lmdew
    176
Everything posted by lmdew
  1. Yep, I've had good results with both if used correctly. And yes, as I said a tune up is on the schedule as well as a good inspection the engine.
  2. I picked up a 2005 Impreza from a coworker and it's going to my brother's better half. Auto 129K Runs nice, but has a low idle, showing 300 RPM on the gauge in D or N. I plan on running some Seafoam through it Changing the Plugs and see what they look like I've added some lucas fuel conditioner and Shell premium Idle control valve? I'm just starting on this one Thanks, Larry
  3. I pulled the dash today, thinking it might be a loose screw. No such luck, a large circuit board and everything is soldered in. Any ideas other than getting a replacement cluster? I did not see any problems with the circuits. Everything but the Tach works. Thanks, Larry
  4. They are rubber gaskets, installed dry. Make sure you use a 6 point socket or wrench. Some of the bolts are a bugger to get out. Every once in awhile I have to drop the exhaust and jack the engine to get the back bolts if they were rounded off or very tight. Amazon, Felpro kits are pretty good and priced right. If the plugs have not been done in awhile, it's a good time to put in a new set of NKG copper core plugs and wires if you need them. Subaru or NGK on the wires as well.
  5. If you need a replacement engine go with a 95 2.2 with ERG. Plug and Play for the most part.
  6. Emily, you and Rick and the rest of the Gang at CCR are the best. Thanks for taking the time to post to the USMB, I know you have a lot going on. Larry
  7. No, it was not the usual things. The Dash light ABS was on. If it comes back, I'll dig under the dash and find the main power relay - key on, power on relay. Thanks, Larry
  8. Yep, motor is plug and play. Save the motor and any other good parts you may want. Scrap the rest about $250 or so for the weight of the metal.
  9. A 99 Legacy Outback 2.2 swap I did awhile back, started draining the Battery. The new owner went to Autozone and they sold him an Alt. He also got a new Walmart battery. Power was still draining, the ABS light .... I removed the Autozone Alt and installed a Subaru Alt. I charged the Battery It started and stopped just fine many times. All power was removed each time I shut it off. I think the main relay may have been sticking, all though I've never seen that before. I looked under the dash, lower panel removed. I did not see the relays, where are they on a 99? Thanks Larry
  10. I got a 2003 that sounded like a bad rod knock and it was the idler gear hitting the water pump. The inner and outer race if the toothed Idler were there but no ball bearings. Worst one I've seen that was still running.
  11. Injector! I pulled # 4 today and it was a red injector I have never seen. Instead of the normal metal end it was plastic. I put in a red Subaru metal end injector, NO MORE Cell and it's running better. I'll swap out all 4 injectors and the fuel rails in the next day or two. I'm sure it will be a good Subaru 2.2 again. Thanks, Larry
  12. Grab a spare bolt from a yard and file or grind a v notch down the length of the threads, you know have a backyard thread chaser.
  13. No the plug is not fouling. I have lots of injectors, I'll put one in and see if that solves the problem. Compression test if I can fine my tester. Thanks, Larry
  14. I got a used 95 2.2 with 57K on it from a yard. I paid $850 for it, way more than the YPAP motors I usually get, but hey with 57K on it I figured it was worth it. Well, It's been nothing but problems. - First it would not start, bad Crank Sensor - easy fix. - It starts but is not running smooth, P0302 & P0304 so I figure a bad coil. I put a good Subaru coil in but its still missing - Pull the Plugs, #4 is oil soaked. I call the yard, they call the yard they got the motor from. They say we pickle the motors when we pull them. - Today I flushed the cylinders with jet fuel. I pulled the plugs, filled the cylinder with jet fuel and let it soak a few minutes. I rotated it over by hand with the plugs still out and then with the starter to get all the fuel out. - Put the plugs back in and rotated it by hand to make sure it was not locked up - Started right up and was running better but still missing - P0304, flashing CEL. The code will clear, but comes back soon. The Injector is snapping well, so I don't think it's fuel I'm about ready to pull the engine and get a refund. Anything else, worth checking before I pull it? Thanks, Larry Back to the UPAP for motors.
  15. Happy Thanksgiving to all USMB folks. - Thanks for the Great USMB - I'm thankful I can still pull engines and work on Subaru's for Fun Larry
  16. If they are that messed up, you could drill off the heads of the bolt and then grab the body of the bolt once you have the valve covers off. you may have to drop the exhaust and remove the mount bolts and pitch stopper to raise the engine enough.
  17. Forester or Outback struts and springs will give you what you want. Find a good used set of KYB complete struts and springs. To center the rear wheels, you need the trailing arm mounting bracket that goes up to the frame. To correct camber, I've used a second set of rear trailing arm bolts in the top strut hole. It allows you to tip the hub in about an 1/8" and that is just about perfect. I watch for the KYB at the self-serve yards and grab them when I see them.
  18. The two large gray plugs on top of the trans just behind the engine. If you search here for torque bind you will find lot's of info. You can pull the trans tail shaft if it is the C-Duty that's bad.
  19. Come down to Colorado Springs, I have a few in work 2005 OBS Rebuilt motor 152K, almost ready 2003 Baja - Just about ready, but I may keep this one 2000 OBS - Just about ready 1998 OBS - Needs a trany, pops out of 4th. I have a good trans, just need time to install it. 1998 Legacy Outback, getting a 2.2 swap this weekend 1999 Legacy Outback, Auto, has some body damage to the passenger rear, goes down the road fine but alignment is out. $600 Clear Title
  20. Make sure you used the correct timing marks and that the crank and left cam gear are the same as your old engine. Before you tear into the timing, put a cap full of gas in the intake, but it all back together and see if it starts If it cranks well, the battery and starter are good and it one of two things that's not allowing it to start: - no Fuel - no Spark 1+ for checking codes I'm sure you have, but double check all electrical connections - are the plugs fully seated.
  21. I have a 2005 OBS and the PO had dogs. I need to replace the window seals, and on these cars the seal is one large piece that also runs down the B-Pillar. The B-Pillar has a plastic trim piece held on by 4 plastic clips. How do you remove the trip without breaking the trim or clips? I've tried a couple at the yards and the top to clips have a inverted U clip and the bottom a normal U clip slots. Thus you can't slide it up or down to remove the trim. I know there is a trick, what is it? If no knows for sure, I'll head to a body shop and ask them to remove it. Thanks, Larry
  22. Buy a used hub and install it yourself. If you have a You Pull and Pay yard that will be the cheapest and you get to perfect your skills on the used car. Also check your CV Joint boots. rocking back and forth and hearing a noise could be the CV Joint on the half shaft. www.car-part.com is a good place to check full service yards.
  23. Make sure your timing belt idler gear is not going bad! I pulled a 2003 that sounded like a bad rod knock and the T-Belt idler gear was hitting the water pump housing. The bearing was gone! I pulled a 2000 Impreza that was not running, PO said bad shake, you guessed it, the T-Belt idler gear was running on the inner race, with no ball bearings left in it. Two of them in one day! Get the Gates Kit's and always change the idlers along with the T-Belt.
  24. Thanks, I usually feel the USMB is pretty safe, but it always is a good idea to be safer. Larry
