Everything posted by Sweet82
simple trailer hitch
I used an old hitch from another vehicle and mounted it to the underside of the rear deck of my Hatch and then to the bumper. Worked great towing a sail boat. I did end up reinforcing the bumper mounts. Good Luck. Glenn 82 SubaruHummer 01 Forester
Harbor Freight winch
I was going to put one of those on the Buggy. I even measured it and built a space for it, but finally I decided it was too heavy besides drawing a bunch of juice. I decided on the smaller HF #2000 winch with a snatch block. http://www.ultimatesubaru.org/photos/showphoto.php?photo=32&sort=1&cat=500&page=3 This one goes on sale for $39-49. Sold! I'm not sure you really need a #8000 winch on a Subaru? Good Luck, Glenn 82 SubaruHummer 01 Forester
AWD Hi/Lo Transmission?
Sweet82 replied to [HTi]Johnson's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAWD and 4WD are just different animals. AWD maybe superior for traction control but you can't climb with the AWD setup. That's why people are doing the D/R tranny. The D/R will give you the ability to do some real 4wding. The stock AWD is a waste of time on anything but snow (and it's real good there). It boils down to what you want out of your vehicle. I want the ability to climb like my old GL had. I'll gladly sacrafice traction control for gearing. My .02 Glenn 82 SubaruHummer--"Good" gears 01 Forester--No gears! The Australians also have the newer D/R trannys.
AC and Fan?
Sweet82 replied to David C's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Fans are thermostaticly controlled. If you turn the car off it will get hotter for a while before it slowly cools. This happens because the air is no longer flowing through the grill and engine bay. If you turn it back on soon after you turned it off, the fan sensors could easily be hot enough to send a signal to the system to turn on a fan? So it may appear as though turning the car off and turning it back on makes the fans go on? ...Just a thought... Glenn, 82 SubaruHummer 01 Forester
weird, weird, weird - overheating or not???
Sweet82 replied to zzzasy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy question after reading your post is.... Are your fans working? One fan should come on with your AC as soon as the switch on the dash is turned. Is this happening? Just for fun Jump power to your fans and see if they are playing the game? Next I'd look at the relays that control the fans. On my Forester they were "swappable" with other relays so the test was easy. My main fan was not working and my heat would do strange things... Good Luck, Glenn 82 SubaruHummer 01 Forester
The Subaru Brat
I think it was 82 also, the grill for 83 is different. I have never seen the cyclopse light in anything but the 82 grill pattern (stock). Brochures don't mention it any other years... Glenn, 82 SubauHummer 01 Forester
VERY NICE 1984 Subie
The pictures make it look identical to the Front wheel drive ones!
new to group and subaru...
Sweet82 replied to rizzo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the main must have is Big Tires and a Push Bar! Oh! Sorry, that's older generation answer. If your looking for crap to put on your car, try the "Market Place". There is always good deals to be had! "Dr. Outback" (and others) usually have some dealer close outs that they are just dying to get rid of. As for your CD-R, some older decks just don't recoginze that format. Although, I'd think an 03 would? Good Luck, Glenn 82 SubaruHummer--what's an option? 01 Forester--all options supplied by Dr. Outback.
changing parking light
Sweet82 replied to bishop087's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere may not be an easy way I have several other cars and it's major surgery to do something stupid like that. Back lights seem to be so easy... I don't have Imp. Sport so I don't really know for sure. Good luck, Glenn 82 SubaruHummer 01 Forester
'82 GL overheating
In the owners manuel it mentions that during a idle the oil pressure gauge may read "0". As soon as you rev the motor, the oil pressure gauge should come back to life. That is the best I can paraphraise what it said. Having said that, I think the two problems are unrelated. I'd go along with the thermo switch on the fan or the fan is bunk. Have you jumped power to the fan to see if it still wants to play? Good Luck, Glenn 82 SubaruHummer 01 Forester
Hi I'm new---'84 Brat and '01 Outback
If it's loud, I'd bet you have some sort of exhaust leak. Once the car is up to operating temp it should be only very slightly noiser than any other car and most of that noise should be road noise. Check if the noise is related to the motor or chassis. Push the clutch in(or neutral) and rev the motor a bit as your driving at speed. This will tell you if it's related to the motor or not? My bet is something in the exhaust system needs some minor attention. Welcome to the board and... Let us know what you found? Glenn, 82 SubaruHummer 01 Forester
Omg Ebay!!
