Everything posted by GLCraig
Water pump life?
GLCraig replied to Martinjmpr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe water pump will eventually fail at some point. What your mechanic is trying to do is save you some money in the long run. Since the pump is driven by the T-belt you will need to go through all of the labor again and depending on the type of pump failure, the t-belt maybe damage or broken too.
Low power in 4WD
which 4wd system do you have? If you have a single range 5-speed, you could have a vacuum leak between the solenoid and the diaphragm.
Wicked exhaust leak aftermarket parts
GLCraig replied to NoahDL88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAdding a second gasket might help.
Genuine Subaru parts?
GLCraig replied to indianaoutback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere a link to start looking at http://www.ultimatesubaru.org/forum/showthread.php?t=47914
WCSS8 Where will it be?
Maybe my phrasing wasn't the best. I need to turn in the paper work before June.
dirtiest suby job ever
I scrapped all of the dried on mud from the underside, after a season of rallycross.
piston pin puller questions
I got mine on Ebay but you don't need the Subaru tool. There are a few other methods of extraction. You can find a longer bolt and grind the head down so it fits down the bore of the pin and hooks the back side; attach the other end to a slide hammer. I think someone here, instead of using a slide hammer they attached a washer and nut to the other end and pulled them out with a claw hammer. There might be a expanding mandrel type tool out there too.
Broken ignition switch
It may take to work to get to them, but there are 2 or 3 screws that hold the electric portion of the switch to the lock. Take them and the switch out and use a screwdriver to turn the switch; Or Maybe the switch fell out somehow.
99 Legacy 2.2 Replacement
GLCraig replied to TROGDOR!'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bellhousing is a part of the block casting on EJ engines. When they switched to an 8 bolt bellhousing they just added 4 holes. A transmission from with a 4 bolt will mate up.
Gen 1 Auto trans question
Well if this helps, the only Gen1 auto I ever scrapped out was from a 78. Execpt for the bellhousing, I could not tell a difference between it and a Gen2 2wd Auto.
Refresh my Memory
Do the rist pin plugs use a 12mm or 14mm Allen wrench?
Where isn't the issue with me. I'm more concerned with the date that show date and location is finalized. I have not use my vacation week for 2005 yet and I must have it scheduled before June of 2006 or I loose it.
'87 1.8 Turbo Head Gasket Replacement
You can get either head out without pulling the engine.
Retrofitting stiffer struts to EA81
I know you can still get KYB GR2s for EA81 4wd but you would need to check their catalog to see if there are 2wd (which are shorter) struts available.
EA 71 thermostat question
Try checking out some of the OEM parts websites. I have a funny feeling a you'll get the same part number for all EAXX thermostats.
distributor technicality
What you really need to do is get it inserted as close as you can. Then once you have it running and warmed-up you need to use a timing light to get it set to 8 degrees BTC.
pilot bearing?????
Take off the flywheel and tap it out with a hammer and socket.
Clutch Compatability for EA81 4SPD D/R
The input shaft of an EA81 D/R 4-speed is smaller then the input shaft for EA82/ER27 4wd transmission. You may have to use a clutch disk from EA82T 2wd Transmission but I'm not positive if that disk is compatible with a XT6 pressure plate.
Fuel Pump Question EA81
On an 81 the fuel pump and filter should be in the engine compartment near the left strut tower; unless the fuel pump relocation kit was installed. If that kit was installed, it's hard tellin' where the pump.
86 hatchback, timing
You adjust the distributor,
troubleshooting engine installation
Have you verified that you are getting spark?
The annual Hatch Patrol Christmas tree run
Looks like i'll make it, I just made reservation in Enumclaw for Friday night.
16" Steelies for '03 Legacy GT?
GLCraig replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt depends on how much you want to pay. I've been at the parts counter at my local dealer while another customer was buying some 16" take-off wheels but they were not real cheap. You could checkout the local used parts houses or the wrecking yards for some.
Problems with emissions
It would help a lot if you could post your emission test results, so we could give better advice.
Knock sensors only on EA82T's???
Only EA82s with a knock sensor were the Turbos. Also the knock sensor is different between early and late style.
