czny
Everything posted by czny
  1. Yeah, that thermo bulb is meant to be stuffed into the evap coils to compensate for changing temps. OK, so you don't know if the evaporator or condenser coils are clean & free flowing. The filter should be somewhere near the inlet line to the condenser, sometimes in front of the radiator if small enough. Some filters have a view window built into the top. Others have ports for the high-low pressure switches. Changing the high side filter when replacing the compressor is a MUST. So is flushing the coils & lines to rid the system of contaminated oils & particulates. Most parts store carry system flush in aerosol cans for $15-20. After flushing blow out all parts with dry compressed air. AND, evacuating the system then charging with a little R134 to test for leaks before fully charging the system. Also, did you drain the compressor oil then refill it with recommended oil? Likewise with the filter & condenser. There has to a certain total amount of oil in the system to survive. Otherwise you'll be lunching the compressor again & again, contaminating the lines, condenser, evaporator etc again & again. Here's a 99 Lego drier-accumulator-filter: https://www.rockauto.com/en/moreinfo.php?pk=2195678&cc=1389405&jsn=351 More reading: http://www.ultimatesubaru.org/forum/topic/163981-98-outback-ac-work-compressor-dryer-and-evaporator/?hl=%2Bconditioning+%2Bcompressor&do=findComment&comment=1363158
  2. I meant to say "replaced the compressor(comma) expansion valve & still" etc. Does that expansion valve have a pilot tube connected to the system - in other words there are three connections to it? Did you replace the inline filter when you did the compressor too? A clogged filter would affect the pressures. Did you flush the evaporator & condenser coils? Another thing often overlooked are the rubber lines themselves. Inner linings have been known to collapse, blocking flow.
  3. "I replaced the expansion valve in the AC system and there is still no pressure difference between high and low side with the compressor running. Could this be caused by insufficient oil? Or should I get a different compressor?" From what I've read, you've replaced the compressor expansion valve & still the compressor doesn't cycle. Are you sure the A/C clutch is engaging to drive the compressor? Unless the clutch is engaged the pump won't rotate. Very simple to power that clutch with a hot wire to test the clutch with engine running & gauges connected. Have you checked the pressure high-low switch, thermal overload in compressor or anything else in A/C clutch control circuits? I don't have a diagram here for your vehicle.
  4. Found your moose-ns t-shirt: https://www.ebay.com/itm/Rocky-and-Bullwinkle-Wossamotta-U-T-Shirt-New/162118335368?ssPageName=STRK%3AMEBIDX%3AIT&var=461080256650&_trksid=p2055119.m1438.l2649 https://www.ebay.com/itm/Rocky-Bullwinkle-Wossamotta-U-WU-Tee-Adult-T-Shirt/111102044166?hash=item19de32a806:m:mwNRhdundLUetOLLVUGXF5w The whole car-not-done, etc skit has probably been "done" worldwide to everyone's amusement.
  5. If its reman parts for a Fix-It-Again-Tony, I'd say the first way Cardone is about 20 miles east of me here. We say car done. Sad part is, sometimes car isn't done with those products. Good luck with your recon dizzy.
  6. We just had that same question 3 pages back here: http://www.ultimatesubaru.org/forum/topic/165565-looking-for-options-for-slipping-clutch-on-ej-swap/ Have the FW step machined to the .810 to .815 inch depth after cleaning up the clutch face of FW. More holding power for hills, larger tires/wheels, etc with that Exedy 15008 clutch.
  7. When you do get a high lift farm jack, do yourself a favor & get some accessories for lifting. Its always easier to lift a corner with the wheel & suspension already compressed. This add-on puts 2 hooks around the wheel spokes to lift from car by the wheel & has a padded face to protect things. If you keep driving off road you may want to get some steel wheels so they don't get scarfed up from rocks etc. https://www.ebay.com/itm/High-Lift-Wheel-3-Tons-6000lbs-Lift-Mate-Jack-Mate-for-Farm-Jack/351988414170?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Make a steel plate about a foot square(0.3 m x 0.3 m) with 3 holes drilled in same pattern as foot of high lift jack to bolt on. Having a bigger footprint for jack helps keep it from sinking. I have used this many times when stuck in soft sand in the desert - it really does help & saves time looking for flat rocks, etc for a jacking base.
  8. https://www.mcmaster.com/#urethane/=1b3078z
  9. http://www.ultimatesubaru.org/forum/topic/47526-subaru-ecu-codes-for-1983-1988/
  10. Agreed. Ring terminal goes on the short passenger side intake bolt with 12 mm head. That is the main engine harness ground.
  11. Bought a couple kits from these ebay stores for my wiring needs: http://stores.ebay.com/mjmnationalinc/ http://stores.ebay.com/customconnectorkits/
  12. Yup, that's why I have an extra EA flywheel too. Now that my days in Commiefornia are numbered(because the place in Troy MT is becoming a reality) I can change over to an EJ too. At last! Having less torque with an EA it was necessary for me to shift more often in the hills on trip to MT. Edit: Go with what the others have told you for step depth on your flywheel - .810 to .815 inch. Exedy 15008 clutch kit. I know I will. Have a brand new Sachs clutch kit for the convert too. Unobtainium.
