Everything posted by Turbone
Work progress
I got some work done on your stuff too
Work progress
Get over here and mud it for me :-p Yes, of course it will be ready. Got warmer weather coming all next week, so I can get everything painted. Sanded....repainted....I hope thats it I have to be sure to take my time when putting it all back on, dont want to scratch anything. Then I need to detail/buff/polish it all.
Work progress
Stage 2 completed. Stg 3 - Cut the hole for the "new" scoop. Stg 4 - Fill and primer.
Turbone's Wheels..
First time they have been on a wagon (I think) and it looks great
WCSS 11 Date and Location!
I'm leaving Fri also, but not sure on the exact time. Once we get closer to the Show time, I should know for sure.
Work progress
Yeah, the lip is stock. I know where I'm going to set the next fire The wiring is the same, but nothing else is. The holes dont line up and the pins that the screws go in on the mirror are to long and need to be cut. Then the triangular plate needs to be bent to form to the RX door.
Work progress
Its not that bad But it has ran for over 2yrs without mechanical issues. A bit longer than other modified (or stock) EA82T's
Work progress
Ziiing!
Work progress
I do every year about this time. Hope it wins again in its class
'82 Brat: Solid Axle Build *** DONE! :) ***
Just a heads up on the EA81 PS your using with that tire size. Mine heats up after a short time with 30in tires. It might be a good idea to add a small cooler to it (which I have yet to do on mine ) But I cant wait to see some action shots
Work progress
Already been done. Wire brushed all the rust off, hit it with Rustoleum primer then used some industrial undercoating. Russ, do you think I will still have low spots even if I use the filler?
AWD Conversion
Learn to drive better
Work progress
loud
Work progress
Ah, you noticed Those need repainted too. Had the Hellas for a while now. The wheels are 17" ADR Sokudos. Repaint Seems like I do it every year about this time. Thats what filler is for, right? I'll try and feather them all out first tho. You betcha
Work progress
After getting some parts a week ago for my RX (thanks to those involved) I've been steadily getting it prepped and painted and ready for the Show. The fenders are almost done and the hood is almost there on prep. I have some other stuff in the works also, but thats going to have to wait till the Show Lots of rock chips. This piece goes between the bumper and headlights and is pretty rusty. It should look new when I'm done.
Bye bye RS
Turbone replied to bratman18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSad to see it go, but family comes first. Get some pics of the Forester.
EA82T Warm Starting Problem (CTS) + EGR S. Valve Issue = SOLVED!
Sorry for the fuzzy cell pic...
how to seat your torque converter , by mnwolftrack
Turbone replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^^If this is a link, its not working. Neither is the green color, can barley see it. Ditto :-\
I'm sure I do, I just have to find it
I looked at one of my spare manifolds and the solenoid only had one end hooked up. And that was to a metal line above, I assume to the EGR valve. The other end should go to a fitting thats in the manifold. That looks like a plastic cylinder that has a couple of hose fittings off of it.
Eureka!
Turbone replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere were actually 2 new models. The police car was a Impreza WRX and the other was a WRX wagon that Fargo was driving (replaced his old car-a Dodge Aries convert). Fargo will be installing his AI (Tiffy?) into the new WRX, so things could get a interesting tangent.
side project...........
Will it be ready by the 20th?
Evans Creek Meet yada yada
I can help you out with that, get a hold of me.
Documented: The 1970 FF-1 Project car...
Manifold looks fine, its mating flush to the heads.
Glad that worked out for you
