30
Everything posted by Turbone
I can see! Again. (Headlight conversion)
Turbone replied to Ever Victorious's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, where'd you get them and how much? Glad to know they fit in the XT's -
Help needed quickly! front crank seal
Turbone replied to Dylan86GL10's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EJ22 -
Why do I think the EA81 has more power than the EA82?
Turbone replied to markjs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It certainly could be the difference. There is quite a diff in weight between the 2. Your freinds 4wd could also be suffering from tuning issues also. -
Brake upgrades for 89 gl-10?
Turbone replied to 89turbowagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have the rotors cleaned(turned) and mic'd, they might be salvagable. You can get good quality pads to go around, they usually run up to $40 for a set (front or rear). -
Make sure you have the right seal. The part # is 8067 38070. -
You have removed the timing belt covers, etc? -
You may have to remove the cylinder to get the key out. Its a PITA, sorry. What you could do in the meantime is remove the plastic cowling from around the steering colume and on the right side of the ign you will see the relay. Theres 2 small screws that hold it on, remove these and it will come off. You can then turn the cars ign on and off this way and yes, start it also. I've been driving my 86 wagon like this for a while cause the cylinder crapped out on me. And I've been to lazy to fix it Replace all the plastic and tuck the relay under it but with easy access so you can turn it.
What engine is this Ea81 or EA82? I dont recall any metal rim inside either one but I also dont think the main bearing can slip forward like that either. How far out is the seal sticking? The ones that I have replaced on EA82's go flush. -
Might start by replacing the fuel filter. Drivers side firewall, make sure you crimp the hose or remove the fuse, its high pressure.
Test the circuit just before where the old trailer harness was and after it. This will tell you if the wire is bad at that point.
twin core radiator tweak
Turbone replied to thesubeguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The correct mod here is what WJM suggested. Replace the clutch fan with electric. It mounts right to the rad, and its alot easier to remove. -
Tim, check the date on his post. He's still around, I see him on MSN occasionally.
comin to the coast NEXT WEEKEND
Turbone replied to monstaru's topic in Meet n' Greet. Your USMB Welcome Center
Date and time? And I assume you mean the left coast? -
Get a JY coil and see if it still has the problem. Not common to have 2 disty's go bad in a row.
Aarons Auto Wrecking in White Center. He's in the phone book.
Dont forget petting. They like to be fondled
Spoken from a expert I think the Nissan T-Cases are tougher than the running gear on our Soobs. Just dont get to wild with the go peddle and it should be alright (for a while)
Check the rear diff oil. If its low it could be causing some binding. Same with the tranny.
gurgling sound behind passenger dash
Turbone replied to depleted's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It could be just air in the lines that run to the heater core. Its quite common in earlier Soobs. To rememdy this, remove the radiator cap (while cold) start the engine and slowly fill with water. You may have to let the engine run for a while to let the thermostat open, this will help release more air from the system. -
subarus everywhere & none to drive
Turbone replied to jeanine henson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Have you checked or changed the oil yet? This could be very important to you. If it looks like a milkshake, then yes, you have bit off more than you can chew. This would mean a head gasket change. Most of us that have been dealing with this type of engine usually change the waterpump and timing belts, and sometimes the front crank seal at the same time. Its unfortunate that you have spent alot of money on the car already. I hope I didnt rain to hard on your new car :-\
