Everything posted by GLCraig
Don't get your hopes up, they work basically the same as a EA82 SPFI distributor, so you'll still need a computer.
The SPFI manifold will not fit an EA71 engine
I would not do either. The roughness in the oil and coolant passageways helps to create turbulent fluid flow which is better for convection heat transfer.
Q for portland people--> car loans
GLCraig replied to subaru_styles's topic in Meet n' Greet. Your USMB Welcome Center
Basically that's how it was when I got the loan for my Legacy. The only stumbling block was that my legacy is a bit rare and not listed directly in the Kelley blue book or the NADA book, so I had to provide them a VIN number to do the search. -
My Wagon died from heat exhaustion,... WHY
GLCraig replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It could have been a case of vapor lock, but that's just a guess. -
rguyver has done the conversion. I've talked to him some about it and your theory is about right. The distributor needs some more mods then just the gear but it just a cutting wheel and die grinder work. here's a pic of his setup http://groups.msn.com/RguyversSubarus/mesageboardpics.msnw?action=ShowPhoto&PhotoID=65
Well to get a loan from a credit union, you need to be a member of that credit union. Are you a member of one already? Anyway I got a letter from mine, Clackamas Community, offering 2.99% APR on a 24 month loan. -
Typicaly it's recromended to change it every 3 months or 3000 miles or in your case 4828Km.
pics are up fromthe Sea-MSP trip!
GLCraig replied to Ratty2Austin's topic in Meet n' Greet. Your USMB Welcome Center
#10 is kinda interesting -
ignition problem need help ASAP
GLCraig replied to stngllhm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Getting power at the coil? -
They very by year of Subaru
you mean like the white hatch shown in this 87 sales brochure? http://www.ultimatesubaru.org/Literature/brochures/1987-j.jpg Yeah I've seen a few different EA81s with the single round headlights. They were more common in 80 and 81. The swap can be done, if you have the single rectangular headlights. You just need to swap the buckets if I remember right and the grill pieces. If you have the dual rectangular headlights, it's a different story. You would need to swap the core support or modify the existing one to accept the headlight buckets.
71 to 73 if I remember right
They don't mind too much if you're out on the gravel lot behind Corrnet Hall
a hatchback will need a custom driveline made since it has a shorter wheelbase.
1988 gl-10 awd will not turn rear wheels
GLCraig replied to cstrohschein's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Which transmission is in it? In 88 the only transmission that automatically engage the rear wheels is the 4-speed automatic know as the 4EAT, and that's if it was available that year. I can't remember if they came out in 88, 89 or 90. If you have the full time 4wd 5-speed, it has an open center diff and you need to lock it to maintain an even distribution of power to the front and rear. The switch to lock the diff is on the center counsel. If you have either a 4wd 5-speed or 3-speed automatic there is a button on the shifter that you need to press to engage the 4wd. Some GL10 only came with 2wd, are you sure that you have running gear in the back? -
13 year old brake shoes!!AARRGGHH
GLCraig replied to jefvos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well here's a handy hint for the next time you do your drums. On 4wd EA82 models there is a rubber plug that you can take out to access the release mechinism for the automatic adjuster. Just pull the plug and stick a screwdriver in the right spot and you should be all freed up. -
The car Subaru never built... but should have.
GLCraig replied to All_talk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
He's probably talking about the DOHC EJ22 turbo that's found in the Impreza 22B. -
83-84 Clutch with 82 BRAT (UPDATE!)
GLCraig replied to Flowmastered87GL's topic in Subaru Retrofitting
You know the one thing that bugs me about this is that about 9 years ago now a buddy of mine and I transplanted an 82 D/R tranny into his 84 hatch. We used a SOA 84 4wd clutch kit and a new throw out bearing holder. everything went in fine and it still goes up and down the road without any problems.
