Everything posted by czny
- 03 outback rear suspension on EA81 - T-bone 2.0
- Audio/electrical help? 88 Subie DL SoundWagon
4EAT reverse direction for Vanagon
https://www.proformance.com.au/single-post/2014/08/15/COAST-TO-COAST-RUNNING-DIFFS-BACKWARDS-OR-UPSIDE-DOWN
Well then, wouldn't it be wiser to invest in a heavier duty auto transaxle such as Porche 911 Cayenne or a HD race 4 spd manual transaxle? https://ranchotransaxles.com/pbs-transaxles/ Scroll down - they manufacture transaxles with Subaru bellhousings. Monies invested in special purpose R&P for 4EAT could be spent on HD race transaxle already available. As has already been stated in this thread, reverse driving a FWD R&P doesn't last.
https://www.kennedyeng.com/subaru-vanagon Scroll down to automatic adapters. Anything wrong with auto trans as supplied for newer VW vehicle(s) to also transplant in your bus?
Source new centre bearing for tailshaft?
4th picture in this listing for Dorman 'tailshaft': https://www.ebay.com/itm/Rear-Driveshaft-Assembly-for-Subaru-1994-85-Dorman-936-934-STD-Trans/401257355418?epid=203116132&hash=item5d6ccd589a:g:PnsAAOSwFMdaU~6j https://www.dormanproducts.com/p-68555-936-934.aspx?year=1987&make=Subaru&model=GL&parttype=Drive%20Shaft&origin=YMM
Yeah, it is one piece but if a one piece center brg isn't readily available then perhaps you could take yours apart. Then replace the rubber 'doughnut' & brg with something similar from a Nissan product for instance. Then tack the steel 'girdle' back together - slowly - small tack weld at a time so as not to cook the rubber doughnut. My plate is full with putting a 73 Chevy K20 truck back together for tow vehicle to move. IF you find a genuine one, let us know where.
Ball bearing, shielded that is, could be had if you take apart tailshaft first. Just match up to 620x brg. But without the rubber doughnut to know shape, OD, thickness etc in hand to compare to some other make, I don't know. Looked at some late 70's early 80's Nissan center supports which are either 30 mm or 35 mm ID. Subaru center brg has that steel mount girdle around it. You'd have to drill out all the spot welds, split it apart to dissect it.
Fuel stink and bubbling after parking XT-T
Yeah, fuel recovery system operates at a partial vacuum IIRC. Depends on fuel purge solenoid valve to either vent positive pressure to charcan or vent fumes to intake with vac. That plastic bladder is for fumes to condense then drain back to tank. Otherwise liquid fuel could get sucked into intake. Emission vacuum hose stock should do you well. Don't forget the little lines connected at tank.
There's a plastic tank behind rear panel near tank that can develop cracks & leaks, BUT, I would check out the small vacuum hoses connecting things together back there first. When you get that tank out pull a partial vacuum with a hand held pump vacuum test to see if it holds vacuum well for 5-10 minutes. Mine held for hours without leaking. Had that fuel smell 3 yrs ago inside the car & it was the little hoses that had rotted in LA smog. Mityvac is what I used.
Justy ej22 engine swap
1991 Pontiac Sunfire Quad 4 drivetrain would be more than enough: https://en.wikipedia.org/wiki/Quad_4_engine#LD2
Subaru EA82T compression comes and goes
Marvel Mystery oil in fuel tank & crankcase with fresh fuel in tank. Helps a gummy engine with top end lubrication. After draining old fuel tank & lines first of course.
XT coupe air struts.
Give Photobucket none of your monies. They held thousands of enthusiasts hostage for their own picture files across many websites. These days its about paying for a photo hosting site if you want to share your stuff. Flickr, imgur, imageshack, etc. Search & find one you like, or one that is popular here at USMB.
'86' GL Front Struts
Nice try but those are for FWD - 2WD only vehicles. Big difference in spring perch height between them.
Stripped EA82 Rotor Screw (Threads, Not Screw Head)
Strip down the distrib to a bare shaft, fill stripped hole with silver braze on low flame. MAPP gas works best. https://www.amazon.com/Harris-Safety-Silv-Silver-Solder-Brazing/dp/B0713Y6V2F/ref=pd_cp_469_1?pd_rd_w=dDcKR&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=PG9KRVHQ4X65KNR3N839&pd_rd_r=78b87253-97b1-11e9-9c69-1d3c8f2acdb3&pd_rd_wg=iyhgk&pd_rd_i=B0713Y6V2F&psc=1&refRID=PG9KRVHQ4X65KNR3N839 Drill & tap new threads in a drill press to make sure hole is square to shaft & where you want it.
Splined hubs & stubs are always counted on the major diameters.
Ring Gear Swap
Yeah, they were originators of the "original" Aussie locker. https://www.torqmasters.com/ Have a TorqMaster lunchbox locker for my 83 Chevy Dana 60 1ton front axle. Will have to check the box & instruction sheet for country of origin & manufacturer. Somewhere out there in the world of off road there's a video showing the turning radius difference of open rear diff VS rear locker on tight trails. Tight turns are a strong reason for turning brake steering.
Ring Gear Swap
Here's that thread Dan...Lokka Lockers were the ones that took the money and ran. **&%$$!!! https://www.ultimatesubaru.org/forum/topic/165393-lokka-r160-locker-interest-need-50-guys-300-a-piece/
Ring Gear Swap
NO. Ring & pinion are a matched set.
Tow bar questions for my TOAD 87 GL wagon
Buy or rent a two wheel tow dolly. https://www.youtube.com/watch?v=vKWIKwgSk1U Used ones from U-Haul, etc may still be serviceable after a little maintenance.
Bogging in forward gears
This^^^ Bottom of mine was cracked in places as you can see. From Nov 2017. 4 inch lift caused too much strain on intake boot.
EA82 Control Arm Bushings
Right. Two each trailing arm, #9 in link & two each for the slotted toe-in plate mounted outboard on the cross member, #8 in link. https://www.subarupartsamerica.com/parts/1989/SUBARU/GL/Turbo/?siteid=216122&vehicleid=45477&diagram=758260 Four bushing halves & two tubes per side.
http://www.superprousa.com/where-to-buy/
Front bushings https://www.ebay.com/itm/SuperPro-Control-Arm-Lower-Inner-Bushing-Kit-Front-for-1981-1986-Subaru-Brumby/264304776028?hash=item3d89cad35c:g:Vt0AAOSwaANcyNN8 https://www.ebay.com/itm/SuperPro-Control-Arm-Lower-Inner-Bushing-Kit-Front-for-1981-1986-Subaru-Brumby/283468751142?hash=item42000de126:g:U9oAAOSwEZdcyNK1 Rear bushings https://www.ebay.com/itm/SuperPro-Axle-Alignment-Trailing-Arm-Bushing-Kit-Rear-for-1979-1994-Subaru-Leone/283468762117?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D57921%26meid%3Dd5984c730b32448385cc2bb4439a6a57%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D173716101380%26itm%3D283468762117&_trksid=p2047675.c100005.m1851
https://www.ultimatesubaru.org/forum/topic/134590-diy-bushing-replacement/ There are Superpro bushings still available but you must be patient for them from Aus. Search for Superpro in this forum. Look here too. 5th post first page. Energy Suspension bushings. https://www.ultimatesubaru.org/forum/topic/131364-87-gl-4wd-wagon-czny/
