Everything posted by GLCraig
I think the EG33 is just too long, if you compair the engine compartment of the XT vs XT6 you'll see how subaru had to modify the core support and few other items just the make the ER27 fit. If you really want a H6 you may want to look at the EZ30, it's not that much bigger then a EJ25.
I signed up for a subscription at WCSS7 but I have not received a copy yet, do I need to start calling them and start saying "where my mag"
All the warning lights---
GLCraig replied to pyromanic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The lights will also come on if the ground wire for the instrument cluster comes loose. You may want to check that. -
Labor Day weekend camp out and 4X fun anyone?
GLCraig replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Hey Zap, will it be worth the 5 hour drive? -
tow with 2.2???
GLCraig replied to attym's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Most Legacy trailer hitches are bolt on, mine uses the rear tow hooks and 2 holes in the unibody as bolt down points. -
Oh hearing stories like that makes me glad that the testing in Oregon is ran by the State's DEQ and they were smart enough to exclude all Subarus from a at speed test. Speaking of emission tests, my GL is due again at the begining of the year. Let's see if it will pass for the 4th time in a row on the 1st try.
Will an EA81 raditor fit an EA82 ?
GLCraig replied to paulb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You would need to do some modifications to make it fit -
Some pictures wouldn't hurt.
Saw what looked like a RX, but said RS on it
GLCraig replied to tizzle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've seen one that was MPFI -
Next ORG RallyCross..Aug. 14th..Hillsboro, OR
GLCraig replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Hey they expect the weather to be hot this weekend. Please come prepaired. -
Can you still get a O.E. filter?
GLCraig replied to Subieguy's topic in Historic Subaru Forum: 50's thru 70's
the dealer will sell you the same filter as they do for Gen2 and Gen3, I don't have th recept handy or I would give you the part number -
Proportioning valve changes on rear disc swap?
GLCraig replied to freedster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You know I've looked at my FSM several time, trying to locate a proportioning valve and I just can't find one. Maybe subaru didn't use a proportioning valve. Also if they did, wouldn't they need two since the brake circuit split is Front Left/Right rear and Right Front/Left Rear? -
you know Gen2s & Gen3s may use the same interlock switch since the 3speed auto is basically the same for all three gens.
Strandead Please Help!!!!
GLCraig replied to CITRUSHARK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You know the ECU may not fire off the injector if the MAF is telling the the ECU that there is not any air going through it. Since you did the test with the air intake disconnected between the MAF and throttle body, there wouldn't be any air going through the MAF to begin with. Also have you check both Timing belts? If the one on the Drivers side is busted, the distributor will not turn and you won't get any spark. -
stupid distibutor cap
GLCraig replied to subarunewbie2005's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The fireing order is 1324. -
Wierd EA81 starter problem.
GLCraig replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try a different battery cable. -
I think you have Zap and Qman Mixed up
Your problem maybe from overtightening the 2 bolts. The Torque spec it 3 to 4 Nm (Newton Meters). Also the quality of the gasket maybe an issue. I know you said the head's surface felt clean but you realy need to give it a good visual inspection, any only and hardened cork may cause problems.
FYI Brooklyn is just the name of the unincorperated area around the tavern and Cosmopolis is just for US Postal service addresses.
