174
Everything posted by lmdew
reseal Oil Seperator, Subaru metal ones are $12 0r so. locktite oil pump rear cover plate, new o-ring & reseal Cam & crank Seals New ngk plugs New valve cover gaskets
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
Check the voltage under load! Both leads to the battery, check Voltage Have some one try to start, check Voltage, you should see a voltage drop under load Move the positive lead to the Starter terminal, check voltage Have someone try to start the car, what's the voltage drop Move to the positive going to the starter motor, down stream of the starter contacts - repeat. Record the voltage readings, this will tell you where the problem lies. Some great electrical training at: www.brighterideas.com Load Pro tool is great, but if you can check the system loaded and connected you can get by without the Load Pro.
Good strap wrench, then take your ratchet & 6 point socket, put it on and hit the ratchet handle with a heavy hammer. If the flexplate is still on you can use it to lock up the crank. If option 1 or 2 does not work, you can pull a plug and stuff a bunch of rope down the plug hole to lock the cylinder as the piston comes up against the rope.
- 25 replies
- engine build
- EJ22
(and 1 more)
Tagged with:
After the new Subaru T-Stat is installed make sure the coolant is properly filled and system burped.
- 12 replies
- 1
- head gasket
- water pump
(and 5 more)
Tagged with:
Does your AT Temp light flash 16 times after you start the car? You might have Torque Bind. Have to ask yourself what caused the diff to fail? Once you drop out the Diff, you will see a 2 letter/number code painted in white on top of the housing. That gives you the ratio. You can also use the Trans # to get the ratio. Make sure the front and rear Diff's have the same ratio.
It un-screws. It also sets the bearing clearance so it has to go pack to the same place. - Wire brush and clean it the best you can - shoot it with PB Blaster or the like and let it soak - Center punch the trans and seal retainer so you can put it back to the same spot - Take your prybar or large straight slot and put it into the slots - Tighten it hand tight, so you know how much play was set for the bearimg. Center punch 2 marks - Try turning it out. If it does not move you can try a punch and hammer, but expect to break off some of the tabs - Remove the retainer, get the correct LH or RH Seal and o-ring from Subaru - Lube the oring - Install the retainer with the new seal already installed
Check the Computer. There are two single plug connectors under the drivers kick panel. Green Diagonstic Black ECU Codes, turn on the key and count the flashes. Check for Spark, if you have spark, the computer is getting the correct signals Put a little gas in the intake, does it start and run, if so you have a fuel problem Pull the side Timing Belt Covers and check to see if you are correctly timed. I'd do it in that order and you should have a good idea what the problem is.
