10
Everything posted by ivans imports
True duals on a BRAT
ivans imports replied to RustyBrat's topic in Historic Subaru Forum: 50's thru 70's
My 81 brat has full deuls two glasspacks xover and two bike mufflers one on each side blows rings out both side when cold and loud but not to loud did not make any power diff but sounds cool -
hitachi carb - issues after partial rebuild
ivans imports replied to belacane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I found putting a clear feul fillter under the hood helped could see whats coming up to carb is good diagnostic tool -
I am looking for more power down low below 1000 RPM
ivans imports replied to Scott in Bellingham's topic in Off Road
We just couldent get standard trans to hold up to high hp no matter what. Keeping in mind my auto is not compleatly stock we put outback forward clutchpack and drum into the early 4eat gives me two wide clutchs instead of 3 thin clutchs and tougher basket other than that stock. I also only use 1rst / 2nd gears have no need for rest as it will do 110 kms in 2nd. Sorry a'm not trying to tell you guys what to do just what worked for me. A'm going on to almost 18 years of bagen subarus in the bush and many many hours of subaru offroad in many difernt setup subarus. -
Make cardboard drawings of front / rear covers and mark bolt holes on it so yo can keep all bolts in order of were they go this saved me hours. And took minutes had 6 or 8 templates this is the best way i can think of as many of the bolts were differnt lengths
- 10 replies
I installed a rebiuld engine yesterday took 10 seconds for oil light to go out I do not crank them at all just fire it dont want to push all are assembly lube out cranking with no oil preshure is bad thing just fire it remember pump is trying to pull oil up hill and you dont make mutch rpms cranking
ea82 radiator okay with ej22?
ivans imports replied to Subinoobi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used the ea82 rads not ideal but will work fine -
ea82 decent compression?
good 150 + max 175 is about the highest ive seen -
oh no we run this thing for tank after tank of gas on my freinds unlimited beach 100kms of beach front hills jumps rock piles sand holes mud pitts ect I putt it thru hell trying to break it before race season hours and hours of abuse 3 drivers 3day 3 times a year in the end we broke 4 rear axles and colasped one front strut trans never got hot. Even in two ft of snow pulling very hard under boost still never got hot warm but not hot -
Any play in diss shaft ? alt overchargeing
- 5 replies
- engine problems
- missing
(and 5 more)
Tagged with:
Have you checked the main engine harnes conectors are pluged in all the way and no bent pins
83 Brat front hubs rattle
ivans imports replied to bartbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Chage hubs splines are worn to badly also watch out for axles with older car ends on them have had rebiuld axles with 70s outer ends slight diff in spline length and will never titen right. Also make shure 200ft lbs or better on that nut -
I did a piston on one was crazy hard 285 bolts one piston pin In center cly [ what a pain ] anyway timing covers and componets was crazy amount of parts. Had to make cradboad templates to keep bolts organized and coverd the whole floor of my shop with peices before i got to cly head . Took me about 15-20 hours with motor out. One other note have 3 of thoose engines two had oil cooler to block ishues were coolat was getting into oil somthing to do with orings on oil cooler halfs. The one engine i have has 380000kms on it headgaskets were fine
- 10 replies
