Sweet82
Everything posted by Sweet82
  1. I've heard rumor that the pulley torque specks are incorrectly set out in the FSM. I understand the real torque specifications are way higher than those referenced in the FSM. If not torqued enough the pulley has a way of working it's way off. I have heard of several people welding the things on in order to get them to stay! Good Luck, Glenn
  2. Repost your question and you may get a response quicker, I'd think most people will think this is the same old farwell post and not re-read it?
  3. Thanks, I'd been looking for that picture... For inspiration..
  4. My first recomendation would be... Loose the "White walls" The white walls have AARP written all over them What a score... Glenn 82 SubaruHummer 01 Forester
  5. That is so strange...I saw one of those Unisport 198's last weekend. It lives near me? I didn't know what it was till I went to the link... Now I'm going to have to go take a look and see what is powering it?
  6. Welcome to the board. I think your in the right place. There are tons of modified Brats around here. I'd call it a "SmorgasBrat". Pick and choose what you like? Are you thinking on using a Subaru suspension or mixing it up a bit with other parts? The reason I ask is you'll soon be dealing with the gearing/tire size equation. Everyone seems to come up with their own balance. Using non-subaru gearing... will allow you a wider range of tire options. But it does cost more...$ I'd assess your intended use and see what makes sence for gearing and tires. Good Luck, Glenn 82 SubaruHummer 01 Forester
  7. So you removed the fuzzy dice and passed then reinstalled them, right? http://www.ultimatesubaru.org/photos/showphoto.php?photo=31&sort=1&cat=500&page=3
  8. What model of Gen 2 are you looking for? The bumpers changed a bit from year to year. My Hatch had chrome with rubber bumps Later Hatches had the black plastic bumpers... http://www.usmb.net/gallery/album15 Here are some pics... Good Luck, Glenn 82 SubaruHummer--no bumpers anymore... 01 Forester--factory bumper w/factory push bar...
  9. I'm 8 years over due on my valve adjustments Can you still get the gaskets from Subaru or did you make them?
  10. Link, http://www.usmb.net/gallery/album16 I like the Sambar Mini Caterer Just plain cool!!! Glenn, 82 SubaruHummer 01 Forester
  11. I haven't seen one that clean since 1978 Lookin good!!!
  12. Other than the fog light needs aiming and the wheel centers need some attention... the car seems flawless!!!
  13. I always thought I wanted a van but now I see them all together, I think the 360 is the cutest. That car would turn heads. ...and it would be real easy to store...
  14. It was a long hard battle but...Your back on the road! That's all that matters. I've been dinged on a few inspections too. I've been through the tie rod thing. So I just took it to a different station and got a second opinion, I passed! Another station said my caliper was shot and showed signs of leaking. The car didn't use fluid? I cleaned the caliper with a wire brush and told them it was replaced! Of course both places wanted to fix it for a ton of money Even in Utah we can buy Beer at the 7/11's Of course anything else must come from the liquor store. Good Luck, Glenn 82 SubaruHummer 01 Forester
  15. I agree, how high are you thinking on going with a lift?
  16. Be carefull!!! You already have a bad situation, don't take any chances to make it worse. Yes you need to drill a pilot hole. This is critical. You must get it right the first time. If you don't you'll mess up your existing threads. I'd center punch your bolt and drill it carefully! Start small and work your way up with the bits. If you stay centered you can drill most all the bolt out except for the threads. I have found that with the center of the bolt gone, it's easy to remove. If it still won't come out then try the easy-out. Don't force the easy-out, if you break it you have a big problem. They are made of the same stuff as drill bits. Good Luck, (Ya I realize that the bolt are rarely in a convient spot)
  17. We want results!!! ...and pics along the way... :cool: Keep us updated Glenn 82 SubaruHummer 01 Forester
  18. Nick, Not sure who makes a lift kit for a Justy but... Put a 2" piece of square tubing between every place that the suspension and drive train touch the chassis and you'll be lifted before you know it. Someone up in the northwest put ATV tires on a Justy? Dunno who it was or if they are a board member here or not but it can be done. Good Luck, Glenn 82 SubaruHummer 01 Forester
  19. Welcome to the Board, Tell us what & how many Subarus you own? I think you'll like it here... Glenn, 82 SubaruHummer 01 Forester
  20. I think most anyone with an EA-81 could relate to this tale.
  21. So what is the overall plan for this clean little Hatch? Are you going to build it up or leave it as it is??? Sure looks nice, Glenn 82 SubaruHummer 01 Forester
  22. For what it's worth, I had a wheel company in Denver custom make my 12" rims. The were $80/ and I only had 4 made. http://www.ultimatesubaru.org/photos/showphoto.php?photo=4967&sort=1&cat=500&page=1 I have info if anyone wants it. For what it's worth. Glenn 82 SubaruHummer--custom rims and 26X12X12 six ply tires. 01 Forester--factory tires...
  23. So...... What type of Subaru are you replacing it with?
