Sweet82
Everything posted by Sweet82
  1. I believe the problem is the diff gear ratios. I think your looking at a 3.7 on the auto and a 3.9 on the manuel. You could swap the gears out of another diff to match the tranny you decide to go with? Good Luck, Glenn 82 SubaruHummer 01 Forester
  2. Anything is possible! And Subarus are easy! As far as the motor goes, I'd make sure you have the computer and black boxes out of the Hatch. You'd need to match the Fuel Pump control unit to the carb so you'd have to transfer that from the donor car. Do a Search on the motor swap? Good luck Glenn 82 SubaruHummer 01 Forester
  3. Sweet82 replied to s'ko's topic in Off Road
    I can't remember what thickness tubing I used, I'll have to go check tonight. But in the areas where I might be coming in contact with rocks... I used D.O.M! Good Luck, Glenn 82 SubaruHummer 01 Forester
  4. The N20 guy claims it's underpowered until he hits the button
  5. My 82 has done that since time began I have never been able to figure it out Good Luck, Glenn 82 SubaruHummer 01 Forester
  6. That's the funnyiest story I've heard in years I feel bad for the guy in a way but on the other hand he was handcuffed for a reason. :-p
  7. I just put the Bosch platnums in the Buggy over the weekend Glenn 82 SubaruHummer 01 Forester
  8. I just put frams on my trooper and camry I just put a pennzoil filter on the SubaruHummer yesterday Glenn 82 SubaruHummer 01 Forester
  9. What did they charge you for the Pugs? Curious Glenn 82 SubaruHummer 01 Forester
  10. We want pics of the transformation Welcome and good luck, Glenn 82 SubaruHummer 01 Forester
  11. I'll be in Moab on May 6 - 8. May also be there Mid March a couple weeks before the Jeep Safari. Glenn 82 SubaruHummer 01 Forester
  12. Given what happened it seems as though that's the best possible outcome. Your ok, the car has usable parts... It could have been a lot worse Good Luck, Glenn 82 SubaruHummer 01 Forester Maybe the car is now ready to become a modified off-roader?
  13. Looks like classic Moab / I-70 / San Rafael terrain. If I'm not mistaken that's clay and gooey when wet???? I've had problems moving on level ground in that Crap! I took the Forester through some of that crap last spring in the San Rafael Swell and it's still stuck on the bottom of my car Looks like a ton of fun! ...Gotts to wonder how "Summer" (my SubaruHummer) would handle the terrain I need to get down that way sometime... Glenn, 82 SubaruHummer 01 Forester
  14. Try Ebay, I've found a bunch of stuff like that there. Good luck, Glenn 82 SubaruHummer 01 Forester, Ebay, security system, remotes, wood dash...
  15. I got 21 mpg with my 01 Forester on a 300 mile freeway trip once. Best I've seen is 24 mpg. In Utah with the tempature change, cars need to warm up a bit. My winter mileage is always less than summer. Sounds to me your in the ball park with the mileage, Glenn 82 SubaruHummer 01 Forester
  16. Hey welcome to the board The newer Subies can be lifted just like the older ones are. Mudrat is a great source for that kind of stuff. I think the reason more people don't lift the newer stuff is the lack of the dual range transmission Because of the gearing, your limited on your off-roading adventures. Again that too can be gotten around ...Mudrat... I added fender flares to my Forester to give the illusion of a lift but until I can get it geared down I won't take it on the ugly stuff. My .02 Glenn, 82 SubaruHummer 01 Forester
  17. Looks great, however I think your leaving your self wide open for some "Photo Shop Fun" with your car posed like that Glenn, 82 SubaruHummer 01 Forester
  18. That's cute... Can't you get those for the kids at PepBoys or Checker? If I could get one I would, Glenn 82 SubaruHummer 01 Forester
  19. What did it cost to make the change? I'd consider it, if it was not too expensive I'm tired of not getting the vehicle to refire untill its back level ground. Does anyone remember what it cost them when they did it? Thanks, Glenn 82 SubaruHummer--carter weber 01 Forester--injected
  20. I had my rims made 3 3/4" center bore. http://usmb.net/gallery/albuo21/PIC4
  21. Drive first (and fast) measure thickness later ...said the guy with the winch in back...
  22. Lots of folks compete in UROC with "stock" Toyota axles. They are solid! My .02 Glenn 82 SubaruHummer 01 Forester
  23. I think you'd have more travel with the leafs on a solid axle. Our indpendent set up is limited. Just add leafs to the torsen bar and call it done! Glenn, 82 SubaruHummer 01 Forester
  24. Looks Great, Heres a link.... http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=8086
  25. There might be some "ecomomies of scale" or in other words if a whole bunch of people wanted to go in on a batch of them...It may be cheaper to send a bunch of them than sending them one at a time...? Just a thought... Glenn 82 SubaruHummer 01 Forester
