ocei77
10
Everything posted by ocei77
Thanks for the reply. After more research on opposed forces, it seems that the DS exhaust is once piece from the manifold to and through the cat at the y. The cat fitting is either swaged or welded under the shield. ala the front cat on the BL series. So it seems I'll have to remove the DS manifold and the bolts that joins the left and right exhaust sections.to get this replaced. I just thought I was missing something that I knew you would know of. Thanks again. O.
Trying to help a friend replace his rusted exhaust. The cat at the Y has a busted seam where the flange used to be which now has a 3 ft section of straight pipe with u bolts. I have someone who I can get the cat from. (The 3rd cat at the Y). I see that it only has one flange from the PS, while the DS seems to be a push fit. How is it secured, or would it be better to just get the whole exhaust from the manifolds back. TIA. O.
10 years or 100K miles. Whichever comes first. This means all the idlers also. O.
- 18 replies
That's what we're here for, to help each other. O.
- 8 replies
- Instrument Panel Pad
- Dash
(and 8 more)
Tagged with:
you don't have to pay. Go to 2nd page of New Gen FAQ sticky under my name there is a link to all Subaru models starting with jdm.........This has the BL series you are looking for. O.
- 8 replies
- Dash
(and 8 more)
Tagged with:
Make sure the cams bolts are tight first. Remove belt and compress tensioner. Reinstall tensioner and realign belt. Push down slightly on belt to hold position and release tensioner. All should stay in alignment at this point. Put large screwdriver into flywheel teeth, so it butts against the inspection hole. Have some else hold the brake while you tighten the crank bolt. O.
- 6 replies
- 99 Legacy outback
- Oil pump
(and 2 more)
Tagged with:
More than likely it's the front seal, not the oil pump itself. You can remove just the seal (careful not to scratch the shaft) and replace. it would take another half hour or so to pull the pump. Check the screws on the back, clean and dry both surfaces and reinstall. Now would be a good time to replace the t belt etc if its due to be done soon. Get the o ring for the pump from the dealer. Cost me less than $3 two weeks ago. You need a good sealant. I prefer anaerobic, for it doesn't set up in air. The FSM is available. In New Gen FAQ sticky. 2nd page under my name. To give yourself room to work, all you need to remove are the fans, not the radiator. O.
- 6 replies
- 99 Legacy outback
- Oil pump
(and 2 more)
Tagged with:
95 2.2 oil pump
ocei77 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
replace the o ring and front crank seal, use sealant on the pump. Don't overdo it on the sealant. Torque spec on the bolts is only 4.7 ft lbs. O. -
Not that hard, just not as easy as disc. Buy hardware kit. You may not need it, but it's better to have in case you do when all is apart and you can't go get it. The springs and the metal discs are what may be needed, Back off the adjusting screw so the pads are not pushed up against the drum. Have 2 m8x1.25 bolts about 2 in. long available. If the drum doesn't come right off, use the bolts in the threaded holes to push them off. If the drum is still hanging up as it comes off, back off the adjusting screw more. Get FSM from New Gen FAQ sticky. 2nd page under my name. Needle nose grip pliers are great for pulling the springs into place, unless you want to buy the tool to do it. O.
