Scott in Bellingham
Everything posted by Scott in Bellingham
  1. New Product line Im introducing strut spacers in 1/4" increments , first set is 3/4" (20mm) http://www.sjrlift.com/index.php/catalog/lift-kits/0-1-1-2-lift-kit-ej-fits-90-99-detail also new Alloy rear 2000+ 2" shock spacers http://www.sjrlift.com/index.php/catalog/lift-kits/0-2-lift-kit-2000-252016-06-24-17-42-53-detail
  2. we want to see this !!!
  3. That may be better as the wife reminded me about a family commitment on the 18 th
  4. I feel 3" is to much on a all suspension lift, 2" max , you need a complete lift kit for 3" like this one http://www.sjrlift.com/index.php/catalog/lift-kits/0-4-lift-kit-ej-fits-90-99-detail
  5. Saturday June 18 I'm looking to hit walker again , had great time last Saturday and want to do it again, Basic car needs lift, tires, locked rear diff, you will need a Discovery pass , who wants in?
  6. http://www.sjrlift.com/images/stories/virtuemart/product/sjr%204%20ea71%20front%20rt.jpg cool pic with 6 bolt hubs and wheel spacers to clear rear torsion mount
  7. heres some pics https://www.facebook.com/photo.php?fbid=2025584421000449&l=75fef53308
  8. great day heres a pic https://www.facebook.com/photo.php?fbid=2024186584473566&l=5114f7332a
  9. Rained so were goin today be there before noon
  10. Use a 720 nissan t case or a Sammy behind the stock dr many have done it works well
  11. Lookin at hitting walker either Friday or Saturday this weekend anyone want to go?
  12. From your cat, it can clog up he exhaust and run powerless untill unclogged
  13. Put a couple us invasion stars on it in white or yellow
  14. your in Auburn? If you drive up to Bellingham ill get it right as I didn't have a 4x4 just a older fwd to look at Scott
  15. I have a set of recaps same pattern 14" rim I run, good tires for he mud
  16. With a EJ swap you only need to add the EJ system to run the engine, all the stock wiring is left in the car just tapped into to run the new engine and it's ECU
  17. I like the Maxxis bighorns, not the most aggressive MT but good all around tire 29" is about max with stock outback strut
  18. having worked in a Auto Body shop simple answer is yes the issue is how to get a hold of the spot that needs pulled out and how to hold the rest of the car from moving and getting bent , in the shop we had a framework that would clamp to the underside of the car at the pinch weld seams, it was always a issue on how to grab the bent sheetmetal, it almost always got mangled , usually a few cuts and a pull then rework the cuts and area and add a new part would fix it
  19. Your best bang for the buck would to find a complete doner car with good running engine, then you will have all the wiring and ecu, The intake exhaust and cooling , what type of drive trans system will you run?
  20. I've taken the cylinder out , installed a key I like and ground down the tumbler things till smooth, now that lock will work with your key, it's not as secure but works for my off roaders
  21. I've seen that much on the old ea81andea82 cars, ran with no issues, the wheel hub to axle play has been the only issue I've seen that matters
  22. Could be the linkage rubbing the driveline
  23. Strut blocks will need camber correct angle built in, I can make you a set
