Everything posted by Turbone
1985 Soob GL Turbo 4wd Sedan
After replacing the disty cap and rotor, timing it might help.
Hatch Patrol annual XMas tree run
I was up there, sick and all I'm paying for it now tho
If Bill is 6'6, then I'm 6'5 Anyone get stuck on the way down waiting for the tree cutters? It looked like a group of local(?) snowmobilers took it upon themselves to take down trees along the road if they looked like they were going to fall. I was behind our Ms Congeniality Forest Ranger and she was out helping move branches. So I guess it was approved, just rotten timing
EJ22 to EJ22T wiring problems
Neutral safety switch?
Got a few pics uploaded, I know theres more out there, so post em up.
welded diff on a commuter?
I've driven my Hatch over 1000mi on the hiway without a problem. Of course the short wheelbase has helped, but I try and drive it so my turns arent too sharp.
We could use some firewood up there, bring some if you have it.
Got my winter tires mounted today.
Dang Bill, thought you fell off the face of the earth It will be good to see you again, hope you can make it. I did make it up there today and Jesse was correct. The road is closed at the top of the Snow Park. I did not care for the snow conditions at all today. The snow was only 3-4in deep, but it was slush on top of ice because it rained last night. It was slick as toad snot and I was sliding all over :-\ BUT, I talked to a Ranger that was there and she said they planned on getting the road plowed up to the big gravel pit area. This isnt where we usually stage, its a bit further down. If we use this area, we will be sharing it with a lot of snowmobilers with their trucks/trailers. If the weather continues to be nice, the roads will improve and we might be able to make it up to the regular spot.
EA82 engine help
What? You just posted about setting hydro lifters. EA81 and EA82 hydros are basically the same. http://www.ultimatesubaru.org/forum/showpost.php?p=975321&postcount=2 Dont you think he should have adjusted the one he replaced at least? And come on, the engine got hot enough to melt the timing belt covers. You dont think that warped the heads?
EA82 engine help
Well, you did a number of things wrong. 1. You should have had the heads milled to return them back to a flat mating surface. If the engine had been overheated enough to melt the covers, it certainly warped the heads. 2. You should have used new t-belts. Did you know how many miles were on the ones you re-used? 3. You should have but new seals in the oil pump. Not doing that could be why it seized. 4. Did you readjust the lifters after you re-installed the heads? Now, go back and do it all over again. I bet you do it right this time
OK, how does this winch work?
Those crazy Russians will try anything
Fender flares
Its been done before.
need HELP fast on EA82
Sadly, when you buy something off CL, its buyer beware. Always do a thorough inspection of the item and if you arent sure what to look for, have a friend who does go with you.
Anyone Drift A Wagon?
Click on the Shirley link, its a group of guys in Iceland. It looks like tire came off the rim in that pic. You cant drift a stock EA82 GL wagon, it just doesnt have the power to do it. Anyone can throw it sideways into a corner, if you have the cajones. You need a transplant, like a EJ20 or better to get the power.
'84 GL Digidash fun
I no longer have my 84 FSM, which goes into detail on the "test program". Maybe the digidash guru carfreak can look it up for everyone. I do have a troubleshooting schematic tho.
I may make a run up this week to verify what Jesse found. The Brat shouldnt have to big a problem
'84 GL Digidash fun
I think thats the start up from factory sequence. Theres a way to reset it so that it displays normal. I'll need to check the FSM to be sure.
Would love to see you guys, come on down!
Scoobyclimbs Outback makeover
I like everything except for the wheel-tire combo. Dainty and gnarly together just doesnt look right to me. How did you extend the spare tire basket out?
All hail the Subaru!!! Best snow vehicle EVER!!!
Had another Subaru moment yesterday, shared it with a 05 WRX too! Pulling out of the Walmart parking lot, the road goes uphill a little. Just enough to get a minivan turning right stuck The WRX was 2 cars in front of me and when the light turned green we both pulled out at the same time and went around the van. I came along side of him and his GF and him were both laughing and he gave me a thumbs up.
Pacific Import Auto. They are in Spanaway on Pacific/Hiway 7.
EA82T + Digidash questions
Yeah, theres a tab at the end of the DP, but there is one thats on the side to bolt to the trans also. Btw, I've never used that attachment point.
1988 GL EA82T Rebuild HELP
I may have missed it, but are you getting spark from the coil? Spark to the plugs? I just had a issue with my Brat that it was getting spark from the coil but not to the plugs. Turns out the coil spark wasnt hot enough.....ie, a bad coil.
Some brilliant Seattle drivers.
