Turbone
Administrator
    28
Everything posted by Turbone
  1. The Fox looks like he's in disguise. And whats that look for?
  2. I do have more. 1/8in isnt much, and he can probably get more by taking some of the stuff out of the back:D
  3. Just make sure the hoses you use dont have holes and they make a tight connection.
  4. It was hard finding this thread again, and it took me a few days to actually get out, move the Hatch and pull out the measuring tape. 14.25" of diff clearance. This is with 3" lift, 28" Superswampers, EA82 adjustable rear shocks and the torsion bar racheted.
  5. Signs of a bad air/vacume leak. Use a can of starter fluid and spray small shots around where you made changes. A change in idle will give you the location.
  6. The rotation of the rotor is CCW, and plug firing order is 1324. Alot of people have made the mistake on the disty rotation, me included.
  7. Do the blinkers work? I would suspect the stop checker myself.
  8. It says what the ratio is on a tag on the back of the diff. It also will have in big letters - LSD. Thats if you have it.
  9. Hey Soobme, can you make a brushguard like the one on the EA82 Sedan?
  10. Well, your all right with the belts. It sounds like they are installed right. I think the problem could be the cat, typical symptoms. Feel the end of the exhaust pipe with someone in the car giving it the gas. You can also pull the O2 sensor out to test, but that can sometimes be a bear. If you need to have the car inspected yearly, you may have to have a new one installed.
  11. You will need to have the diff match the tranny ratio, should be 3.9.
  12. http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f50d9b8.15492800/&FileType=Article&File=ARTICLE_3f29b750a92b88.77574552.art This is basically the same swap, just need to get the pedal box, clutch cable, tranny xmember and strut caps. Is it 2wd or 4wd?
  13. Personally, I only rib, raz and cajole people that I know well and have been on the board for a while (at least over a year). That way I know how much I can get away with:D Personal attacks are a nono. If you want to question a persons reasons for what they are doing, do it with a PM or email.
  14. Are you missing any rubber gromets in the firewall? All the seals around the doors and windows look good? Check underneath the car itself and look for holes in the floorpan also.
  15. So? Dont keep your finger crossed, but someday it could come back. So in the meantime, you will probably see alot of threads like this:brow:
  16. Cool Mick, it looks like I wont be the only one. Altho you only have to replace the belts, I have to replace the engine. But I'm not complaning:D Mine is coming at a slightly lower price, but not much. With delivery, its $30 more.
  17. Lets not go there, ok? He has one more chance to make things right. After that, who knows.
  18. Sorry, should have added the year in my last post. That is for 85.
  19. Wow, this is great news . I really hope this can come true, it will be the best thing since........uh, well you know. I'm sure we could gather up some volunteers for help in building the track, or whatever. When will we hear more?
  20. My FSM says both the 4dr and 3dr Turbo's had 5spd D/R's.
  21. Somebody correct me if I'm wrong, bit didnt the 85 Rx have a D/R?
  22. Zap is from the "School of Hard Rocks". Literaly, and in more ways than one:brow:
  23. The best one to hope for would be the GL10 4wd Trubo, with 5spd of course. A 4wd manual with turbo is ok too. Anything else, with problems, may not be worth it.
  24. Hmmm, just maybe the Canadien models were a little different then US models for those years? Btw, nice score Brian.
