Everything posted by subiemech85
seal ring also used on cadillac 4.9 ht4900 77*c seems a bit cold
1978 Brat! Help
subiemech85 replied to devildog78brat's topic in Historic Subaru Forum: 50's thru 70's
adjust valves weber electronic dist. and alt. NGK bpr6ey-11 ea81 not worth the trouble, not a direct swap, only 4 hp difference in stock form ea71 is a happy engine when tuned properly -
thermostat what engine??
does your fan switch have one or two wires??? if it has one wire, is the radiator grounded, if not, it won't work if it has two wires, make sure the radiator is grounded one wire system: short wire to ground and fan should turn on two wire system: connect both terminals and fan should turn on iirc yellow and blue wires all below is just a guess, but a good one: Pressure switch ( main Fan Control) is for the AC system Sub Fan Control Relay also with AC Sub Fan relay is the critter to look at
Headlight Guards.
subiemech85 replied to Dantes Inferno's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i was more interested in the wheels -
replace the wires black tape
yes, the flapper door system is different, and not swappable to the hot wire system I also would like a copy of the manual jkrhodes @ 37.com
'87 gl-10 fuse # 10 blows, turn, backup, 4wd
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The HAZARDS work with the green wire disconnected BUT the TURN SIGNALS do NOT work with the green wire disconnected connected the "ground" lead to the green wire, and "hot" lead to the load side of fues, and measured 14v with engine running on the led light battery and charging system tester as seen in the following link: http://www.vehicle-wiring-products.eu/VWP-onlinestore/testmeters/photo/53460.jpg :-\ -
with turn singal connector disconnected and pin # 10 connected, the fuse blows also noticed when flashers are on the right side is dimmer than the left One problem that is consistent is the 4wd selector switch does nothing, but it did work the one time the signals worked when the headlight relay was removed back-up light does work -
DesMoines IA meet Sat. 29
subiemech85 replied to subiemech85's topic in Meet n' Greet. Your USMB Welcome Center
SNOW that's why we have subarus :-p -
well, here's the proposal..... We meet @ Boston’s 12401 University Avenue Clive, IA 50325 PHONE: (515) 440-6051 time is flexible, try to arrange it so that we can maximize attendance http://www.bostonsgourmet.com/?q=bostonsgourmet_restaurantpages_clive http://desmoines.metromix.com/webtools/print/restaurants/pizza/bostons-gourmet-pizza-restaurant-west-des-moines/467230 this is a follow up of http://www.ultimatesubaru.org/forum/showthread.php?t=93065
I am only trying to post info that will make solving the issue easier, it is also getting on my nerves decided to disconnect EVERY connecter until the issue goes away after disconnecting 5 relays, and many connecters, finally one made a difference listed in manual as F65 white, 21 pin, connecting to i6 of instrument panel wiring harness, 7 across and 3 down behind fuse box and on same bracket as the connectors F66 and F67 page 9 section 6-3 fig. 10 front wiring harness MPFI model the offending wire is in position #10, has single green wire, no stripes car built 2/87 using book printed july '87 -
Vanishing coolant leak.
subiemech85 replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hardest leak to find list: heater hoses, abraided by clutch lever, impossible to see rubbing little booger manifold hoses waterpump hoses rad drain cock and sensors rad cap rad "header" leaks leaks between hose and pipe -
Mystic 15W50 cleans the engine very well, when I opened it up to swap heads, looked like someone polished everything inside, no usual yellow and brown crud
MilesFox has done several how-to's disconnect from trans stubs before removing from wheel end
oiling the underbody of a car
subiemech85 replied to bheinen74's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my self-oiler broke and swapped in a self-ruster side panels behind rear wheels tend to rot away easily nice car with almost no rust, and want to keep it that way may try spraying diesel, had a vw pickup with leaky fuel tank seal, no rust back there -
just did some googling and found waxoyl http://www.robisonservice.com/articles/RonR_waxoyl.asp http://www.cumminsforum.com/forum/auto-body/49819-rustproofing.html
