el_freddo
    148
  1. Don’t get a new car, just a new engine... like an EJ engine Cheers Bennie
  2. Exact details of the model in question would be helpful. Certainly start with the fusible links and go from there Cheers Bennie
  3. @soobie87 - did you get the issue sorted? My thoughts would be the fuel cut relay/engine revolution sensor box. It’s a black box somewhere above the driver’s feet. 8 pin plug from memory. You should be able to throw a jump wire in to fire up the pump whenever the ignition is ON. Only recommended to do for diagnostic work. If the box is dead get another known good one Cheers Bennie
  4. Bugger mate. If she’s thrashed I hope the damage is only in the engine and not the body etc. And I really hope you get it back and the waste of space get what’s coming to them. As a coincidence my mother in-laws targa brumby was broken into as an attempted theft (second time in a year). Very lucky. Cheers Bennie
  5. Or look into hitbits coil overs. The fellas at Offroadsubarus have had good success with them in their lifted rides From what I can gather you can custom build your coil overs for your application. Cheers Bennie
  6. @GeneralDisorder - what’s this “hour glassing effect” of the main line about? Ive not come across this before. Cheers Bennie
  7. Yeah Bugger the 40/50mph stuff. I’ve slipped into 4wd from 2wd at higher speeds than that (100/110kmph) without issues. Just do it in a straight line. With the tyres, if you’re running different sizes or even same size, different brand/tyre model you may have binding issues that will lock it in 4wd - or make the car feel really unstable when that binding tension is released through one wheel. Not fun on snow I can tell you that! Cheers Bennie
  8. When shifting from 4wd high to 4wd low ALWAYS use the clutch! And it’s best to shift into the next higher gear if on the move Cheers Bennie
  9. You might also need to swap the crank and lhs cam sprocket/gear for ignition timing to work properly or at all. Cheers Bennie
  10. California in about 2014 looking at the OP. Cheers Bennie
  11. That user may have been me Jono and Jono That or I had the same convo with a mate when we were sorting something out between the two of us. Anyone know if the EA82 double uni joint can be fitted to the EA81 PS setup? Cheers Bennie
  12. Dizzy swap to a carb unit, intake swap to that of a carb as well. You could get away with keeping the ecu and matching dizzy for ignition purposes but it might not be overall happy with the tps and O2 sensor missing. You may need to run some wires to excite the coil to make the bang in the cylinders - and sort out the anti-dieseling solenoid (or run the Weber) Cheers Bennie
  13. Either way a butcher was at work there. Probably had to weld it back on several times due to the pressure and heat from the turbo extractors/headers. Cheers Bennie
  14. I cut up some old conveyer belt and used that. Got rid of all the slopin the bush too Cheers Bennie
  15. Is the steering wheel physically pulling one way or the other? Or is the issue that the steering wheel is not centred properly? If it’s just that the steering wheel is not centred then that’s an issue for the wheel alignment place. Cheers Bennie
  16. Sounds like a win win with that setup. Interesting about the turbo too... Cheers Bennie
  17. Just because the control arms were replaced, it doesn’t mean the ball joints were. Although it would make sense to replace these items while everything was apart. Cheers Bennie
  18. Not even a chance that you’d get away with that for long over here!! Traffic authorities would spot it a good mile away Small/mild lift and tasteful mods are the way to go. The EJ22 can be done without drawing attention to your ride Cheers Bennie
  19. Definitely factory fog lights. The problem with using these switch panels is that you need the switch button or mod the blank that’s there so you can actually push the button and have it return back again. I tried it for my driving lights but it didn’t work out very well. I ended up going the easier route - used aftermarket toggle switches I put my cruise control panel on there - but I modded one of the blanks to mount the panel on, so that’s neatly mounted and the button pushed into the panel. Looks real neat. Cheers Bennie
  20. If you’re worried about the power do a couple of track days to get to know your new power plan and how it behaves - or just drive it gently like a Sunday drive style. Youll probably find that you won’t play with the boost all that much - but it’s “nice” to have it on tap if/when needed. I hope everything goes sweet once the conversion is sorted Cheers Bennie
  21. Why a 5 pin? The easiest way to do it is to run a dual wire from the temp switch at the radiator, have one wire go to the switch, the other wire from the wiring loom. On the other end of these two wires will be the three way switch. You wire the loom wire into the common/shared pin, the switch wire to one side of the three way switch. The other side of the switch is wired to earth. Back at the radiator end, you’ll need to put the other wire of the temp switch to earth. You may have to work out which wire is earth and which is the reference wire that goes to the relays. Or it may not matter since it’s just a switch. The MY is much easier to do since it’s only a one wire switch. Cheers Bennie
  22. BYB don’t make lift kits for these anymore. I doubt you’ll find anyone in Oz making a lift kit for these anymore. As previously mentioned, a two or three inch lift and 27 inch tyres are the go. After that you’ll want an EJ22 to turn those larger wheels better, or sort out a gearbox with foz internals behind the EA82. Cheers Bennie
  23. After checking the balance of the tyres and not finding any issues, have the inside of the tyre checked for any foreign material in there. This can also cause weird vibration issues. Mother than that I concur on the above mentioned areas to check Cheers Bennie
  24. Thanks Dee. I knew it was something like that... I have a 3/4 inch drive breaker bar that I jump on to tension the castle nut, my torque wrench doesn’t go up that high :/ Cheers Bennie