  13. While I can appreciate your enthusiasm to upgrade - hop up - hot rod your Brat, know that no vehicles 76 & newer can be altered in any way & still pass the new smog requirements. California really, really sucks when it comes to building up an engine horsepower wise. My 87 TBI Subaru GL wagon passed with no problem but only because it is still running an under powered EA82 in near stock form. They almost didn't allow the 2nd cat conv because they said it wasn't on the accepted list - a list that had been changed 3 yrs ago after I had already replaced that cat conv! And had passed smog with it 2 yrs ago! Ridiculous smog laws. Stupid Schwarzenegger signed a freeze to the rolling 25 yr exemptions while he was in office. Now Brown is stirring the emissions pot for more changes. Yet another reason I'm moving out of Commiefornia. End of rant.
  14. If they don't know what a step in a flywheel is, don't take it to them. Had mine cut but mach shop wouldn't go less than .827", 21 mm. When the mach shop second guesses you, its time to find another shop. Clutch is still holding up well now for 8 yrs.
  15. Glad to have been of service in this case. Be sure to let them know their past caught up with them. It takes a thousand attaboys to make up for one awsh*t.
  16. Found some stuff for Lokka Matt. "You sent a payment of $396.00 USD to Super Benefit Pty Ltd ATF the Gear to Goannawhere Trust (isales@lokka.com)" After re-reading my emails, actual start of all this slow-motion email ripoff started in late 2014 & ended in April 2016 when they wouldn't respond any longer. The main character I dealt with by email was going by "JD", the "boss" never got involved with the whole thing. Gear to Goannawhere: https://www.4wdsystems.com.au/ https://www.4wdsystems.com.au/index.php?id=125 http://abncheck.com.au/abn/30991504889 http://www.statsinfinity.com/domain/rGTxW5qAzpGTwjeiZY2hxQ.._info.html Looks like things changed in 2014 then again in 2016, so somewhere in between all these changes they dropped the ball & never followed up on my order at all. I'll just have to get $400 satisfaction dissing them at any opportunity on here, Pirate4x4, Ih8mud, etc.
  17. A pulley tap has a reduced shank just for that purpose. https://www.mcmaster.com/#pulley-taps/=1alewv7
  18. I'd rather not log onto my PayPal account to search history while I'm on the road like this. That acct was on a yahoo address that I since closed because of all the trouble yahoo accts getting hacked in 2014 & later. IIRC that super benefit was out of taiwan or hong kong for Lokka. When I get home I'll see if I can find more info for you Matt. I think I'd rather deal with the makers of Spartan lockers.
  19. As I recall it was someone with initials instead of a name like that RJ, JT or some such. I may have saved the emails on my desktop - can't recall right now & I'm on my laptop hundreds of miles from home in Baker City OR as I type this. Another fact: I repeatedly requested a refund by email & then by letter when things went sour. NOTHING! I suspect the salesmen use initials to hide just as others use usernames on the forums to protect themselves. Google 'Super Benefit Party Ltd' & see what you get Matt.
  20. I for one would NEVER deal with those thieves again. 4 yrs ago paid $399 thru PayPal to "SuperBenefitParty.com", Lokka's PayPal address for a R180 lunchbox locker to fit a 1986 Nissan 200SX open diff. They requested pics, drawings, dimensions & finally my carrier with internals. Had to ship my stuff thru Parcel Monkey for best rate to Australia. NEVER saw anything from it. Their response time & follow-up for emails was terrible. Be forewarned - I was burned for the money because length of time for transaction exceeded PayPal's overseas policies. And had to find another 200sx diff which aren't easily found at the self-serve yards anymore. F''k Lokka!!!!!!!!!!!!
  21. DL headlight buckets aren't quite deep enough for these LED lamps so replaced the trim ring screws with longer allens & backed those up with nuts behind the bucket flanges to keep all from vibrating loose. Helps keep pressure down on plastic the lenses so they don't crack later on. Can't recall the thread pitch of those screws but found them at a Home Depot locally.
  22. Installed 4x6 LED headlights outboard on my GL before house hunting trip to Montana. This trip would've been better with an EJ engine but this the last hurrah for this EA82. Its a dog but a dependable one. 1380 miles in 3 days of rowing the stick on hills.Had to strike while the iron was hot. Pic is along the 28N in Idaho approaching the 93N then thru the Bitterroot Mtns. on way to Hamilton MT. https://www.google.com/maps/place/Bitterroot+Mountains/@45.8001599,-114.4418378,9z/data=!4m5!3m4!1s0x535915a184e5f8c5:0xfba63605bbcae42b!8m2!3d45.8076982!4d-113.9389673 Saw a herd of pronghorn antelope along the way.
  23. Drove 1500 miles already & nobody has flashed their beams yet. Mine have top row & center rows of LEDs for low beams. SAE print goes to top of lamp. Low beams following another car I just keep back far enough that beams don't meet back window of car ahead. Tractor-trailer rigs around here have them too.
  24. I replaced my outer pair of 4 x 6 lights with these: https://www.ebay.com/itm/4X6-LED-Cree-Headlights-Sealed-Beam-Hi-Lo-Bulbs-White-6000K-Head-Lamps/252638282642?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Low current & very bright.
  25. You're probably better off doing an H4 dual headlight conversion with low & high beam relays wired directly to fused battery connections. Buy 4 9003/H4 headlight connectors, some colored wire, 4 pin relays & sockets & go to town. https://www.google.com/search?q=dual+h4+headlight+schematics&tbm=isch&source=iu&ictx=1&fir=0d2NTE8Pvu-scM%253A%252CgCpuDJ6wHe1seM%252C_&usg=__PBiHrNfoiqVII9pGIYk1rh95bVY%3D&sa=X&ved=0ahUKEwiNtpuWluXXAhWh5IMKHbM8BusQ9QEIKzAA#imgrc=11W7UL5r5X02EM: I did this but added a center pair/fog light switch in dash.
