Everything posted by GLCraig
On EA81 models it's just a flat washer that's being used as a thrust bearing. It sounds like whoever did the work didn't grease it very well.
Stripped a front hub! Why?
GLCraig replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you been spending too much time in 4wd on the pavement? -
EJ22T HLA noise
GLCraig replied to XSNRG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Okay I finally got a hold of him, basically what you need to do is take out the rocker assembly and flush out every nook, cranny and oil passage with solvent. Since the replacement HLAs were quiet to begin with and then began to make noise, it dose sound like there is a problem of getting oil to the HLAs. -
EJ22T HLA noise
Let me call my bud who's a subaru tech tonight and get back to you. -
RX Disty: Hitachi or Nipodenson?
GLCraig replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
IIRC EA82Ts that do not have the crankangle sensor type distributor are Hitachi. If it's possible go back with the Cap & Rotor for your RX in hand. You would have to be blind to mistake the Hitachi cap for the Nipodenso cap. -
Who is this guy? Is he on the board?
GLCraig replied to kingwill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A gen1 grill would be 1 piece, grill & headlight bezel. That looks like a EA81 single round headlight grill. -
NV To WCSS Caravan Thread...
GLCraig replied to NV Zeno's topic in Meet n' Greet. Your USMB Welcome Center
Hey guys, if you are planning to go from Klamath Falls to Portland, the fastest way is to go North on 97 then West on 58 over to Eugene. I went college in KFalls and my parents live in the Portland area, so I made that trip several times. The other two routes take about another hour of driving. If you guys don't mind taking some extra time, then I would recromend going North on 97 then go NW on 62 and around Crater Lake then West on 138 to Roseburg. -
EJ22T HLA noise
Before you start swapping HLAs you may want to check the rocker assemblies for clogged oil passages. The guys at my old shop have found that to be a common cause of HLA noise, due to a like of oil pressure to the HLAs. -
What is this box next to my radio?
GLCraig replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's the Door chime -
Have you tried cleaning out the EGR tube and is the EGR valve working correctly? Also, what temperature thermostat do you have and about where on the gage is the needle staying when the engine is warmed-up?
I remember parting out a 75 4wd wagon when I work at a Subaru shop about 8 years ago.
Clutch glitch in EJ22 swap - HELP!
GLCraig replied to cracked head's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You know a 2wd EA82T clutch disk may work for this. There were some 2wd XT6s too but I think they had the bigger imput shaft like a 2wd Legacy or Impreza. -
Let me guess, your XT is 2wd? -
it's more like an inch and a half. I've got an engine from a 97 in my 94 legacy wagon, using a 97 y-pipe and it pushed the mid pipe and muffler back. I didn't really notice this until I installed a trailer hitch. Now the muffler will rub the hitch. I few months back I got a midpipe from a 98 legacy for free and I hoped that this would cure that problem but it didn't, it's the same length as the 94 midpipe but the 98 pipe dosen't have a cat. I installed it anyway because the combination of a 97 Y-pipe and a 94 midpipe has a total of 3 cats. This was great for passing the emissions test but it suck for everything else.
Craig's Subaru Wrenching tip #37
GLCraig replied to GLCraig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A good hardware store should have some but they maybe hidden. I had to ask the clerk at the local Ace hardware where he hid them. Counter clockwise -
Own atleast 1 CCW drill bit.
