Everything posted by nipper
When is the Turbo supposed to engage?
Yes it should come on. You may have a sticking boost control valve (forget the exact name right now).
General Carburetor question
AT the time most pickups were full size and getting 13-15.
99 legacy speed sensor
nipper replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXABS in gerneral does not work well on icy roads, and i will not get into the ever continuining debate about subaru ABS. ABS is for more rain and slush then anything else. You have a manual so really you should not have the usual abs "issues" that others seem to have since you have far practice in down shifting and haveing two ways of putting the car in N to hel the abs operate. But yes you have the two issues and one sensor.
What the heck?
Now three people have stopped by my house wanting to buy the Justy, and it isnt even running. One wanted him for a winter car, no way in hell, he is rust free!
97 OBW not starting. Clicking
nipper replied to NameTaken's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThem falling into Acme instant holes?
Correct pressure control solenoid valve operation?
nipper replied to jamesm113's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt regulates pressure. It does not have an open and closed, it has a partial flow and full flow position. I can not tell you any more unless I know from where on the car it came from.
Radiator time? Or?
You didnt quite answer my question. Fill procedure for any car: Remove cap Start car fill cooling system Wait for t-stat to open (will be a rush of coolant maybe some overflow) Top off coolant fill resivoir to hit line Replace cap, drive, let car cool off Check coolant Sounds like you had an air bubble.
slave cylinder real hot...is it cool?
nipper replied to efseiler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHrmm is your clutch slipping and you don't know it? Is the bell housing as hot? it may just be a bad location, I don't know. Can you take a temp on it as hot to touch isnt really all that hot for a part.
nipper replied to jamesm113's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt may not be closed by default as it can be a check valve or reducer valve of some kind. From where on the car was it located.
viscous coupler
nipper replied to GEORGE G's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHas anyone checked to make sure thier tires match and are equally worn and inflated?
6 year oil change interval for reals
You dont need to start the engine twice a month, just cover the air intake so moisture wont get in it. Oil sitting for six years, I wouldnt drive on it as the additives may have broken down from being open to the air. The fuel vapors from the last operation and moisture can make an acid. Odds are you are ok. What i WOULD be worried about is the fuel system, coolant and brake fluid.
New Guy, First FOREIGN car! haha
Welcome. The car isnt all that foreign as it is built in Indiana. ALways make sure all the tires match otherwise you develop the dreaded torque bind
Radiator time? Or?
Subarus dont burn coolant they tend to vomit it. Is it the proper cap? Have you given the system a really good flush? How did you fill the system? Any bubbles in the coolant after the car is warmed up How is the heat? Are the cooling fans in one peice and operative Is it a subaru t-stat (if they are available for this, I do not know).
Water temp sensor moving with revs
Check your alt output as the voltage flux can cause this. Also if your electric fan is dying and drawing too much current. I had this with a digital dash, i imagine it could happen with an analog as that is the only thig that changes that quickly with engine rpm. Even a coolant fault wouldnt respond that fast.
nipper replied to NameTaken's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXACME really shouldnt be allowed to sell those things.
Oil Filters...Smaller vs. Larger
nipper replied to Bluestone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have the room and clearance a larger high quality filter will do no harm as long as it has the same specs. Anything you can do to add oil capacity is a good thing.
nipper replied to NameTaken's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBattery and or battery terminals, how old is the battery
Intermittent Airbag Light UPDATE
nipper replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going with a bad clock spring. This is the only moving part which could come and go. An OBDII reader ONLY reads engine related codes, nothing else. There is a way to pull these codes but like the dealer said, the fault has to be present. What happens when you turn the wheel lock to lock or bang on the wheel or column.
nipper replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX99 is the year of bad spedo heads. You have two issues. One is the one of the two speed sensors, the other is the spedo. Take the spedo apart and clean the contacts (easy if you ever played with lego toys).
plow car ?
I wouldnt do this to a car personally. Plowing snow is very hard work on a truck, let alone a car.
Jack Stands
I use the three ton ones from sears myself. That is three tons per set which is more then enough for almost any car or suv. They are cheap and a good name
is this normal
Well if it hasnt been replaced in ages yes.
Engine Cuts out exactly at 4,000 RPM after 1st gear. Whats wrong?
nipper replied to kxracer741's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.howstuffinmycarworks.com/Fuel_pressure_regulator.html Also try this http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm
nipper replied to kxracer741's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomeone else want to talk him through this, i have a nerve injury and can't type well tonight.
Overheating oddities
nipper replied to havoc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never beleived the heater core theory myself, I just think those people never ever got all the air out of thier system.
