Everything posted by Sweet82
Carb Choke basics
I have always had to bump the pedal to unlock the choke/high rpms when it's warming up. I have never seen it calm down on it's own but then again, I never let it run long enough to see if it will do it on it's own? For what that's worth? Glenn 82 SubaruHummer 01 Forester
harpua update
Donny, Hate to see you go... You have the cutest little boys around (next to mine). Say Hi to the guys in Laramie. I like Missoula, I think you'll like it too. What's up with the RX? Good luck, Glenn 82 SubaruHummer 01 Forester
a wagon wheel of a different color
That looks fantastic! I had never though about that color scheme before. I think it looks great! Glenn, 82 SubaruHummer 01 Forester
Weight Stripping
Does the car need to be street legal? Might I suggest removing the body for a huge weight reduction? I saved a "ton" of weight by doing that. Glass weighs! Doors weigh, Hatches weigh, Hood weighs, Seats weigh a bit, My chrome bumper didn't weigh that much... What do you need the car to do? Glenn 82 SubaruHummer--serious weight reduction 01 Forester
Heater Blower Wacky
I'd bet the motor is fine and the wiring is messed. Try jumping power to the blower and see if it behaves? Put a volt-o-meter on it next time it don't wanna play and see if your getting power? My money is on the resistors for the speed setting are messed or in the process of messing up. Check your grounds too! Glenn, 82 SubaruHummer 01 Forester
"Rattle" in 87 GL
I would have suspected the heat shields on the exhaust pipe. I have always got rocks or pieces of rust rattleing around in them. They only made noise during a shift too? That was easy to trouble shoot by pounding on various points on the underside. Have you isolated the noise to the tranny and not to the exhaust? Humm, Glenn 82 SubaruHummer 01 Forester
tracked subie
Didn't they do this on Monster Garage Glenn 82 SubaruHummer 01 Forester
Newbie, any tips?
Welcome to the board! I've found the basic tune up kit does extremely well on these old beasts. Plugs, a cap and wires seems to cure everything. Four wheel drive in a small car is amazing! Enjoy you new toy. Glenn 82 SubaruHummer 01 Forester
rolling a fender
I was just messin with ya on the sawzall bit... Howerver, On the Buggy when I hit an exposed metal edge, I used that small drip Irrigation tubing split open to form a molding. This made it so the metal edges are not such a problem. My dash, all metal side pannels,rear pannel and windshield are all lined with tubing to eliminate any sharp edges... http://usmb.net/gallery/albuo21/MVC_174F Here is what I talking about in case anyone cares... Tubing came from Harbor Freight for $5 on sale. Glenn, 82 SubaruHummer 01 Forester
My new find.. EA81 dune/swamp buggy
SCORE! I'm sooo Jealous! Why can't I ever find those deals! Glenn, 82 SubaruHummer 01 Forester
rolling a fender
Isn't a sawzall easier?
RWD Subaru Video Check It Out!!!!!(Reposted)
Regular Subies can't do that kinda stuff. The RWD is great!
How do I remove ea81 oil pump.
Becarefull!!!!! Don't pry the pump to get it loose!!! There is a flat plate that brakes easily and it's just under the oil pump.
running rich EA81 Hitachi Carb
S'ko, Mine was bolted to the same bolt that the hood release latch is attacted with. Should be a black or blue box 2" X 3" X 1". I had a big Mitsibishi logo on mine. Has a six prong wire clip attached to it. Glenn 82 SubaruHummer 01 Forester
Looky what I found.
10th digit of the vin tells all...
Horn ? for a 1988 Wagon
The horns, on my car are between the grill and the front cross member (ahead of the radiator). Just behind the plastic grill. Good Luck, Glenn 82 SubaruHummer 01 Forester
I'd check for corrosion on the horn wire clips. I had the same basic problem. I took it off and cleaned the horn and clips. Worked just fine after that. Harbor Freight has $7 horns on occasion. Glenn 82 SubaruHummer 01 Forester
The wrong fuel pump control unit box will tell your carb & pump the wrong things I had the wrong FPCU on my buggy for a while. It ran... but it ran rich. Just a thought... Glenn 82 SubaruHummer 01 Forester
Please clean inside your fenders!
Sweet82 replied to schspeedster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI peaked in mine and found some masking tape with "Aspen White" written on it. Guess my car has been to the paint shop before? Glenn, 82 SubaruHummer--No fenders, no crud buildup! 01 Forester--Apparently been painted...
Help!! Airbags pop at 3mph!!
Sweet82 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAir bags are pricey.... Two are twice as expensive... Windshields ain't cheap either... That's a problem.....Figuring out what to do...?
Motor is here - links for pics
Someone step in... What are the specks of a JDM? Someones got to know...?
New wheels installed!
Looks good, What rims are they? White goes with the wagon nicely... Glenn, 82 SubaruHummer 01 Forester
On an EA71 what's the difference between a regular and a JDM motor? What are the specks? Glenn, 82 SubaruHummer--EA81 stock 01 Forester--EJ25 stock
Pics of the 84 DL
I'd call that a score! I like the single headlights Car seems in great shape! Good Luck, Glenn 82 SubaruHummer 01 Forester
Minnesota has a new lifted Wagon
Two thumbs Up!! Looks great!
