Everything posted by GLCraig
Portland, OR. Radiator suppliers Name?
GLCraig replied to Indrid cold's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's probably these guys http://www.macsradiator.com/ -
Wrist pins blocked. Shifted cylinder liner?
GLCraig replied to Gloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most of the time when I've seen a spun cylinder sleeve, there's usually a crack in the block too. You're far better off finding a good short block and take the old one to the recyclers. -
Here the RallX schedule for the Pacific Rally Group. Most of their events take place out west of Olympia. http://www.nwr-scca.org/rallycross/index.htm
There was never a EA82 Turbo Brat. Only Brats with a Turbo were an EA81 and All EA81 Turbos came with the 3-Speed Automatic.
This is my 84 GL with 238K miles on it. I've owned it for over 9 years and I've put over 71k miles on it. Rally tire of choice is the Kumho Ecsta R700 165/80/13. This is my 94 Legacy GT. That's right is a Gen1 Legacy with a raised roof. It's been my daily driver for the 5 years that I've owned it and I've put over 65K miles on it in that time.
knock knock under moderate braking
GLCraig replied to SakoTGrimes's topic in Historic Subaru Forum: 50's thru 70's
Okay, you really need to adjust the shoes on the side with the new drum. Subaru did not start using automatic adjusting drum brakes until the Gen3s came out, so the shoes are currently set for the old drum. You might as well adjust the opposite side while you are at it. At worse this will make your Subaru safer to drive but it may even resolve the noise issue. There are several posts about how to adjust them so just do a search. -
The damage to the drum was probably caused by the previous owner. The splines will take a fair amount of abuse before they let go. When I was working at a local Subaru shop, I saw 1 or 2 cases of this a year and when we would ask the customer if they played around in 4wd on dry pavement; the usual answer was yes. -
The Drum has a set of splines that the axle goes through; similar to the front hub. The splines will strip out if someone consistently drives in 4wd on dry pavement. Make sure the Castle nut did not loosen up. Did you properly adjust the brake shoes after replacing the drum? Now that you have a good drum, perhaps other problems are coming out of the woodwork. Check the U-joints of the drive line to see if they are wearing out. -
First Rallycross of the season for the NW
GLCraig replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Is the event schedule out yet? -
3EAT vacuum doohickey ????
GLCraig replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IIRC it's a vent hose for the front diff -
Rally X meeting on March 3rd at 7pm. Location: Pied Piper Pizza in Vancouver WA
I got a set from a dealer about 2 years ago but I don't remember the part number of the price.
The secondary airbleed maybe a little plugged up. Hitting it with a little compressed air seems to cure those types of problems for me.
okay here's another Vid. http://home.comcast.net/~c.moe/rally.mov
The ECU is in the trunk on XTs
I was going to post another VID but I ran out of webspace......
I still RallyX my 84 wagon. Here's a little video Edrach took at one of the events. Please don't laugh at the mistake I made. Http://home.comcast.net/~c.moe/rally.mov
EA81 tranny matchin up to EA82 Engine
GLCraig replied to Subaru_Mechanic's topic in Subaru Retrofitting
All EA81 engines used the side mount starter, even the one in an 81 Brat. -
Arizona emmisions laws and DMV crap
GLCraig replied to SakoTGrimes's topic in Meet n' Greet. Your USMB Welcome Center
Get an Oregon trip permit for the brat when you head off to Arizona; then you should be able to licence it there. Contact the Arizona DMV before you move and find out what paper work you need to file when you go to licence it. -
Here's a pic from WCSS#5. It's a pic of the underside Lumpycam's HatchBrat with a T-Case mod. http://www.ultimatesubaru.org/photos/showphoto.php?photo=13819&size=big&cat=500
