due to vacuum leaks and/or sensor issues or something that's relatively simple to fix. Turbo engines are going to consume oil, that's just the nature of their design, but an old PCV valve will increase consumption. How about a tune-up? 160k is decently high mileage for a turbo engine, but it's no death sentence. Most people here are gonna tell you to fix what ya got. Or you could be honest and just say you want MOAR POWAAAHHH!!! In which case, you can get a JDM drop-in 2.0 for about a grand. You could probably make the NA motor work, but the hassle isn't worth it. Takes like 2 days for a machine shop to machine and valve job a set of heads. You're gonna spend probably $300-500 per head to have that done. Plus gaskets, you're close to $3000 already. Throw in a $500 tune, bigger turbo $300-600, up/down pipes... Gonna spend 5 grand before you know it. Low mileage JDM 2.0 you can up the boost as is and get plenty more power and still have a reliable engine.
Plug the EGR hole with a bolt. Or just leave all the EGR stuff there for decoration. Block off the vacuum hoses because it won't work anyway.
- 6 replies
- 2
- engine swap
- automatice trans
(and 1 more)
Tagged with:
There are latches at the top of each fold down section that should have a small metal tab with a peice of cloth attached. Often the cloth is gone or the tabs are folded back where you can't see them. They fold toward the drivers side. Use a flat head screwdriver to reach into the crease and find the latch and pull the tabs out.
I took a look at the diagrams I have for 2002 model year (should be similar enough) and the only thing that stands out in the diagrams is a communication line between the ATCU and the ECU. I suspect there should be an identifier pin on the ECU that needs to be grounded, similar to the older model years, but the diagrams just aren't showing it. There are similar instances of unlabeled pins being used among other projects people have done, such as the Sport mode pin on the TCU in 95-98 model years. I think the thing you'll have to do is get a wire harness from a manual transmission car. There may also be the option to have the ECU flashed in order to disable those codes. This is something the performance crowd does fairly often when removing certain components from the turbo engines and/or when doing turbo swaps into non-turbo cars. I'm not sure of specifics as to what you need in order to do this. I imagine having it flashed by a performance shop would cost a few hundred $$.
If its fresh oil, that much oil runnin down from the timing cover area is going to be from a cam seal or the oil pump or front crank seal. Like LM said, need to get it cleaned up and watch where the oil is coming from. Pull the timing covers off so you can see the front seals.
Germans like to run high pressures. "More than enough" might mean "too much" in this case. I would put a gauge on it and make sure its sitting around 30-35 psi at idle. Should be around 40-45 with the regulator vacuum hose removed. If the fuel pressure is too high its going to spray in more fuel than is needed. If the pressure doesn't change with the vacuum hose removed, use some pliers to pinch the return hose and see if the pressure changes.
