25
Everything posted by nipper
That was easy to find. 76 is the 2-4 brake timing solenoid. It is detecting either an opne or a short circuit. FOund it resistamce is 10-16 Ohms. Signal from the TCU should be higher then 9 volts. The proper way to test the output requires getting the car up to 40 mph. It seems like something straight forward to check as far as no surprises in the circuit. nipper
OH COME ON! It's tradition now, someone is going to teach thier sooby how to swim, it's just a quesion of whom. It's tradition! nipper
i need a link for directions so I can post it on the LISC site. Lets see if any of them want to get thier riceburners dirty . nipper
Ah ok. Outback spring rates are based on the Legacy, outback sport based on the imprezza. One car is much heavier then the other. I would stick with same weight class, There may even be physical size differnces. nipper
Not quite sure what you are asking nipper
Well i have to post a date on the LI sooby list as some of those folks want to come. nipper
SO there is a firm date then. nipper
a fool and his money. Sometime you have to pay a professional to repair what you can't, there is nothing foolish or wasteful about it. All i said was to diagnose it. nothing about fixing it. And actually its about 850.00. The logic behind the age of the car is silly. Is fomeone said you needed four tires at 500-600 bucks do you junk the car? Good luck whatever you choose to do. nipper
http://www.metacafe.com/watch/2546622/4x4_cooooooool/ Has an entire new meaning.
No no no thats not it. Do you have a bicycle with hand gbreaks around to look at. The but end of the cable sits in the both holes in the cam (roataion arm) on the hill holder. They way you have it the hill holder will drag the brakes and snap the cable. Loosen the hill holder cable at the clutch fork to get slack. nipper
