ocei77
10
Everything posted by ocei77
Charging Help
ocei77 replied to ocei77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've checked the grounds and cleaned up a few. The battery was charged a few days before the real cold snap here. Checking now, the voltage is less than 12. So I am getting a new battery and will advise after I get it to the vehicle in question. The alt was taken to Advance Auto and tested. Thanks to all for their help. O. -
Well I guess I didn't remember correctly lol . If you can/are willing to put a small hole in the ceiling, find a place where the beams cross and put a length of chain around it and secure with a nut and bolt. Of course the car has to be able to be centered under it. From 2004 until now, along with a comealong ,is how I've pulled at least a dozen engines. O.
Whenever I am ready to install an engine, I put a small piece of 2x4 on the tall side(actually 3 1/2) under both sides of the tranny housing flush with the edge. This allows me to catch the dowel pins at the same time clearing the engine mount studs so I can push the engine forward and catch a bolt. After I catch all the bolts, I knock the pieces out and lower the block right into the cradle. O
You can check cars101.com for width etc. Outback struts would raise your center of gravity and advsersely affect how hard you could corner. Repalcing your worn suspension bushings would help get the ride quality back. Lowering on H&R or similar springs with new struts would help. Adjustable coilovers would let you tailor the ride height. 17" rims and tires would help to close the gap and in that case, 225/45 is the widest tire you can use w/o rubbing or rolling on legacy struts. see http://www.rimsntires.com/specspro.jsp Hope this helps. O.
See attachments. Go to 2nd page of New Gen FAQ under my name, link for FSM. Coolant temp sensors are not that expensive and in this case I would even grab one from a pick and pull A scanner with live mode would read temps O .Diagnostics Radiator Main Fan.pdf Diagnostics Radiator Sub Fan (With AC model only).pdf
- 1 reply
- 2
Brakes
ocei77 replied to briankk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Any 16" Suby wheel will work. The offset is either 52 or 55.. O.
