Turbone
Administrator
Everything posted by Turbone
  1. I'm already planning on changing the look a little. A metallizer is available and I might change the color of the wheels some.
  2. Guess I can finally post a pic of the finished product and before heading out to WCSS yesterday morning.
  3. Can someone save me a spot in the Old School section? I might be running late
  4. More on this later.... And then theres this empty spot.....
  5. Matt in AK, Subaru Junkie and maybe a few more
  6. You will find most of your questions answered in this sub forum. If you look for threads started by me, you will the write up about the EJ22T swap I did in my 89 RX. If your smart, you will leave the engine stock as it has plenty of power for the RX.
  7. I'm going to miss Ed...a lot. Been wanting to reply to this all week and still cant really put my feelings into words. Losing good friends is a fact of life the older we get and makes us aware of our own mortality. And it sucks.
  8. Oops, without actually tearing into the trans I'm sure you're correct
  9. I have ordered many items from RA, never once have I received the wrong part. Got to be sure what you are ordering. as most parts houses usually get mixed up between the EA81 and EA82.
  10. Like Ski said earlier, the lifted rigs with a divorced t-case use RWD. My lifted hatch had this setup, but I went thru 2 trans because I stripped the teeth of the ring gear. With the EJ trans, the center diff can be welded which allows all power to go to the rear. I'm going to use this setup on my upcoming project.
  11. Why not just call them? Ken (or John) can answer all your questions.
  12. Correct on the front struts. The plug for the rear is under the back seat I believe (its been a while since I've had a gen 3 wagon)
  13. The fuel prices in Oz have ZERO bearing on what we pay in the States. Sorry
  14. I made some brackets and mounted mine where the turn signals went (now located in the cornermarkers)
  15. Not sure if it will work or not, guess theres only one way to find out. And all you need to do is replace the stock up pipe flange with one for a TD05
  16. Nope, swapping x-member and suspension is not a feasible option. But theres other ways to skin that cat. Theres several threads in this forum that relate to this swap, start doing your research. http://www.ultimatesubaru.org/forum/topic/107157-my-ej22t-swapand-a-few-issues/
  17. What is that made from? Looks like a old loaf of bread.
  18. Everyone needs to stop the pissing matches. If you think theres a issue, please use the Report button to bring it to attention of the mods.
  19. This is Garner's old Brat, he passed away a few years back. Then another guy bought and posted frequently here for a while about getting it running, progress etc, then he dropped off the map about a year ago. Now here it is again. Hope you have better luck. Unfortunately, the old site lost the photo album. http://www.ultimatesubaru.org/forum/topic/13101-ea82t-in-gen-1-brat-its-in-there/?hl=garner
  20. It may be because you have a open front diff and it wont lock in park if the axle is broken on one side. A lot of times a parts store will sell reman'd axles and this will happen (early breakage). Get new axles for the front and make sure the axle nuts get torqued to the correct specs.
  21. Might move it up a few degrees to see if it stops. A few isnt going to hurt anything but might get rid of the ping.
  22. A few thousand more miles and I can add the 200k to my Foz. Not sticking anything like that on my RX.
