el_freddo
    152
  1. Seems like you need to run a certain cam grind from delta cams to get the best from this build. Do some reading, drop thread links in here and hopefully it can be worked out for your setup. I reckon the EJ253 (going by an EJ251 with a sports exhaust that's in the family) would be a good engine and upgrade over the stock VW donk in there atm. A fella I know over here has an EJ22 in his '80s kombi (T3??) and he loves it, so the 2.5 should be even better I reckon. Cheers Bennie
  2. Hey Bob, I've replied in your other thread - but finding out that one cylinder is down on compression that throws a red flag for me. How do you know that the issue is a valve? It could be the piston, rings or worst of all the bore. You can certainly build the franken motor you talk about but I don't know how well this will run as a result as I've not built one of these engines... Yet. I'll leave off here for others to add to. But like I've said in your other thread the ej22 intake, heads, sensors and timing gear will bolt on and run that ej25 block. I'd hate for you to put it all together only to find an issue with that cylinder that's down on compression. Cheers Bennie
  3. Dohc will be the EJ25D Sohc is either the EJ251 or the EJ253 depending on the year. Being that yours is a 2002 model year (going by AUDM) it should be the 253. Either way it's the sohc setup. Subarus are like Lego. All heads are interchangeable - but to what sort of performance to expect depends on what's used. The only issue is that you have the 251 or 253 I've read that these blocks are not great for the franken build, only the EJ25D is the block to use (but I could be wrong on that. @GeneralDisorder will be able to clarify). To get that engine running at the very least, use the '97 heads, intake, sensors, timing gear (including the sprockets/gears/wheels - what ever you want to call them). Again, I reckon GD will be able to advise if that setup will work or not. Cheers Bennie
  4. There was no marking balls for me, those little mongrels went every where when I pulled the joints and cages apart. I did make an effort to keep the inner and outer race and balls separate to each other. Anyway, I'm going with new aftermarket shafts that shouldn't be cheap Chinese junk. Wish me luck. Cheers Bennie
  5. Interesting. All GTs over here are twins... Cheers Bennie
  6. Ooh I love that colour!! neat head unit setup. I used a block of wood, got some filler to smooth it out and never finished it... It's been 13 awesome years Cheers Bennie
  7. So are you saying avoid the genuine subaru oil filters? I've just found them to be a few dollars cheaper than the ryco aftermarket units at local retailers here. I thought OEM was better quality than anything aftermarket. Cheers Bennie
  8. I should send my shafts over to you as this trick hasn't worked for me But they keep on trucking even though they're noisy as hell Cheers Bennie
  9. I'd assume that the 5 stud conversion would change the ride handling through bigger brakes - giving better stopping power and reduce the chance of brake fade. Other than that you're essentially running the factory suspension and geometry. Cheers Bennie
  10. Shame you're not near me, I've got two sitting around and another three in parts cars over here (in Oz). I know shipping to the states would be the better part of $1000AU... Not worth it Look around, you'll be surprised what's hiding out there. Have you put up a wanted advert on the site? Cheers Bennie
  11. I did my EJ conversion while at uni. I searched for parts on my holidays, did my research of wiring etc between assignments then put it all together in my final year over the mid year holidays If you retain the factory gearbox you'll need an adaptor plate and get used to spinning the front wheels off the line if you're not careful! Or swap in the EJ AWD box, but lose the dual range in your case due to USDM AWD EJ boxes only being single range. Really though, getting the wiring cut down and working correctly is the biggest hurdle in this conversion in my opinion. Cheers Bennie
  12. So I'm guessing auto as you haven't definitively said so. If this is the case ignore my post as this only applies to manuals from the L series - I thought yours may have had a gearbox conversion done. Best of luck getting your ride sorted! Cheers Bennie
  13. Welcome to the forum! The twin turbo GT? Noice! Post up some pics when you get the chance. We all love pics here! First up I'd be swapping out the timing belt for a new quality kit! That way you know the history on the cam belt kit and know that nothing is going to snap and make other bits go tinker tinker tinker together. If you need any twin turbo info there's an Australian based forum with a TT guru or two on there, they know all about the twins, vacuum lines and trouble shooting Cheers Bennie
  14. Like an EJ conversion. Done right and looked after it's a very good swap that comes with reliability. I'm still running on my same EJ conversion done ten years ago it also makes the L series a much more enjoyable car to drive. So patch that issue and plan for an EJ conversion I say! Cheers Bennie
  15. Map lights: grab the factory wiring and you *should* find a matching plug under your dash for them to be powered from. Cheers Bennie
  16. Check the power and vacuum to the solenoids to ensure they're working properly. Also check the switch as it sounds like it's not engaging in the on position. Cheers Bennie
  17. As mentioned - check the resistors in the fan ducting. There will be several wires that plug into this device. Check those and go from there to the switch etc. Cheers Bennie
  18. The XT6 5 stud hub swap doesn't do much for suspension other than change the front strut to EJ for the bigger brakes. Two reasons for this swap 1) wider rim selection becomes available and 2) you get the EJ brakes which means just about anything from the first liberty to the wrx and early sti (pre PCD change). as for the springs, heavier usually gives a little bit of lift but at the same time you lose some compression unless you're carrying a heavier load. The Honda springs go well unloaded. I'm now looking into IFS prado springs/shocks as the next piece of kit out the back. I might end up just using the Honda springs with the prado shocks - I'm not sure until I get the prado shocks and have a play. Cheers Bennie
  19. Thanks for coming back to this and updating the thread as to what the fix was. It's pretty rare Cheers Bennie
  20. @ErikAnderson - ok with more background context it makes sense. In that case find a decent used 4spd to bolt straight in because I can tell you now that if you open up a 4spd to service it you'll not have your wrx or your wife's car sorted anytime soon to start working on your motorbike. If you were keeping it, which I thought you were, my above recommendation for the 5spd stands. Or just save your time and sell it with a couple of crunchy gears. They can't be THAT bad can they? Cheers Bennie
  21. .B) read up on the conversion process (search the forum). Not overly difficult. And a lot less difficult than pulling a 4spd apart for some worn synchros. Cheers Bennie
  22. .A) what needs repairing? .B) everyone is with the 4 speed box. Your efforts would be better spent on fitting the L series 5spd box. At least there's some hope if you open up one of these Cheers Bennie
  23. There are two different clutch sizes for the MY series. Typically the smaller is the 2wd and I believe the early 4wd unit. I can't see anything wrong with that pressure plate going by the pics but that doesn't mean much. Have you had time to look at the other components in the clutch system? Cheers Bennie
  24. Make sure the dust boots are in good condition. If not it's probably a good idea to pull the calipers and put a new seal kit in them. If the piston on the driver's side is really badly rusted I'd recommend either a replacement piston or a refurbished set of calipers left and right. Cheers Bennie
