16
Everything posted by Crazyeights
Looks great as always Nico! Thanks for the update.
EA81 adapter for oil pump?
Crazyeights replied to CarsonGrey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The EA81 oil pumps are SO EASY to break when removing them. Be VERY careful when removing it and you can probably just reseal it. Don't use a hammer or mallet to remove it. -
Oil Pressure Gauge and Idiot Light Wiring
Crazyeights replied to G3.Spiffy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The EA series engines run very low oil pressure at idle. This is even stated in the owners manual. The factory gauges are not accurate at all either. What I would do if your concerned about it is hook up a test gauge and monitor the oil pressure from a cold start until the engine is warmed up. Once you know what the pressures really are you can train yourself to use the factory gauge. -
1979 DL Wagon Project (91EJ22T)
Crazyeights replied to 79DL's topic in Historic Subaru Forum: 50's thru 70's
My EJ22T is completely stock. Just a valve grind and reseal. Here is a picture of everything that comes with the factory AWIC setup. As you can see it has a separate small radiator that has to be mounted as well as coolant lines, pump, etc. I found front axles that didn't have to be shortened. I am pretty sure that they were from a FWD '93 Impreza. -
I have an EJ22E in the car right now to keep it mobile. The EJ22T is on the engine stand right now almost completely assembled. The turbo wiring harness is all stripped and finished. I used the engine cross-member from an '89 GL-10 turbo wagon so the exhaust will clear without any cutting. The radiator is stock Loyale. The 5 lug conversion is all done. I used '93 Impreza FWD hubs, struts, springs, and knuckles with Loyale top hats and EA81 outer tie rod ends. The front lower control arms are from an XT6. The transmission cross- member is a mixture of '94 Legacy and XT6. It bolts right in. The 5 speed transmission and rear differential are from a '94 Legacy 4WD, the ratio is 4.11. The clutch, flywheel, and starter are '94 Legacy as well. The front section of the rear Loyale driveshaft had to be shortened 51mm to fit with the EJ transmission installed. The front brakes are Loyale calipers with '93 Impreza FWD brackets (with 1 of the Loyale caliper pins installed), hubs, rotors and pads. This allows me to retain the front parking brake. I am pretty sure I used stock '93 Impreza FWD axles but it's been a while. I added a rear sway bar using the sway bar and trailing arms from an XT4. The rear disc brake backing plates are '94 Legacy 4WD modified to fit the XT4 trailing arms. The rear rotors, calipers, brackets, and pads are from a '94 Legacy 4WD with XT6 4WD rear hubs. The wheels are 16" Enkei Fittipaldi with 205 55 16 tires. I have a stock Subaru '92 Legacy Sport Air to Water intercooler (AWIC) setup that I had shipped in from New Zealand. I hope it will fit as I haven't tested it yet. As far as I know these were never available in the USA. This would let me keep the stock hood without adding a scoop. It's been about a 7 year project so far. It's been lots of fun building it but it's taking me way too long. At least it's almost done. Here is a thread with a few pictures https://www.ultimatesubaru.org/forum/topic/145759-royal-loyale/?tab=comments#comment-1224351 Thank you for sharing your awesome project! I look forward to more updates! -
Nice project! Please keep the thread updated as you make progress. It looks good so far. I have an EJ22T going in to a '92 Loyale. It's taking me way too long to get it done -
If you already have the engine out and it's an EA82T I would do the head gaskets even though it has low mileage. Nice looking car!
The small black unit on the speedometer with 2 wires is probably the vehicle speed sensor (VSS). It's probably not used in your car unless you have fuel injection.
I picked this one up, do you think it will work? I am having trouble finding a flange to match the oval shaped port on the lower side.
That's really nice of you. Do you have a picture of it? How much do you want for it?
U-joint from Toyota van?
Crazyeights replied to Zip Tie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I need to learn how or where to accomplish this on a custom length driveshaft I have. Thanks for the start. -
Upgrades for 85 brat
Crazyeights replied to Wannabebrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had that same 4 inch SJR EA81 lift kit on my 1983 GL 4WD Wagon for about 12 years now and I am very happy with it. It doesn't eat axles - same ones are still in there and it handles great. I used a Forester steering shaft and it fit right in. I think it was from a '98 or so. I have an EJ22 in mine so I can't offer an opinion about the Weber conversion or the exhaust but I hear they are worth while upgrades. Good luck with your project! -
Check with Painless Wiring for the fuse box. I have installed several Painless wiring harnesses in street rods over the years. Very good products and the fuse boxes are nice. https://www.painlessperformance.com/ All my best to you and your family. So sorry for the loss of your father.
Scary moment due to accelerator cable
Crazyeights replied to Steptoe's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Brat EA81 Rebuild thread
Crazyeights replied to Subarute1984's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used Loctite 518 flange sealant on mine but you can use Fuji Bond, Toyota Bond, etc just don't use rtv. There is no gasket between the case halves. There is a special oval shaped o-ring in there though. -
EJ22 flywheel rubbing in 91 loyale
What cross member are you using? I have an EJ22 and an EJ 5 speed in a 92 loyale with no problems. As I remember I had to use part of an XT6 cross member (was hard to find). -
Front parking brake assambly '86 xt
Crazyeights replied to 86 xt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
These calipers have problematic parking brake mechanisms. Even if you assemble it perfectly it may not work right. I gave up and ordered a set from Rock Auto for my '88 Wagon. It took me (5) calipers to get 1 set with functioning parking brakes. Fortunately Rock Auto was really good about it but it was still a mess. I wish you the best of luck. If you get a good working set make sure and keep your brake fluid flushed and clean so they last as long as possible. -
The EA81 and EA82 do share the same main and rod bearings.
