153
Rear wheel bearings ring nut tool
el_freddo replied to alexbuoy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I made my own tool and it utilises all four slots in that nut device. I use a large adjustable shifter on it without any issues. Thereare pics of it floating around the interwebs. Too hard basket to find one on my phone atm. Cheers Bennie -
You'll love the painted guards - so easy to clean out and they look schmick when they're clean too! Will you be doing the rest of the underside of the vehicle? Keep up the good work! Cheers Bennie
Ummm... So why isn't his insurance covering the damage to your vehicle? He was the one at fault - and the service station should have CCTV footage you could sepena (spelling?). I wouldn't live with it and I'd be chasing down that driver if possible. At the time you should've got all their details and have them contact their insurance company to put in a claim. All the best with it. Bennie
EA82T Jap Spider Conversion. Help please.
el_freddo replied to Ausbert's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Intercooler can easily be setup. You should be able to use any standard EJ setup intercooler. As for your other questions, this might be of value: https://ausubaru.com.au/viewtopic.php?f=22&t=11047 Cheers Bennie -
I wasn’t saying there was anything sketchy about the wiring. Just that wiring should be tidy and protected. It doesn’t matter how well it works, if it’s not protected over time with vibration wiring damage and be caused and worst of all either a harness failure (engine no worky) or an electrical fire. Over here corrugations will kill a harness in not time if not properly protected. Plus wiring in black automotive conduit or spiral wrap looks mint over seeing every wire in the bunch (or worse still, not bunched together at all). Thats what I was getting at. And it sounds like there was a lot of effort put into this car. Kind of sounds like you would like to buy it back FerGloyale! Cheers Bennie
*Giles gets on the next plane to the US* Cheers Bennie
That airbox says it’s a Gen2 (legacy, the Impreza may have got this airbox straight up since they came in a bit later). Looking at the shape of the intake I’d agree with it being an EJ18 - they all seem to have a much more pronounced “wave” in the intake runners from the pendulum box to the head than that of the EJ22. And it’s time to wrap up that wiring in some sort of automotive conduit Other than that, enjoy the ride, an EJ’d L series or MY is WAY better than a stock unit! Cheers Bennie
EA81 Throttle body FI fuel pump issues.
el_freddo replied to 84GLFWD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I’ve never seen a fuel pump spring a leak - unless it’s a mechanical one off the side of the engine from back in the day, and even that was rare! Got any pics of it leaking? I’d reckon the issue would be more to do with the EFI fuel hose leaking due to age. I’ve had that before. Cheers Bennie -
Sparkyboy, the compressor for air suspension should be under the front LHS guard/fender, between the wheel and the front bumper. Talk about using all nooks and crannys!! I hope for Giles that it’s still there. And Giles, I wouldn’t say the vortex was hugely popular over here. I think many of them stayed in the 80s after the initial excitement died off. In saying that I saw my second ever XT4 in ten or more years. That was on my street/road about six weeks ago. I couldn’t believe it and wished I could’ve followed them for a bit... Anyway, I digress! Cheers Bennie
A back up plan would be a second harness Don’t take what GD says to heart. He plays with the new stuff and seems to have little time for others starting to play with the older stuff... and seriously GD? More fun LS swapping an f150?? Where’s the Subi in that equation??! It’s not even part of the initial question!!!! Argh!! Do your research, learn along the way and take your time with the wiring cut down job. If you get a donor vehicle, pull the wiring, do the cut down then test run the wiring on the engine while it’s still in the vehicle. Once that checks out without any check engine lights etc, then proceed with the engine removal and the rest of the conversion. Cheers Bennie
Welcome to the forum Giles! Long time no hear (I’m not on bookface)! I hope you find your answer, I’d want to do the same too Cheers Bennie
Cyclops 3rd Eye Install!
el_freddo replied to divinicus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just be aware that you *might* need to also replace/modify the front panel that the headlights mount to. Modifying the original grille with the quad lights would be way easier. Someone will know more about this mod... Cheers Benie- 51 replies
- 1
- brat
- cyclops brat wiring
(and 1 more)
Tagged with:
Even so, I’ve been blinded plenty of times with LED bar weilding vehicle’s that just don’t see the oncoming vehicle with dipped headlights... or sometimes with high beams on (enter high beam wars - where I think they work out their lights are still on high beam). Cheers Bennie
Short answer... No. Even moreso if you know nothing of spinning spanners or reading/following wiring diagrams. Either the EJ NAs or the turbo engines will require a wiring loom cut down and an adaptor plate. Go the turbo route and you’ll have to notch the engine crossmember (or find an EA turbo crossmember) and think about gearbox upgrade thoughts too. Once you’ve done one it’s pretty easy Cheers Bennie
Down with LED and HIDs! Halogen all the way for me. And what’s with the 55w globes? I’ve got 130w globes in my driving lights. You don’t need much more than this in three or four lights! Added that the “cool white” light is more like a blue light, it’s a very unstable light wave and thus is why they look so glary to oncoming drivers - but also look good to the driver as a driving light, they’re not getting all the thrown light back to them. Cheers Bennie
hello from Latvia
el_freddo replied to rex_saugerty's topic in Meet n' Greet. Your USMB Welcome Center
Ah one of the elusive fin tailed brumby/brats! You’re probably the only one here with this extended tray brumby/brat/MV! But definitely not the only one here with a brumby/brat/MV Loads of info for anything you need to know Cheers Bennie -
Only thing I do after scraping off the old gasket is to wipe the mating surfaces with a white spirit like mentholated spirits. Then gasket on and bolt up to required torq specs. Cheers Bennie
Knock the two roll (or cotter) pins out. Use the correct sized punch as the inner pin passes through a hollow section in the diff stub. Get this wrong and you’ll be in a whole world of hurt. I’ve been there, done that. Get the inner CV cup moving on the diff output spline as these weld themselves together with rust if not removed “often”. Once that’s moving, jack up the rear wheel on the side that you’re removing the CV shaft. Remove the strut mount bolt and swing the hub down lower to release the CV shaft off one set of splines. The other side should just pull out. Install is the opposite of removal Cheers Bennie
