el_freddo
    153
  1. You might have a leaking injector filling a cylinder with fuel when it’s not running. check your oil and see if it smells like petrol. This theory doesn’t work if you tried starting immediately after. Two other things that come to mind - an issue with your starter motor or a sticky/stuck IACV. Is it cranking the engine over at a good speed on initial start up and there after? Cheers Bennie
  2. Yep. Clean all mating surfaces first (except the HGs - they come straight from the bag onto the prepped block deck face). Follow that procedure and you can’t go wrong. Cheers Bennie
  3. You guys had an outback sedan and don’t get the Levorg? Weird. Levorgs look the part. I wouldn’t mind one but there’s no way I’ll be able to afford one while they’re still useful and not failing in the engine department etc. Cheers Bennie
  4. I got bored half way through. He didn’t go all out early on to say why it failed until he got to the sump side of things, even then... EJ251 - good engine in my book. Too many people neglect to properly service them and then they fail. Next step is to blame the equipment before taking responsibility for your own actions (or inactions). My 2c anyway. Cheers Bennie
  5. And the loyale is an EA82, best to post in the older gen forum Cheers Bennie
  6. If you have AC the evaporator could be very clogged up with leaves, pet hair or lint. Pull the fan unit and clean out the AC evaporator of any crap that’s in there. Won’t be an easy job but it could be the problem. Cheers Bennie
  7. GD, I don’t doubt the later model dash boards are more involved, I was talking about the MY dash since that’s what the vehicle in question is. My comment was regarding the older models. Not many Subi specialist shops would be well versed in removing dashboards from the old school Subaru. I’ve had the pleasure of removing a Gen1 Liberty dashboard but we never reinstalled. In some areas they were a massive improvement over the MY and L series dashboards but on the flip side there were loads more connectors to sort out too. Miss one of those on reinstall could see you tearing hair later. The MY unit was clearly not designed to be removed with the windscreen in place. They rectified this in the models after the EA81. Cheers Bennie
  8. Too much tyre pressure is a killer in sand! The softer the sand the lower the pressure. With low pressures, no sharp turns or you could roll the tyre bead off the rim and have a complete flat that’s got sand in it. That or you end up with a slow leak due to sand between the bead and the rim. Been there done that a number of times! Cheers Bennie
  9. All the best finding your beast in one piece abandoned somewhere that it’s not then trashed. Cheers Bennie
  10. That’s a business’ way of politely saying they don’t want the job. And it’s money for jam if someone pays! Cheers Bennie
  11. Yeah I have no idea on that Dfoyl. I’ve never looked into it. Cheers Bennie
  12. Trapped air won’t cool. And it can allow the cooling system to push fluid out the rad overflow as air will expand more than the coolant. No overflow reservoir will see your radiator lose coolant over time until it reaches a certain level where it can’t push any more fluid out. By all means, block off the throttle body warming circuit but I’d be keeping the block to thermostat housing hose. Cheers Bennie
  13. Yeah do it! Bugger cracks, deal with that later! First I’ve heard about the cracking issue - but then again I don’t deal with them on a regular basis, or at all for that matter. 6 speed would be highly recommended! Cheers Bennie
  14. I think you made the right choice not to just run with this block as it was. Cheers Bennie
  15. Welcome mate. What sort of Subaru do you have? It’ll either be EA or EJ - that’ll give us a big clue. Cheers Bennie
  16. Don’t lever on it. You need a quick punch to the spanner/breaker bar/whatever you’re using as this will break the hold on the threads. Alloy is good for holding steel. Cheers Bennie
  17. I replace cam and crank seals as a part of the timing belt service. You don’t want to deal with a leaking seal because you didn’t put in the extra bit of time and effort to swap the seal. It’s not like the seal is easily accessible. With the EJ timing kit the crank and cam seals come as part of the kit from what I remember. I now buy the parts individually as I get genuine when I can. Better bang for buck in my experience. EA82, I’d run whatever timing kit and have a spare kit on hand with a set of tools to do the job on the side of the road if needed. Cheers Bennie
