Everything posted by ocei77
Clutch release bearing
ocei77 replied to Mark3521's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck with supplier. I just had to return a Sachs clutch for the opposite reason. My replacement (from another vendor) was in the same box and part number but had the correct (smaller) bearing. In addition the pressure plate was @ 1/2' to small in diameter and would not hang on both pins. I have an 05. O.
09 Legacy broken piston
ocei77 replied to JohnCT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXget FSM here:http://jdmfsm.info/Auto/Japan/Subaru/ Only remove the outer circlips. Use a thin stiff rod and you can snake it past the opposite rod and tap out the king pin. ie: past 3 and tap 1. 4 and tap 2. Make a drift out of 3/4" dowel to install. The block has markings to say whether the piston is an A or B. Spec sheet gives dimensions. Put pistons back into cylinder they came from. Make sure piston is installed with dots or markings facing the front of block. O.
2010 forester heater core replacement?
ocei77 replied to Mallory's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFSM here: http://jdmfsm.info/Auto/Japan/Subaru/ O.
1998 Legacy GT coolant change FAIL
ocei77 replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChange the water pump. If the T belt is due might as well do it with new idlers. When filling the car start with coolant in the upper radiator hose. Then the radiator. With our t stats on the bottom of the block, you will never fill it by just adding to the radiator. O.
Wheel Offset Difference: '01 Forester / '08 Impreza
ocei77 replied to Tony Cortado's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShould be no problem. To check see:http://www.rimsntires.com/specspro.jsp O.
P0420 code is on , just exactly is Bank 1 ?
ocei77 replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBank 1 is drivers side. Sensor 1 is the first O2. get fsm here: http://jdmfo/Auto/Japan/Subaru/ Do you have the early pzev car with three cats and a total o 5 O2 sensors? Doesn't change anything, just info. Engine info is same except for the exhaust. O.
Need Advice to buy
ocei77 replied to Cam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBank 1 is the front sensor O.
Need Advice to buy
ocei77 replied to Cam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe p420 is generally a benign code that usually requires replacement of the front o2 sensor and or is the result of an exhaust leak. Rarely but sometimes is needing a cat replacement. O.
Hood style
ocei77 replied to Turbolaggin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo. It has to be a legacy/outback from the same generation. ie 96-99 O.
That miserable &%@^#*$ EJ25D EGR tube.
ocei77 replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can probably find just the right spot to set the vise grips enough to break it free. Take some PB with you. Having to work on them constantly, I cut the 15mm side off so it would give me the ability to move more. O.
03' Baja - 17" wheels?
ocei77 replied to Typhoon-22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXuse this to check: http://www.rimsntires.com/specspro.jsp O.
Aftermarket stereo wiring issues (2003 Baja)
ocei77 replied to Typhoon-22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis should help •Yellow - 12V Battery / Constant •Red - 12V Ignition / Switched •Black - Chassis Ground •Black / White - Factory Amplifier Ground •Blue - Power Antenna / Factory Amplifier Remote Turn On •Blue / White - Factory Amplifier Remote Turn On •Orange - Dash Light Dimmer / Illumination •Orange / White - Dash Light Dimmer / Illumination •Orange / Black - Dash Light Dimmer Ground / Illumination Ground •Brown - Mute / Not Used •White - Left Front Speaker (+) •White / Black - Left Front Speaker (-) •Gray - Right Front Speaker (+) •Gray / Black - Right Front Speaker (-) •Green - Left Rear Speaker (+) •Green / Black - Left Rear Speaker (-) •Purple - Right Rear Speaker (+) •Purple / Black - Right Rear Speaker (-) This is the Subaru side Suby radio wirirng.txt
Crank Pulley Ej25 vs Ej20
ocei77 replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif the triggers are in the same place and have same count use what you wish. O.
Tire Circumference?
ocei77 replied to Mike104's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe. He may have the Fwd fuse in permanently. Other yes indeed.
'98 Legacy 2.5L N/A will not start after rebuild
ocei77 replied to 98GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe wires are on the proper plugs? Can't quite tell from video
2001 outback headgaskets torque procedure.
ocei77 replied to sirtokesalot's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee attached. get full fsm herehttp://jdmfsm.info/Auto/Japan/Subaru/ O.: cylinder head assembly.pdf
EJ25 Engine Swap
ocei77 replied to Subberman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can install the heads from the 07 onto the 05. Don't know of any other workaround. O.
Factory service manual
ocei77 replied to Basket_case's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just used the jdm link and it worked, Try again O.
ocei77 replied to Basket_case's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy bother. They are free. http://jdmfsm.info/Auto/Japan/Subaru/
Is there a way to tell which ej25 engine I have with no VIN number?
ocei77 replied to Van Quixote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a vin stamped on the block. A flat surface on the pass side just below a tranny bolt hole. Will probably need cleaning to see it clearly. O.
Frankenmotor question: Will an ej22 from 1997 Legacy work with a 2002 ej25 for a Frankenmotor?
ocei77 replied to Van Quixote's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDOHC is probably an EJ25D. The DOHC setup is also used on the Turbo blocks. There is a vin , stamped or imprinted on the pass side on a flat above where the axle fits in the tranny, Probably needs to be cleaned, 1oth digit gives year. O.
Big problem with my 98 SOLVED see Last post
ocei77 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck under the dash for the wires attached to a button or switch. May have been moved by previous owners. I ran into one with the wires just dangling. O,
1998 Legacy coolant hose
ocei77 replied to odonian's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe hose goes from the throttle body to the crossover pipe. It acts as a return line that goes from the bypass pipe to the TB. Its designed to keep the throttle body from icing up. Some people in hot climates just bypass or plug them as icing is not a concern for them. It will show up in service procedure for the TB. Use an online dealer part cat. to look up the actual part no. if you need it. The dealer should be able to get it w/o a number. Its on all the EJ22 and EJ25's at least up to 06. O.
Used parts standards
ocei77 replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry car-part.com. Lots of listings and they will ship. O.
Newbie questions
ocei77 replied to SubaruMom22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe OBD port is fused IIRC SBF fuse #4 in engine bay. Check it. Are you plugging it in AFTER you turn the key? If not you will get a link error. Here is link to FSM: http://jdmfsm.info/Auto/Japan/Subaru/ Wiring etc is in there to check your lines. O.
