13
Everything posted by Mike104
That looks like a fun job to do on the ground! Good thing you had a lift available
- 11 replies
- p0768
- valve body
(and 4 more)
Tagged with:
Also wait a second or two after you turn the key to ON before you move it to START then hold it there for a few seconds. I put a alternate start line for my kid's car that lives an hour away and has starting issues. Just ran a parallel line from the starter solenoid and left it secured near the starter so if needed he can touch it to the Positive terminal of the battery after turning the ignition switch to on. Put a fuse in it for protection.
Using parts interchange listings, and trying other vehicles on that list, I came up with a few other part numbers. Napa lists a UJ10430, although there was no availability. Autozone lists a 2-0430DL, of which they had 4 in their Hub store across town. I now have 2 of those sitting on my desk (they are greasable, btw).
We all make mistakes. The main issue is a) was it done because you didn't know any better (not intentional) and b) did you own up to the mistake or try to hide it from being discovered. In my line of work if you don't follow b) people can die (no road shoulders at 30,000 ft). The other concern is like GD says is it a continuing case of mistakes.
My son and I chased a poor running issue on two Subaru's, both ended up being a coil. I went to the pull and pay yard and got a Subaru OEM one and when I installed them all running issues went away. Stay away from the aftermarket part store ones, I have never had much luck with them but don't want to spend $$$ for an OEM part from a dealer. The pull and pay yard worked for me. All that being said is this a Coil Over Plug engine?
