15
Everything posted by bratman18
98-2000 2.5 was 2 completely different style ej25 motors. I think maybe you should research a bit more before you offer advice to others. 96-98 was dohc 2.5. This had internal head gasket leaks. 99 Legacy's also came with the dohc but had a phase 2 block which had a better lower end. Other models in 99 got the SOHC 2.5 along with all 2000+ non turbo subarus. Those had external head gasket leaks, primarily oil leaks, but could leak coolant too. Those are usually good to go once he gaskets have been changed once, as long as MLS gaskets are used and attention is paid to detail. They claim o have fixed the head gasket issue but even some of the newer ones are leaking. I personally would own one no problem, but pay attention to coolant level, and if they leak, have a subaru mechanic replace them.
Pretty sure the Gr2's were changed to the Excels, at least in some applications. That's what I heard anyway. But they're still the same strut.
Whining noise in all gears in 1994 Loyale
bratman18 replied to Kris79's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check gear oil? -
EJ20 vs. EJ22 vs. EJ25 in an EA82 body-Opinions?
bratman18 replied to thesmith's topic in Subaru Retrofitting
With an Ej22 you can drop that in with the necessary adapter plate and re drilled flywheel, and a wiring harness essential and basically. Be good to go. But with a turbo motor there's even more work involved. And the ej20 is not lighter than the ej22. Especially after bolting on the turbo and added exhaust etc. And I wouldn't trust the rest of the suspension or driveline if you dropped just the ej25 STi engine in. Your best bet would be to buy an entire ej22 car for your swap. That way you have everything you need to do the swap. -
Not the rear.
05 forester front seats into an 85 gl wagon
bratman18 replied to shoebee2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Forester seats sit high in an impreza, so chances are they're going to be pretty tall in a GL. Might have to mod the rails some. -
Extra length DOJs for Brumby/BRAT?
bratman18 replied to Phizinza's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pretty sure you can use ea82 stuff for the front too. You'd have to use ea82 knuckles and I think tie rod ends too. -
"BOUGHT" A 1983 GL Brat
bratman18 replied to buckkiller's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pretty sure those are Calmasters. Nice brat! -
1992 loyale axle nut backed off , around 80 km/h
bratman18 replied to *Rust*'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
We have the same issues with rust here. My impact gun will usually shear off the rusted pin. -
96 LX Impreza Coupe swap to manual from auto
bratman18 replied to awcforever's topic in Subaru Retrofitting
Weird. I have swapped drive shafts and rear diff from impreza to legacy to forester, anywhere from 96 to 04 and they've always been the same. -
Input flange should be the same. All the r160 rear diff were the same,the r180 has the bigger flange. Those only.came in STi's.
