24
Everything posted by 86BRATMAN
84 Subaru GL non turbo transmission swap
86BRATMAN replied to JordanFelder88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That I'm not sure, I haven't had to deal with a bad one in a very long time.- 3 replies
- transmission
- swap
(and 2 more)
Tagged with:
Ea81 hardtop coupe window gaskets.
86BRATMAN replied to 86BRATMAN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, it is. I finally broke down and went to look at it lol. Got it for much less than he was asking. I need to make a ride thread one of these days. -
A couple of you may already know that I'm back in the ea81 world these days. Been a long time since I found one solid enough to purchase out here in VA. Anyways, I have an 84 ea81t coupe now. And like many of these 30 some year old cars the window gaskets were deteriorated pretty badly. The rear especially, all corners were leaking with any amount of rain, or a simple car wash. So much so that I've owned this car for slightly over a month and have only washed it once. I started searching immediately for a gasket solution, which many places led me to believe does not exist anymore. Flash forward a couple of weeks, I come across a seller on Australian eBay that has gaskets for what he lists as fitting the Subaru Leone 1800 GFT 2 Door. Many emails were exchanged, with detailed measurements and pictures of my car for reference. As it turns out, he has the gaskets. And is willing to ship them to the States. And that's the rear installed, 100% dead on fitment, the coupe specific window trim will fit in these things perfectly when I'm done blacking them out. So if your hardtop coupe needs window gaskets and you think there is no option available, look no further. Contact www.newoldcarcompany.com.au for your replacements.
Sounds like the governor gear to me.- 3 replies
- 1
- transmission
- swap
(and 2 more)
Tagged with:
Really loving the progress you've made man. Really an inspiration. Makes me realize I need to stop being lazy and start a new build thread.
- 261 replies
- 1
- Restoration
- Coupe
- (and 4 more)
What to do with an old Subaru XT in good condition?
86BRATMAN replied to RAD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://forums.nasioc.com/forums/showthread.php?t=2319484 -
You'll need xt6 parts, legacy hubs are different. If you can find a 4wd xt6 you can use the complete rear trailing arm in place of your fwd rear arms.
- 1 reply
- 1
I had an 88 xt, 5 spd, push button 4wd, non-turbo, that had factory air suspension. It was easy enough to convert to standard suspension. It never had any trouble running highway speeds, or jaunting up the mountain roads around here. -
You do need the avls components. But you cannot use those heads on the ej20 shortblock. Best bet is to just get two jdm ej25s and go that route. Using the ej25 heads on the ej20 will lead you to another engine replacement in short order. I've been doing this stuff for 15 years, guarantee I've built more motors than your engine importer.
EA81 Radius Rod bushings
86BRATMAN replied to Splinter's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Superpro makes polyurethane replacements for the ea81 radius rod bushings. -
The biggest reason that there arent more dohc swaps in the ea81 chassis is because of the narrow frame rails. The only engines that fit without body modification is the 90-98 sohc motors. This does however include the ej22t from the 91-94 legacy sport sedan and touring wagon.
They also ignore messages asking about shipping to the US, I asked several days ago if they'd be willing to send a pair of front and rear gaskets for the ea81 coupe over here for myself and a friend.
- 73 replies
- Ea81
- windshield
(and 8 more)
Tagged with:
Definitely interested in a coupe rear window gasket.
- 73 replies
- Ea81
- windshield
(and 8 more)
Tagged with:
Updated oddcomp's MS n' EDIS fuel/DIS
86BRATMAN replied to a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm considering the MS route with my newly acquired ea81t coupe. Any recommendations for a setup or options with this thing? -
11044AA642 04-06 sti is the head gasket of choice for this build. The ej251 gaskets are crap, and will blow in fairly quick fashion.
- 4 replies
- 1
- head gasket
- sealant
(and 3 more)
Tagged with:
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
86BRATMAN replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Still very interested in a pair. Hope this is still in the works.