It's a parts car! It has obviously been used as a parts car already... You could "buy it now" for the $490 and part it out and still come out ahead! There is just too much missing to make it reasonable to restore. You could buy a better on for much less than you could even start to restore this one.
Off roading justy!
Someone up in your neck of the woods is running ATV tires on their Justy. I don't think it would rally well but it may be a lot of fun in the mud? Glenn, 82 SubaruHummer 01 Forester
Under car cleaning leads to sudden problem
I just "Googled" for "thwarping marbles" and it came back with "funny noises Subaru's make when freshly cleaned". Really!
Teaser pic...i scored big time today
I smell "Rice" cooking Show us more!
Salvaging CV's
I believe it's a motor match thing rather than a body or year match thing. As I understand it, an EA81 axle matches to EA81's, years don't matter. EA82 to EA82's. I believe Turbos are an exception to this and have more splines on the axles. Anyone else? Glenn 82 SubaruHummer--can use axles up to 1984. 01 Forester
a debate here at work...
I'd mix any brand with any other brand as long as they were the same weight. It's the weights that could cause a problem not the additives. Although in a pinch, I'd mix weights & brands rather than run it low. My .02 Glenn 82 SubaruHummer 01 Forester
I think we have all learned a lesson about cleaning the crud off a Subaru! I'd bet your Subaru liked being dirty and is now mad at you! Water in the distributer cap??? Dry it out and try it again... Good Luck, Glenn 82 SubaruHummer 01 Forester
damn 82 GL wont start! You all said I should help the lady!
Do you have a wiring diagram for the vehicle? I'm not sure which wires your talking about??? Your probably one of the few people who can actually help this lady.
My recent purchase, '84 Subaru Brat Pics
The jump seats are not illegal. If they were imported with them in, then they passed all DOT regulations for sale in the US. They quit putting them in, in the later models but that was for liability reasons. I have checked out most of the local Junk Yards and there are no seats to be had. :-\ I know of a hidden stash of Subarus and some of them have the seats (old and new generation) but I have not been able to run down the owner. Glenn, 82 SubaruHummer 01 Forester
5 speed swap
The main difference is the multi part drive line associated with the 5 speed. The 4 speed has a one piece driveline and thats what the 82 is set up for. The 4 speed has lower gears than the 5 speed but if you want it for freeway driving what about taller tires and no tranny swap? Another thought is use the 4 speed driveline and have it redone to the proper length for the 5 speed tranny thus allowing you less headaches on the driveline install? I have plenty of usless suggestions... Glenn 82 SubaruHummer--shortened driveline 01 Forester--factory driveline
Funky gear ratio question
John, You'd be a hero if you could figure out how it's done! Go John Go! Glenn, 82 SubaruHummer--needs lower gears. 01 Forester--needs D/R
Busted bumper
Sweet82 replied to frag's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may be able to be popped out but the paint may crack during the process? Let me guess...no one left a note on your car claiming responsibility? Try popping it out, and see what happens? Good Luck, Glenn 82 SubaruHummer 01 Forester
Destructive testing.
Sweet82 replied to Diesel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt might be fun to make a buggy out of it??? Serious weight loss may make up for lack of gearing. On the other hand it's a perfect rally car. Your not going to hurt the body. However, I'd still remove some weight. Remember, If you break it then you won't have anything to play with... Keep it together and play with it! Glenn 82 SubaruHummer 01 Forester
Brat with lift and mad fender flairs in Island.(pics) gnarly legacy shot too
Are we missing the obvious These cars were not designed for use here! Our needs don't apply. These vehicles have a purpose. Traveling over snowpack and soft terrain. Somehow I think they have figured out how to do that. They live there you don't. I don't think that we have a secret idea about "clearance" that they have never thought of? Give'um some credit, if they needed it they would have built it in... These vehicles were not designed for our terrain! Glenn, 82 SubaruHummer 01 Forester
