153
You’re going to have to trick the ECU to think that the auto is still there I reckon. I know this works on earlier models but really don’t know with the later stuff. Why didn’t you just swap for a manual vehicle? Cheers Bennie
Because what you’re asking just isn’t done commercially!! The only bolt on option is to go for a set of coil overs, but unless you want racer-boy-hug-the-road-“fun” then you’re flat out of options other than to go buy a “truck”. So basically, like everyone said previously, it’s buy all the parts and build it yourself (DIY) or buy all the parts and go to a suspension shop to have them put together and you can decide whether you fit them or they do. Youll want a 4 wheel alignment after all this work is done. Have a nice day, Cheers Bennie
You’re clearly keen on the swap so you’ll have to take measurements and work it out for yourself. I bet my $2 on the dashboard being longer than the impreza one. So you’d have to look into cutting the legacy unit down to fit, then make it all look pretty. If you’re only after the instrument cluster it might swap over with wiring repinning of some plugs. Door cards. Measure, work it out. My gut says different. Cheers Bennie
EA-81 Fuel injected engine
el_freddo replied to wain lee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Why not get funky and run the EA82 MPFI system with those heads? The only real mod needed is to the dizzy and that’s well documented. Then it’s the wiring loom. But yes, you could run the carb on the efi heads with injectors as plug. Cheers Bennie -
EJ22 swap with UEL headers?
el_freddo replied to ClassySoob's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Use the stock EJ mid pipe section that those equal length Y pipes use, then go custom from there. Ruby Scoo above runs the gen 1 Y pipe with a welded on cat back exhaust that’s custom for the L series, lift and EJ. Using the factory EA exhasut with an EJ should only be a stop gap as it’s very restricting. Cheers Bennie -
Sounds like a dead crank angle sensor in the dizzy to me - ECU doesn’t know when to hit spark and doesn’t know when to fire injector. That said, I’m not sure that the SPFI ECU signals the dizzy to fire since it’s still in the mechanical spark mechanism era. Have you checked for codes yet? Cheers Bennie
Somewhat New Subaru Owner, 2002 Forester
el_freddo replied to TanStin's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the forum! Interesting ideas and project goals you have there! I’ll be keen to read where you go with this. Boosted EJ in a mini sounds.. er.. different! Cheers Bennie -
I’ve got the factory Y pipe from the Gen1 EJ22 on my L, so there’s no issue with the factory bash plate. UELs in the style of the turbo exhaust manifold (with the pipe crossing under the front of the engine but usually reversed to the turbo setup) can be made to have little to no change to the bash plate. The trick is to keep it up high and possible make a heat shield for the cam covers. To make a decent note you’ll need mufflers that don’t muffle the sound so well - straight through mufflers seem to do this well. A decent exhaust shop should sort this out no issue. This is my setup from 9 years ago. It’s still running now without any issues even though I’ve scraped it, rocked on it and flooded it with water... you can hear the exhaust in this video once it changes to the outside camera: That said, the aftermarket UEL sound is sweet. We did some DIY ones for my sister’s Gen3 RX. The other day as it pulled into our driveway I was waiting to check out the WRX that I thought was about to drive past! It’s got a cat back “sports exhaust” from the previous owner, the UELs make it Subaru spec now. No video of that I’m sorry. Pic of the build process: and the final product - I forgot to get a pic of it fitted: with this setup we can return it to stock if need be as we’ve not modified any points where joints occur in the exhaust, really though, why would you go back to stock?? Cheers Bennie -
AUDM doesn’t get half of the JDM goodies that are actually on offer. NZ gets many of them shipped over as second hand vehicles from what I understand. I also don’t know how the Siamese exhaust ports help with emissions, I thought they’d drop the required emissions and that’s why they got rid of them! This could be a long shot - any models or parts made in the US - or is everything built in Japan and shipped stateside? Cheers Bennie
New to me 1990 Loyale
el_freddo replied to IFlyS5's topic in Meet n' Greet. Your USMB Welcome Center
And we all know what resolves this issue... Cheers Bennie -
The hard start and rough idle could be too much fuel. I suspect you’re using the injectors from the EJ25, on start up a rich fuel mixture is used to help aid starting. This extra shot combined with the smaller engine capacity could cause an over fuelling situation which wouldn’t be great when starting. As for the codes, if the temp sensor was dropped or knocked when swapped with the coolant crossover pipe it could’ve died, especially if it was already hanging in there by a thread so to speak. The other codes, best of luck with those I’m sorry. Sometimes you might get lucky and have one code sorted and the rest follow suit... it doesn’t always happen, but it can at times. Cheers Bennie
And a lack of need for more speed/power! Cheers Bennie -
As for the air compressor, you might find one in an early legacy that has air suspension, even if it has coil springs - many ppl don’t remove the compressor. And I believe it’s the same unit between the L and the Legacy, maybe with a different mounting plate. It’s in the same location too - front left guard Thinking about it, your air system probably has leaks that lead to the air compressor burning out due to being overworked/worked too long too often. Cheers Bennie
