Everything posted by subiemech85
heat the surrounding area with a torch, use a stud extractor make sure you use GOOD VICE GRIPS NADE IN NEBRASKA
How to tell if the turbo is not working
subiemech85 replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you should become familiar with "turbo whine", even at idle -
DIY EA81 Tranny Mounts
subiemech85 replied to GeneralDisorder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the link at the top does NOT work does the "super weatherstrip adhesive" work good? I bught 08008, black, 5oz. how many tubes are needed to do a mount? http://products3.3m.com/catalog/us/en001/government/innovative_solutions/node_GSN04SFBB0gs/root_GS3RBW6QFVgv/vroot_31S2JJ7584ge/bgel_GSYHNJB2MYbl/gvel_J80MWCFZCDgl/theme_us_innovativesolutions_3_0/command_AbcPageHandler/output_html -
Would the half shaft...
subiemech85 replied to [HTi]Johnson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have an ea81 84 that you don't have to shift at all!! why not go with an ea82 5 spd dr????? -
new GL owner with some Qs
subiemech85 replied to dziuggy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
replace t-belts and h-gaskets after they blow -
Oil Cooler adapters,permanent avalibility!
subiemech85 replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sold! -
Pictures from CV axle replacement work.
subiemech85 replied to MPVSubaru87's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there is another way that I have used that takes 3 hours both ways, but that included stoking the stove every 30 minutes while the snow kept falling, and the wind kept howling, and I kept shivering there is also the easy way that includes pulling the engine, transmission, rim, and finally axle, but save that for later today the bolt marked "no touch" I had to!!!! enjoy :biggrin: -
AHHH Brat is making me mad *UPDATE!!*
subiemech85 replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you need to adjust the valves AFTER you rebuild the engine check the oil pressure sending unit with an ohmmeter, the tool that measures resistance install a mechanical oil pressure guage, and skip the step above^ install new 15W40 oil, and a new filter and drain plug gasket after breakin it is also good to make sure you have the correct NGK sparkplugs bpr6es-11 -
what does it take to swap rear dif hanger from ea82 wagon to ea81 brat?
I believe this is what you are looking for: http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29dd8b7a4f46.89471656/&FileType=Image&File=New%20Image.JPG -
EA82 parts swap into a EA81?
subiemech85 replied to spideyz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
so does the spare tire support, and exhaust -
EA82 CB mounting
subiemech85 replied to Flowmastered87GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I liked it when I put it on my "luggage seat" Miles used long bolts that stuck through the roof -
that's Wi-Fi Hijacking
ea81 LOUSY gas mileage?
subiemech85 replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
and I can't figure out WHY???? it used to get 24mpg -
1986 GL sedan alternator problem
subiemech85 replied to vhenem's topic in Old Gen.: 80's GL/DL/XT/Loyales...
run the car wirh the alt disconnected, it is probably the distributor bushings going bad, search "jumpy tach" -
why does the 83 ea81 california emissions feedback carb wagon get only 16 mpg?
monster ea82 wagon update!
subiemech85 replied to bushbasher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you've got that but ugly fwd selector, which started in 86, otherwise nice -
I now go to combine demos, they are lots of fun it's alwaws a challenge
Brat t-top tinting ideas??
use stickers and wall art, be creative, kid's hand prints -
remove the rotor be wary of swap meets when a guy buys a distributor for YOUR car!! true story!!
My Car Tried To Kill Me!!!!
subiemech85 replied to Vegablade's topic in Old Gen.: 80's GL/DL/XT/Loyales...
replace cap, and thermostat remove the black o-ring from the green overflow bottle cap check hoses -
the jy in WAUKEE, WRENCH AND SAVE, yeah rite, thinks their 86 xt in an 86 gl, and wants $150 for the mpfi, and $100 for the fwd, and seat covers are $15, and shift knobs are $5, and I dickered them once 50%, bought the distributor splash shield for $5, told them that's all I have