  18. Certainly did - L series dual range in Gen1 dual range EJ cases. Worked a treat. That box was swapped out for an AWD L box with phase 2 EJ gearbox front cases and gearing. Yes. Front diff stubs are held in by a circlip on the inside of the spider gears. L and EJ interchange. Driveshaft lengths are still different so a custom length shaft is still required. Over here we got the NA MPFI EA82 L series that has the EJ spec 25 spline front diff stubs and the good 1.59:1 L series low range. It’s all Lego! Back on the 5 stud swap with bigger EJ brakes, you still need to work out something for the rear hub as the L and EJ rear hub setup is completely different. Cheers Bennie
  19. JesZek, 2020 is not a good year to say the least. You’ve put into perspective how lucky we are over here during the pandemic and I wish Melbourians would quit winging about it. Very sorry to hear about the loss of your Dad, especially so unexpectedly. You have fond memories of him and I’m sure you will keep them alive, same for the Mercury. While it might be painful to look, work on or drive it, that vehicle is one very huge link to many good memories with your Dad. Look after it and in time you will enjoy driving it because of your memories with your Dad. All the best mate. Bennie
  20. Subaru did start out with a 10mm pump. As oils thinned out so did the thickness of the oil pump rotor. No change to housing that will interfere with anything else. If it’s EJ it will bolt on to any EJ block. Totally agree. More safety gear makes ppl more complacent. Look what happened to that dude in Cali that died in his automated Tesla. He was meant to be watching/monitoring - alas he paid the ultimate price for not watching. Cheers Bennie
  21. The problem with the gearboxes is hard gear changes - and constantly. Many WRX gearboxes break second due to hard high rpm gear changes. Mods or not, the extra torque produced on boost isn’t nice on gearboxes due to shock loading etc. AWD traction doesn’t help either. The EJ251 as I mentioned in Numbchux’s “help me decidel thread, cops the poor reputation of the EJ25D and the crappy factory HG didn’t help. Swap them for MLS HGs. The H6 HG seems more seems more economical to swap the whole engine for an import create engine. I’ve heard issues with burning valves if valve clearances aren’t done at the service intervals. I don’t have any direct experience with this, just “heard” about it. The Gen3 is a solid platform. What sort of soft raiding are you planning to do? Either way, an auto will spoob all over a manual, more so that you don’t have a low range in the manual. Cheers Bennie
  22. It’s not really an issue. Just something GD replaces as a part of his major service that he does to provide a warranty he’s comfortable with. I’ve got two EJ251s in my family. Both high km, same oil pump from factory. Zero issues. Both have HGs swapped for the MLS units. Main “issue” now is regular maintenance such as oil changes (and filter), then the “big one” when the cam belt is due for replacement. Bloody good engine in my book - they cop loads of flak from the reputation of the EJ25D. Cheers Bennie
  23. That thing really IS mint! EJ swap it with a manual gearbox and keep it! Cheers Bennie
  24. The EJ22 will be just fine. You’ll break things if you’re being stupid in it. The EJ253 will be fine too - if you take it easy. Spinning wheels generally isn’t an issue, it’s when you go to doing them and they have more traction that you first thought. Of course constant purposeful wheel spinning (as opposed to breaking traction once rolling or when in the wet) will end up killing the gearbox. You WILL want AWD with the EJ253! Front LSD can be fitted with the 1.59:1. Some shaving of the LSD housing may be needed. I have an OBX in the front diff of my L - I run factory MPFI/turbo L series driveshafts to mate to the EJ style 25 spline diff stubs. Works a treat. As mentioned, the wiring cut down for the EJ253 will be the issue if it has the immobiliser or CANBUS. I’m sure the immobiliser can be worked around. A mate just put a 2001 EJ251 into his EA81 hatch, drops in as its SOHC and it goes mint from what he tells me. Cheers Bennie
  25. True, thanks for point that out to me. I was adding to your comment as to why this may be: Cheers Bennie
